My FY-21AP from FPVflying is in Frankfurt now (80km from here). But no deliver today as we have a holiday here ![]() --- Thursday, June 03, 2010 Location Time 10 Processed at Frankfurt - Germany Frankfurt - Germany 08:09 9 Clearance processing complete at Frankfurt - Germany Frankfurt - Germany 07:38 8 Arrived at Sort Facility Frankfurt - Germany Frankfurt - Germany 06:51 Wednesday, June 02, 2010 Location Time 7 Departed Facility in Hong Kong - H K Heliport - Hong Kong Hong Kong - H K Heliport - Hong Kong 23:11 6 Processed at Hong Kong - H K Heliport - Hong Kong Hong Kong - H K Heliport - Hong Kong 22:10 5 Processed at Hong Kong - H K Heliport - Hong Kong Hong Kong - H K Heliport - Hong Kong 06:08 4 Arrived at Sort Facility Hong Kong - H K Heliport - Hong Kong Hong Kong - H K Heliport - Hong Kong 05:10 3 Departed Facility in Hong Kong - Hong Kong Hong Kong - Hong Kong 03:28 2 Processed at Hong Kong - Hong Kong Hong Kong - Hong Kong 03:28 Tuesday, June 01, 2010 Location Time 1 Shipment picked up Hong Kong - Hong Kong 23:08 --- M. |
Thailand
Joined Apr 2006
Fy21ap
The have the choice for you at your Tx stick
Up position = Normal fly Middle position = Fly with utilize stabilization function Down position = Return home Or you can return home by turn of you radio, and your radio set the failsafe to attivate Down position of you stick, this mean it will go to Return home function. |
My order status only shows one order, #47..... and one order tracking # which I presume is for the DHL order that I already received. (the FY20A) I click on track status..... and the page I get does not recognize the tracking # ![]() ![]() ![]() Copy/paste from order status page.......... Order #47 Order Date: 22nd May 2010 Recipient:************ This order is marked as Shipped You chose to ship this order with FPV flying------------------------------------------------- EDIT; ooops.... my mistake, I was able to get the tracking # to work. It seems my Skywalker plane is in customs... |
this is not correct,
One channel controls stabilzation, another controls the autopilot. stabilzation channel is either "off" "stabilize" or "stabilize and hold elevation" the other channel controls the autopilot so it is either "return to home" "off" or "circle at present point" so you set the second channels fail safe to return to home when you are doing your fail safe procedure and if you turn off the TX then it will come home. what is outlined below is not posible with this system (these three things on one channel) Quote:
Thailand
Joined Apr 2006
To make sure I am not out the toppic and I use the same system which the people now talking. This system we use it since the product lunch, it been long time now the people start talking here. So below is the picture of how it connect to each channel. ![]() I recently use it for our work at http://www.thaisky-digital.com |
this may be version one??? I am referring to version II which is outlined in the manual Hooks posted a link to... you need two RC switches to work this version....
I quit using my AR7000 years ago because of the need for more range ;-)
this is perfect then you can set that channel to fail as return to home. That channel will overide the stabiliaztion channel when selected so you need to only set the one channel and your throttle channel to fail to about 3/4 thanks for helping clarify! |
I had thought they were both shipped together. No problem, it's all good.
Fy-21ap ii
So basically what you are saying is that given my current setup (Spektrum Dx6i & AR7000) that if I was to lose signal and the "Failsafe" activated the "Return Home" mode on the FY-21AP II the following would happen. The servo's would lock in their last position and the FY-21AP flight stabilizer would not be able to override the receiver and provide/control stabilisation and heading, and depending on my last input I would sill watch my plane fly out of sight
| Thread Tools | |
| Question Using fma copilot ii with OSD-Pro? | RHash | Eagle Tree Systems | 15 | May 09, 2013 03:36 PM |
| Discussion Remzibi OSD (Poor Man's OSD) integration with ArduPilot | HappyKillmore | Video Piloting (FPV/RPV) | 539 | Apr 28, 2012 04:32 AM |
| Discussion best OSD with most features for the money? OSD product matrix here.. | markm75 | Video Piloting (FPV/RPV) | 66 | May 03, 2010 02:31 PM |
| Discussion Octocopter for aerial photography with - FPV - OSD - Head tracker | danielpetrescu | Multirotor Talk | 1 | Mar 26, 2010 02:30 PM |
| For Sale FY-22 Rapter EDF Jet | 3DTRYER | Aircraft - Electric - Jets (FS/W) | 1 | Mar 15, 2010 12:52 PM |
