Old Dec 06, 2012, 11:58 PM
bassman2914 is offline
Find More Posts by bassman2914
It's an addiction I wanted
USA, CO, Fort Collins
Joined Mar 2010
Don't feel bad, it's an easy mistake to make considering without being told you'd never be able to look at it and see that there's covering. I'm pretty sure the sealing strips they provided had covering but it's been a year since I built my Addiction X so I'm not 100% sure.
Try a razor blade or tape to try and separate the backing. Dragging your finger over a corner can sometimes put away the backing. (it's a real pain though)
bassman2914 is offline Find More Posts by bassman2914
Old Dec 07, 2012, 10:37 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Originally Posted by Casllab View Post
Hahahahaha There's backing on the covering ??? I didn't know that but then again this is the first time I'm using covering.
Lots of people dont realize this when covering their first plane; I certainly made the exact same mistake when I recovered my AddictionX, as it was the first time I had ever covered anything.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Dec 07, 2012, 10:39 AM
wgarman is online now
Find More Posts by wgarman
More Planes Than Sense
wgarman's Avatar
United States, PA, Wexford
Joined Feb 2010
Thanks for the BIG tip. I got the sealing strips to bind when I built the plane, but couldn't figure out why I could not get the roll of covering to bind when I did repairs later.
wgarman is online now Find More Posts by wgarman
Old Dec 07, 2012, 10:50 AM
USA, GA, Atlanta
Joined Nov 2008
I have done many more covering jobs since I first did my Addiction, and I have also found that the solid colors of covering are far easier to remove the backing. For some reason, the backing on transparent coverings put up much more of a fight to remove; but once you get a corner pulled back, the whole thing peals off with no problem.
Old Dec 07, 2012, 12:08 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Hahahahaha There's backing on the covering ??? I didn't know that but then again this is the first time I'm using covering. That would probably explain why such an apparently easy job didn't seem as easy. Oh boy, I feel like a bit of chop right now..
There wasn't any backing on mine, but it was pretty hard to figure out which was the sticky side. It sticks down ok, but I had to come and seal it with some CA after a season of keeping the plane in the car
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 07, 2012, 06:01 PM
dodlestonian is offline
Find More Posts by dodlestonian
Chester UK
dodlestonian's Avatar
Joined Mar 2006
separating covering and backing
The easiest way I've found to separate covering and backing is get to a corner, put adhesive tape on the covering and another piece of tape on the backing.
Then just pull the taps apart and the covering comes away with one tape and the backing comes away with the other. Works every time.
I reuse the same two bits of tape many times. I find that insulation tape works best for me :-)
dodlestonian is offline Find More Posts by dodlestonian
Old Dec 07, 2012, 08:04 PM
Rocket Programmer
Joined Jul 2007
An easier way is to grab the corner and rub it a bit with your fingernail, which causes the backing to wrinkle a bit and you can pull it up.
Old Dec 08, 2012, 02:50 AM
Casllab is offline
Find More Posts by Casllab
I'd rather be flying..
Casllab's Avatar
South Africa, WC, Cape Town
Joined Jul 2009
I am now even more confused.. I had a look at the stips of covering and coudn't see that there was anything to peel off. I did notice that one side was stickier than the other so tried ironing that side to the plane and guess what.. It worked.. So i've now easlily sealed all the gaps using the covering..
Only a few things left to do and then maiden!!
Casllab is offline Find More Posts by Casllab
Old Dec 08, 2012, 03:22 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
Good to hear you've come right.
Post a pic of your finished bird
demonGti is offline Find More Posts by demonGti
Old Dec 08, 2012, 09:16 AM
USA, GA, Atlanta
Joined Nov 2008
Last covering tip~ if the backing is off, and you are not sure which side has the adhesive; look at each side and the "dull" looking side has the adhesive on it and needs to be down on the plane. The shinny side goes on the outside.
Sounds like a nice maiden, I look forward to your thoughts as you get even more used to this ship.
Old Dec 09, 2012, 01:11 AM
USA, GA, Atlanta
Joined Nov 2008
I had my first day back flying today since my surgery (before Thanksgiving), it was fun to mash the sticks around a bit, but really just hot-dog huckin in the neighborhood! I always seem to forget that with all my tail weight (wires and LEDs), this ship requires solid back pressure on the elevator, about 1/4 stick, just to maintain level inverted flight without popping into a hover.
I thought my buddy Chris was just taking some photos, but he snuck a video of the first flight back I cant wait to get her back up tomorrow, I am going to wring this machine out!
However, I did have one glaring issue that has been irking me- ever since I had to move the 3s2650mAh flight battery, the 3s500mAh LED battery, and the ESC all the way forward (with an additional 49g of nose weight), I have have been unable to get the cowl on and still have access for battery changes.
Flying this way for the last year, it never seemed to bother me as I fly it mostly at night and it is unnoticeable, but today I decided it is time to start working on the cowling. I am not sure if I will modify the X cowl with magnets and a clamshell design or a side door, or if I want to fabricate something that would give me the room I need....
Anyway, here are some daylight photos and the vid. It really is amazing how drastic the LED visibility is once the sun is fully down, and how its only slightly noticeable during daylight/twilight... I snuck a few older pics from in the darkness for comparison:
Bradley Bauman - PA Addiction 12/8/12 - DFC-1 (5 min 35 sec)
Old Dec 10, 2012, 12:22 AM
Casllab is offline
Casllab's Avatar
Joined Jul 2009
I realised yesterday that I don't have the motor mount bolts and washers - can someone post a pic of what they look like so I can try source some locally? I don't know if I got them with the motor or not as I've had the motor out the box a few times and it's not impossible that I may have lost them without realising it..
Old Dec 10, 2012, 01:04 AM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
They should be in a little zip-lock bag inside the box, sometimes squashed at the bottom of the foam padding.
They are 3mm philips head machine screws about 8mm long, black in colour.
The four washers are also black, 8mm in diameter with a 3mm hole.
Old Dec 10, 2012, 01:08 AM
Casllab is offline
Casllab's Avatar
Joined Jul 2009
Nope, I checked and double-checked the box and foam, no sign of them anywhere. I don't recall ever seeing any black bolts anwhere in the kit.. Not serious though, I am sure I will be able to find replacements quite easily..
Old Dec 10, 2012, 01:20 AM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
The screws should be a pretty standard item at most hardware stores, but just make sure you get a bigger washer than the normal hardware stuff. The larger the area, the more the load is spread across the CF motor mounting plate.
I have used 3mm pop rivet washers in the past on other planes 'cause they have a nice large diameter.
Discussion Precision Aerobatics 58" Extra MX Official Roll Out Thread **New Video** hercdriver7777 3D Flying 5619 Jun 16, 2016 10:10 AM
New Product Precision Aerobatics Addiction X rcbirk21 3D Flying 235 Sep 01, 2014 07:10 AM
Wanted Addiction by Precision Aerobatics youace Aircraft - Electric - Airplanes (FS/W) 1 Mar 10, 2010 08:00 PM
Video Precision Aerobatics Addiction 3D Video hercdriver7777 Electric Plane Talk 13 Dec 26, 2009 10:35 AM
Discussion Precision Aerobatics Addiction -Aussie Made flying video dingfix Australia 26 Dec 02, 2007 03:38 PM
