Old May 03, 2010, 07:39 PM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
MK Hexa video with Canon T2i & 10-22 lens
Using a modified Hexakopter to carry a Canon T2i/550D and a 10-22 lens I shot this sample this morning.
I set the focal length at 22mm to better show any vibration on our camera gimbal. There is none. Absolutely zero rolling shutter artifacts. Even when panning at a moderate speed the video shows no rolling shutter problems.
The vibration isolation system used on our gimbal is extremely effective although these multicopters do not exhibit vibration problems nearly as bad as helicopters do.
can't wait to get the HD Quadcopter flying. This Hex is straining with the T2i and 10-22 lens.
To view the raw clip in 1080HD (recommended) go to the vimeo page and then on the lower right you can select to download the source clip.
http://vimeo.com/11448055
The smoothcam version of this clip is below. A setting of 0.4 was used with a total zoom in on the image of 103%
T2i on a Hexakopter with mkTR gimbal (1 min 16 sec)
Photoship One is offline Find More Posts by Photoship One
Old May 03, 2010, 07:46 PM
Coil is offline
Find More Posts by Coil
Coil's Avatar
Slovenia
Joined Mar 2008
Great video, what is total weight? Do you have pictures of hexa, what prop-motors combo.
Coil is offline Find More Posts by Coil
Old May 03, 2010, 07:54 PM
by Alary Design
Joined May 2002
go here and scroll down for pics of the Hexa used for this shot
http://photoshipone.com/ps1-products/multicopters/
Roxxy motors were used with 12x3.8 APC props on 4s3000 battery. I put heatsinks on all FETs on the ESCs.
It would not be recommended to fly a Canon T2i with lens (2.0lb) on a Hexa. I did this only as a test for our camera gimbal to see if vibrations affected the CMOS sensor in the camera. There were no vibrations. An Octo would probably be on with this payload.
Old May 05, 2010, 04:18 PM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
Nice video. Palm leaves suggest you didn't have any wind?
Over here we always have wind and vibrations can be a big problem with a suboptimal motor-prop-weight combination.
Arthur P. is offline Find More Posts by Arthur P.
Discussion Electric Heli for mounting a Canon T2i DSLR Robert Anthony Large Electric Helis 8 May 02, 2010 08:43 PM
Discussion Canon T2i/550D Video Flight Test jeffscholl Aerial Photography 5 Apr 14, 2010 10:48 AM
Sold Canon 70-300IS Lens DuaneV Non R/C Items (FS/W) 4 Mar 08, 2010 06:34 PM
Canon SD20??? under 5oz, fixed lens, video out, 5 mpxl - opinions? CactusJackSlade Aerial Photography 22 Apr 19, 2005 09:25 AM
