Old May 03, 2010, 12:59 PM
chuckinnc is offline
Find More Posts by chuckinnc
Joined Jul 2008
Help!
Maybe OT Scroll saw blades
I didn't know which forum to post this. I plan to do alot of scratch
buillt foamies and need to repair my broken gws models, I picked up a vari speed Craftsman 5" scroll saw at a local flea market this weekend.
It did not have any blades and when I looked up blades on ebay, well there are too many types out there. I need to cut thin aluminum, balsa & if possible
foam. So far Ive found spiral, skip tooth, reverse tooth, 46 t metal cutting, & size # 1-11, I need alittle help or sugguestion as to what would be best the blades for this hobby.
chuckinnc is offline Find More Posts by chuckinnc
Old May 03, 2010, 01:10 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
get a pack of these and see which work best
http://community.craftsman.com/Craft...ws?tab=details
RogueTitan is offline Find More Posts by RogueTitan
Old May 03, 2010, 04:24 PM
miniman is offline
Find More Posts by miniman
Joined Sep 2004
The more teeth on the blade the smoother it will cut, especially in thin materials. The narrower, front to back, the tighter the radius can be cut. Spiral blades allow you to cut in any direction without having to rotate the work piece. For plastic you may want to slow the speed down to keep from melting the plastic. RT's suggestion is a good one, buy a combo pack and see what works.
miniman is offline Find More Posts by miniman
Sold Ryobi variable speed scroll saw like new $80.00 Cloud Cruiser Aircraft - General - Miscellaneous (FS/W) 0 Oct 03, 2009 05:39 PM
Sold Craftsman Scroll saw variable speed soft start.($85.00) mtdoramike Aircraft - General - Miscellaneous (FS/W) 1 Oct 03, 2009 01:08 PM
Discussion Fine Blades for Dremel Scroll Saw aussie_flyer Australia 4 Mar 28, 2007 05:13 PM
Discussion Source for scroll saw blades and sandpaper jbrandon Sailplane Talk 0 Mar 11, 2006 06:34 PM
Scroll Saw Blades (Source in UK) Andycart The Builders Workshop 1 May 16, 2003 08:59 AM
