Old May 04, 2010, 04:56 AM
NicholasC is offline
Find More Posts by NicholasC
Parma - Italy
Joined Nov 2009
Home made EDF - Twin EDF for airliner
Hi everybody!!!
I'm building an RC airliner, so I need 2 EDF (I can even use 2 pull props hidden under the wings, but I want EDF!!! ).
The problem is that the EDF has very low efficency (thrust/W) so it needs more power from the battery to get the same thrust.
So I decided to take a normal brushless motor with a normal prop (maybe with 4 blades) and close them inside a duct (pipe), it will be bigger than a normal EDF because the diameter would be the same as the prop, but I'll get a lot more power with less consumption... right?!?
Another thing, having 1 motors on both sides of the plane (1 for each wing), should I make the two motors to rotate in opposite direction to avoid some strange behavior of the plane? Or it doesn't change a lot?
Thank you all!!!
NicholasC is offline Find More Posts by NicholasC
Old May 04, 2010, 05:16 AM
u.rusty is offline
Find More Posts by u.rusty
Novice RC pilot
u.rusty's Avatar
California
Joined Feb 2008
Why have you posted this in the Batteries and Chargers forum and not the Power Systems forum?
u.rusty is offline Find More Posts by u.rusty
Old May 04, 2010, 06:03 AM
Parma - Italy
Joined Nov 2009
Yau are right, how can I delete it? I tryed but I couldn't figure out how.
Old May 04, 2010, 11:46 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Since you have already reposted in Power Systems, just close this thread by going to Thread Tools and choosing to.
Welcome to RCGroups, btw!
mw
Mark Wood is online now Find More Posts by Mark Wood
Home made Depron SU-27 Flanker twin EDF allintheair Foamy EDFs 21 Nov 06, 2012 09:51 PM
Build Log Home made Extended inner shaft for MCX Razors edge 29 Coaxial Helicopters 89 May 01, 2010 09:19 AM
Question Ideas for home made flexible nose skid jswain Sailplane Talk 18 Mar 16, 2010 09:55 PM
Discussion Home made twin motor plane for HD video with Pan and Tilt. pthompson24 Aerial Photography 83 Jan 12, 2010 06:07 PM
Discussion MIG 29 home made twin EDF construction volorc Electric Ducted Fan Jet Talk 112 Aug 24, 2009 11:07 AM
