Old Jun 07, 2003, 06:41 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
APC slowflyer on an IPS A gearbox?
How the heck do you mount an APC slowflyer prop on a stock IPS-A gearbox?
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jun 07, 2003, 06:54 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
You'll need a 3mm prop adapter.
www.toddsmodels.com
www.ecubedrc.com
both sell them and offer great service.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Jun 07, 2003, 07:34 PM
William_Sidney is offline
Find More Posts by William_Sidney
William_Sidney's Avatar
RoundRock Texas
Joined Sep 2001
Re: APC slowflyer on an IPS A gearbox?
I used a piece of fuel tubing on the gear shaft. When the prop washer and nut are tightend down it compresses and holds the prop nicely
William_Sidney is offline Find More Posts by William_Sidney
Old Jun 08, 2003, 05:04 AM
Capt. Electron is offline
Find More Posts by Capt. Electron
Senior Moment Member
Virginia Beach, Va.
Joined Jan 2002
My method:
A 3mm locking nut goes on the shaft first to keep the assembly from turning.
A washer
A 3mm nut
The prop with adapter inserted
Another washer and nut.
Step one...... all the parts, and lock nut already on gearshaft.
Capt. Electron is offline Find More Posts by Capt. Electron
Old Jun 08, 2003, 05:05 AM
Virginia Beach, Va.
Joined Jan 2002
Ready for the prop...
Old Jun 08, 2003, 05:06 AM
Virginia Beach, Va.
Joined Jan 2002
All done.....
Jimmy
Old Jun 08, 2003, 07:52 AM
Tim Wolff's Avatar
Joined Sep 2002
Thanks for all the help. I knew I'd get a few choices if I posted it here
Old Jun 08, 2003, 02:51 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I'm lazy. Since the nice machined aluminum adapters specifically for this purpose aren't available any more, I use the parts GWS sells just for this. There are two suitable adapters in the package. Todd's Models and AeroMicro have them, among others. A picture can be seen on AeroMicro's site on this page:
http://www.aeromicro.com/Catalog/gws...1__1017350.htm
You do have to cut off the small end to get the prop nut fit tightly, though.
I don't know why this URL doesn't work if you click on it - somehow R/C Groups is adding some "%20" and such into it that aren't there, and then it doesn't work. The link is from about halfway down the "propellers, others" page on the AeroMicro site.
BEC is offline Find More Posts by BEC
Question Mounting an APC 8x6SF on a GWS 350C gearbox rrobbins Power Systems 1 Mar 31, 2005 03:50 AM
GWS Beaver on an IPS power system. pc_pilot Parkflyers 6 Jun 25, 2003 03:57 PM
Using APC prop on GWS 300C gearbox? akh223 Parkflyers 13 Jan 21, 2003 08:39 PM
GearBox on an IPS Motor Rogerdoger Parkflyers 26 Dec 16, 2002 10:39 PM
What type of oil should I use on GWS IPS gearbox and motor? The Other Dave Parkflyers 5 Jan 28, 2002 12:47 AM
