Here's what I did on my GWS C-47 - Gone series with brushed motors
I not sure what the C-47 motors are, possibly the cheaper Mabuchi 380, but converting to series on 3s seemed to work quite well. |
I think Kev (who has pretty much given up flying) has a couple of 2s packs, so I might give him a bell and see what the numbers look like, just to satisfy my curiosity. |
Stamford, CT
Joined Oct 2000
Hi Leccy
Hmm, I think I'm getting the problem. Aren't the motors on that airplane in front of the snoot? In that case, you might as well go with a heavy motor. What about the Permax Turbo 450? That should help with the cg and give you something on the order of 400 watts under the hood using a 3s setup and swinging a 6.5 x 4 prop. Cheers, Sam |
I don't know if it is feasable, but you can bring your current draw down close to the original by slowing down the props with a 1.5:1 gearbox. Larry |
Good points all.
The props aren't Gunthers Bare, they are Grapuner 6x3 nylon props. Going down to much smaller props isn't really an option, they'd be lost in the cowls. Sam -I have several Permax T450s and have seen the sister model to this one - the HVP Beaufighter - fly on a pair of those on 8 cells. However as a long term fan of the 450T in my experience they really are current hungry beasts and would possibly be even higher in current draw than the 7.2V Sp400s. Larry - when you put it like that it's not surprising. I hunted round my multitude of boxes and have got some geared Sp 400s, but, of course not a pair with the same ratio. On balance it'll be better to strip out the brushed motor set-up and replace it with the pair of E-Power 2215/20 1200KV 25A Brushless Outrunner Motors that I got to do the job. |
Ray - that's right, they are in parallel. The harness is mostly inside the already built wings. I could desolder the wires where they access the wing and try a series set-up, but it'd mean a new ESC to take the high voltage of extra cells. None of my brushed controllers that are available will take more than 12 Nicds (3s lipo).
The battery situation is also very tight. To stand any chance of balancing, with a shorter nose than Charlie Drake, the Henschel needs the batteries as far forward as possible. The battery box just holds a 3000mah 3s1p pack, my 4500 3s1p pack won't fit. So it's not really an option to fit more cells and go series. |
| Thread Tools | |
| Discussion Twin Sp400 7.2V on 3s1p 2500 lipos? | leccyflyer | Power Systems | 10 | Dec 13, 2008 09:54 PM |
| 2S3P, 3S2P, Three 2S1P, or two 3S1P packs from 6 lipo cells | erashby | Batteries and Chargers | 3 | Aug 15, 2003 07:05 PM |
| 2s1p / 3s1p 1200 | jeddy11 | Batteries and Chargers | 2 | Jul 09, 2003 07:21 AM |
| F/S Kokam 1020 3S1P and 2S1P packs | Ted U | Aircraft - Electric - Airplanes (FS/W) | 3 | Jun 08, 2003 03:11 PM |
| What's the factory timing on FMA SP400s? | Steve Fehr | Electric Plane Talk | 2 | Feb 18, 2002 01:49 PM |
