Old May 03, 2010, 04:47 AM
Vernonia, OR
Joined Mar 2004
2.4GHz TX/RX with integrated patch.
Hello guys,
Here's something I've been working on that might interest those of you who like 2.4GHz video systems.
This is the first prototype, so the final rev may not look identical. But this is also a good time to make any requests before I order a batch of boards.
This system has 3 parts.
1. Three channel, 500mW Airwave-based VTx with integrated PS filters and switching power supply. Input voltage range from 5-24V. Integrated filters enable system to be powered from MAIN FLIGHT BATTERY with ZERO interference. The system connects to the main battery (3s lipo) through the included balance plug. Reverse-polarity protected. 28grams with antenna.
Hauntme13 is offline Find More Posts by Hauntme13
Last edited by Hauntme13; May 07, 2010 at 06:10 AM. Reason: CH. 4 is illegal in USA
Old May 03, 2010, 05:00 AM
Vernonia, OR
Joined Mar 2004
Part 2 is the 2.4GHz receiver.
This receiver uses the SMT version of the popular Airwave modules. Couple of innovations here.
First, built in circular-polarized patch antenna. Great reception regardless of TX orientation and no feedline loss! And WAY cheaper than buying a separate commercial antenna.
Second, 3 channel selectable, built in regulator and PS filter for clean video.
Third, NO MORE TANGLE OF WIRES! RX connects to your ground station using common, low cost ethernet cables. Video, stereo audio, and power combined on a single flexible cable. Twisted pairs ensure noise-free signals. Prototype video is using a 15 foot cable to connect the RX on a tripod to my groundstation.
(I'm currently working to get some vacuum-formed ABS enclosures made.)
Last edited by Hauntme13; May 07, 2010 at 06:10 AM. Reason: CH.4 is illegal in USA
Old May 03, 2010, 05:05 AM
Vernonia, OR
Joined Mar 2004
The third module is the ground station interface.
The RX connects via ethernet connector. 12V from your GS battery connects to the power plug and audio/video outputs through the RCA connectors. There is a power filter and a power LED.
Old May 03, 2010, 05:06 AM
Vernonia, OR
Joined Mar 2004
Here is first flight test on 5/2/2010! EDIT: recorded using AIPTEK MPVR. Camera is the $25 Sony ebay camera from this forum.
2.4GHz video system (5 min 11 sec)
Old May 03, 2010, 06:26 AM
Questionable judgement
bracky72's Avatar
Charles Town, WV
This looks really cool. Will you be producing and selling any?
bracky72 is offline Find More Posts by bracky72
Old May 03, 2010, 08:52 AM
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Wow, very nice.
I would like to know projected price for final revision?
Derek_S is offline Find More Posts by Derek_S
Old May 03, 2010, 09:41 AM
Joined May 2008
Nice work
What do you think the distance will be?
Is there a way to make the receiver divercity?
mark
markeydoo is offline Find More Posts by markeydoo
Old May 03, 2010, 01:47 PM
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
Originally Posted by markeydoo View Post
Nice work
mark
Yes, use the RCA output, plug directly into oracle. Repeat with side B of diversity.
aaron_gx is offline Find More Posts by aaron_gx
Old May 03, 2010, 01:53 PM
Vernonia, OR
Joined Mar 2004
To answer a couple questions,
Yes I will be selling these in sets. I'm setting up an initial batch of 50 sets. Once I get the prices of the parts nailed down I will give a ballpark price. I will say this, the system is designed to be low cost, great performance and easy to use.
To get the results like you see in my video, simply plug the camera into the TX and the TX to the balance connector of the main flight battery. That's it. If you have a mic, it plugs into the TX as well. The plane is a stock PZ T-28 with stock ESC and 72MHz radio (electron 6 rx). No external voltage regulators or filters were installed in the plane.
When weather permits (hopefully next week) I'll do a long range test with my twinstar.
@Mark: This can be used with an Oracle or similar diversity controller.
Old May 03, 2010, 02:45 PM
Canada, ON
Joined Jan 2009
Excellent, nicely done hauntme13
Martin Y is offline Find More Posts by Martin Y
Old May 03, 2010, 07:53 PM
Videopilot
Derek_S's Avatar
Joined May 2009
Sweet. I will be waiting for more details. Great job on your R&D projects.
Old May 03, 2010, 08:12 PM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Excellent! Very nice!
Looked like you were at your club flying field, how many Futaba and Spektrum 2.4 Tx's got turned on while you were flying?
Saw the odd glitch that looked like 2.4 Tx interference.
Oh... and when can we expect the 900mhz and 1.2ghz versions?
galaxiex is offline Find More Posts by galaxiex
Old May 03, 2010, 08:34 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Awesome!
Is your 900mhz poweramp be ever finished?
Hugeone is offline Find More Posts by Hugeone
Old May 03, 2010, 11:56 PM
Guilty of commiting aviation
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
That's way cool John! You should consider building a version of the interface that has two ethernet connections to go to two separate rx's to further simplify a diversity setup.
aaronredbaron is offline Find More Posts by aaronredbaron
Old May 05, 2010, 10:03 AM
Vernonia, OR
Joined Mar 2004
Alright guys, I just ordered almost all of the parts for 50 units. The Receiver and integrated patch will be enclosed in an ABS vacuum-formed case with molded-in tripod mount. The production version antenna elements will be brass. Units will be available for sale in about 30-60 days. Price still yet to be determined, but I will finalize that soon. Affordable performance is the priority. Once I establish price, I will start taking pre-orders by PM.
And along with this order is V2 of the 900MHz amp (since I blew up prototype #1 LOL).
Discussion How to Add 2.4GHz PATCH Antenna to Futaba 9CAP Tx with TM-7 Module? kevinhines Radios 2 Feb 07, 2011 12:17 AM
For Sale 2.4ghz Video system - 2 tx, High Res Camera, Patch Antenna- Sweet Deal!!!!! wac Aircraft - Electric - Airplanes (FS/W) 2 May 30, 2010 10:04 AM
For Sale RangeVideo 2.4ghz AV Rx with 8db patch antenna JonM Aircraft - General - Miscellaneous (FS/W) 0 Oct 26, 2008 03:04 PM
Help! Will a spektrum 2.4ghz rx work with a futaba 2.4ghz tx. simonslim Radios 5 Jul 02, 2008 10:11 AM
Sold JR X9303 2.4ghz TX. With R921 9 channel 2.4ghz rx and a 6100 end pin RX cryhavoc38 Aircraft - General - Radio Equipment (FS/W) 5 Dec 26, 2007 02:01 PM
