Old Jun 07, 2003, 07:10 PM
TomL is offline
Find More Posts by TomL
Joined Aug 2002
Brushless speed control problem
The speed control that I am using with my Hacker C40 is not working correctly. It is a Jetti speed control that was provided with C40 when I bought the package.
The speed control works the motor fine, but after a slight amount of time working the control surfaces, it appears that powe that is going to the servos is depleted (servos work slowly, and eventually stop), but the motor control is still ok.
It almost seems like the voltage regulator is gong bad, if you stop working all the surfaces for a few seconds that surfaces will work ok, then fail slowly.
My battery is fully charged, and the speed control has been working fine for about 2 months.
Any ideas ?
Tom
TomL is offline Find More Posts by TomL
Old Jun 07, 2003, 11:09 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Are all of your control surfaces completely free from any and all binding? How about your your linkages, how freely do they move?
GregG is offline Find More Posts by GregG
Old Jun 08, 2003, 12:49 AM
TomL is offline
Joined Aug 2002
All the surfaces are free, as I said the plane has been flying fine for 2 months. The surfaces will function fine until you start moving all of them at once. While moving them all at the same time, and after about 5 seconds you can see them slow down then they will get to a point where they are moving so little that it looks as if you were to have a flight pack battery that the battery would be going dead.
I can also feel a component getting warm(real warm not to hot to touch) in the speed control under the heat shrink.
I think the voltage reg is slowly failing
Tom
Old Jun 08, 2003, 12:54 AM
electric-2000 is offline
Find More Posts by electric-2000
San Diego, CA
Joined Oct 2001
Servo problem
Tom,
Like Greg said, it still sounds like a servo problem. One of oyur servos is pulling too much current. Try this, unplug one servo and test again. If it still has a problem go to the next servo and try again. Repeat with all servos and one should show up as a problem.
electric-2000 is offline Find More Posts by electric-2000
Site Sponsor
Old Jun 08, 2003, 01:01 AM
ElectRick is offline
Find More Posts by ElectRick
Eye Drather Beef Lying
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
That kind of sounds like the problem some of the E3D guys are having with the BEC in the ESC being overworked by too much servo current draw and shutting down. Happens mostly during 3D flying, slamming/holding everything cranked over at extreme throws, sometimes stalling one or more servos. There is a section over in the second E3D building thread that this gets discussed. I had this happen to me a few weeks ago on my E3D and nearly lost the plane over it. I installed a UBEC, rolled my throws back a little bit, and have been trouble-free since.
Which Jeti ESC is it? Some of them are somewhat current limited for the BEC side.
Rick
ElectRick is offline Find More Posts by ElectRick
Old Jun 08, 2003, 01:04 AM
TomL is offline
Joined Aug 2002
Yup...it's in my E3D, and that is what is happening. The thing that I can't figure out is why didn't it do this from the beginning.
Tom
Old Jun 08, 2003, 01:11 AM
TomL is offline
Joined Aug 2002
I can't remember which Jetti it is, what is a UBEC ?
Tom
Old Jun 08, 2003, 01:22 AM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
You could also disconnect your ESC and use a Rx battery thru your amp meter to see what you are drawing, servo wise.
William A is offline Find More Posts by William A
Old Jun 08, 2003, 01:23 AM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
UBEC
http://www.koolflightsystems.com/ultimatebec.htm
Discussion GWS brushless speed control problem ridefst GWS (Grand Wing Servo) 17 Oct 25, 2006 04:11 AM
Dragon 35 brushless speed control Steve H. Aircraft - Electric - Airplanes (FS/W) 0 Aug 17, 2002 12:29 AM
Speed control problem for wattage crazy max Colt SAA Parkflyers 5 May 27, 2002 11:53 AM
Hooking up a Jeti Brushless Speed Control to a Jeti Pashor 15/4 motor. HELP!!! Rob R Power Systems 3 Jan 10, 2002 06:37 PM
Is this a speed control problem??? jshelton Power Systems 3 Dec 10, 2001 06:31 AM
