Old Jan 27, 2013, 11:44 PM
Casllab is offline
Find More Posts by Casllab
I'd rather be flying..
Casllab's Avatar
South Africa, WC, Cape Town
Joined Jul 2009
Originally Posted by aerofundan View Post
Although make sure to use at least a normal or even better a heavy duty extension!!! don't use parkflyer style extension on the esc because remember it is the one that provides all the power to the rx and servos! hope this helps
cool, thanks - will make sure I get a decent lead..
An update on my elevator / aileron issue. I checked the tx stick movement indicators and it's clear from that that this where the issue is coming from. I can see the aileron movement if there is even the slightest off-center movment on the stick when I move the elevator and it's the same on all my planes. The gimbles were upgraded some time back by the suppliers so maybe what is happening is actually acceptable and as it's been said, due to the large control surfaces it's just much more apparent on this plane. If I move the elevator and there's no deviation from the vertical centre on the stick the ailerons don't move. I think I can set the expo up which may help but how will this affect the fly characteristics of the plane?
Casllab is offline Find More Posts by Casllab
Old Jan 28, 2013, 12:34 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
70% expo is great on high rates. (The closer the curve is to horizontal at the centre, the less response you will have close to the neutral position)
demonGti is offline Find More Posts by demonGti
Old Jan 28, 2013, 01:14 AM
Casllab is offline
Casllab's Avatar
Joined Jul 2009
I already have the expo set to +75% and there's still some aileron deviation so I'm wondering if what I'm seeing is acceptable. Surely others here must have a DX7 on mode 2 ??
Old Jan 28, 2013, 02:36 AM
Casllab is offline
Casllab's Avatar
Joined Jul 2009
I think I just found the cause - the tension on the stick spring needs tightening, seems its quite a common thing afterall and is easily fixed. Cool!!! Gonna try it tonight. I'm almost a very happy camper..
Old Jan 28, 2013, 09:30 AM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
I think it would be interesting if there is any chance there is anyone close to you that has the same radio so you can make a comparison! as for spring tension, i can tell you i run very loose spring tension on my radio and i have no problems with elevator/aileron interaction around center. If there is any chance you can take your radio to a hobby shop or to a flying club for someone else to check, because it really doesnt seem normal to me.....
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Jan 28, 2013, 11:18 AM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I also like it loose.
It just sounds as if your thumbs are not moving on a straight axis and are accidentally deviating and inadvertently causing other control surfaces to move.
As Dan said, a side to side comparison could be helpful, or is there a local experienced pilot that might try your radio.
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old Jan 28, 2013, 12:47 PM
USA, GA, Atlanta
Joined Nov 2008
Is anyone else trying CF props on the Thrust 40 motor?
I am trying this one later this week when the weather clears. It is 14x7 as well, I am so excited to see the numbers...
Appears very thin and stiff.
Old Jan 28, 2013, 08:31 PM
Blucross is offline
Find More Posts by Blucross
Gravity is a cruel mistress...
Blucross's Avatar
United States, FL, Orlando
Joined Mar 2011
Interesting, looking forward to the results.
Blucross is offline Find More Posts by Blucross
Old Jan 28, 2013, 11:24 PM
Casllab is offline
Casllab's Avatar
Joined Jul 2009
I tightened the springs a bit last night and the issue is no longer. The sticks are a bit stiffer but not something that I think will be a problem. I've seen some guys at my club that have the same radio, when I see them again I'll ask if I can compare theirs to mine.
Old Jan 29, 2013, 04:37 AM
p91304 is offline
Find More Posts by p91304
Fly Till You Die
p91304's Avatar
United States, WA, Battle Ground
Joined Sep 2009
I tried that Aero Model prop and it was worthless no thrust at all. It would wind up good but didn't appear to have enough surface area or pitch.
You will find out. Can't beat the T40-X, plus wood is safer if you accidently hit yourself with the propellor.
p91304 is offline Find More Posts by p91304
Old Jan 29, 2013, 04:45 AM
p91304 is offline
Fly Till You Die
p91304's Avatar
Joined Sep 2009
I like to fly with two fingers and very light spring tension too.
Old Jan 29, 2013, 10:06 AM
USA, GA, Atlanta
Joined Nov 2008
Dang... will fly this weekend, but now with realistic expectations
Old Feb 02, 2013, 03:09 AM
p91304 is offline
Fly Till You Die
p91304's Avatar
Joined Sep 2009
Help Videos
Precision Aerobatics Wheel Axles (6 min 1 sec)
Precision Aerobatics Addiction linkage (2 min 46 sec)
Old Feb 02, 2013, 11:32 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Interesting video but I'm totally distracted by the small museum in the background there... nice collection
jasmine2501 is offline Find More Posts by jasmine2501
Old Feb 04, 2013, 10:12 PM
p91304 is offline
Fly Till You Die
p91304's Avatar
Joined Sep 2009
Did you try that CF propellor? I was wondering about your opinion of it.
Discussion Precision Aerobatics 58" Extra MX Official Roll Out Thread **New Video** hercdriver7777 3D Flying 5618 May 15, 2016 06:55 PM
New Product Precision Aerobatics Addiction X rcbirk21 3D Flying 235 Sep 01, 2014 07:10 AM
Wanted Addiction by Precision Aerobatics youace Aircraft - Electric - Airplanes (FS/W) 1 Mar 10, 2010 08:00 PM
Video Precision Aerobatics Addiction 3D Video hercdriver7777 Electric Plane Talk 13 Dec 26, 2009 10:35 AM
Discussion Precision Aerobatics Addiction -Aussie Made flying video dingfix Australia 26 Dec 02, 2007 03:38 PM
