Old Aug 22, 2011, 11:45 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Some measurements, not accurate to the mm, but close enough
Wasp -
102mm from bulkhead to hook fwd recess.
95mm from hook to CG
CG is at 52mm
X -
190mm from bulkhead to hook
55mm from hook to CG
CG is at 54mm
Stiletto -
103mm from bulkhead to hook
90mm from hook to CG
CG is at 47mm
I really didnt experience a massive difference in the launch of the different planes, X has the furtherest aft hook and pulled up the least! Dont think the laws of physics have time to make a massive difference with the hosemonster bungee, they literally just get flung forward.
jackosmeister is online now Find More Posts by jackosmeister
Old Aug 23, 2011, 12:38 AM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Thanks Jacko!
Colin
wollins is offline Find More Posts by wollins
Old Aug 27, 2011, 10:01 PM
Auckland NZ
Joined Aug 2007
Heres a heads up for you guys pushing wasps/swifts hard.
Mine has hundreds of flights on it, well over a year old now, noticed some stress cracks forming around the aft radius's of the wing connector cutout.
This airframe sees some wicked Gs every flight, and these cracks are the only sign of the airframe starting to give way. Its in no way a defect in the wasp.
Increasing the size of the radius, and running some carbon tow on the underside of the area would be a wise idea. The cracks will eventually allow the wing bolt to rip out of the fuse.
Ill post some pic's of the repair later, but the cracks are circled in pen in the photo below
Old Aug 28, 2011, 03:00 AM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
Thanks for that, I'll take a look at mine.
wastegate is offline Find More Posts by wastegate
Old Aug 30, 2011, 03:25 PM
antoine is offline
Find More Posts by antoine
France, Île-de-France, Savigny-sur-Orge
Joined Nov 2005
All,
this plane is really nice. It is looking similar to the mini hawk from below link
http://www.modellhobby.de/Modelle/Fl...&t=3&c=31&p=31
Do you know where to buy it and at what price?
Cheers
Antoine
antoine is offline Find More Posts by antoine
Old Aug 30, 2011, 03:34 PM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Originally Posted by antoine View Post
All,
Cheers
Antoine
That is the Swift from launchmodels they are all made at the same factory in china adsold under diffnt names
http://www.launchmodel.cn/enProductShow.asp?id=150
have alook a this thread
http://www.rcgroups.com/forums/showthread.php?t=1490180
Cheers
Adrian
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Aug 30, 2011, 05:34 PM
Auckland NZ
Joined Aug 2007
How many names can this plane have! Its worse than the Hawk/F5B/Lanyu/Eagle 5!
Old Aug 30, 2011, 09:27 PM
QDRevenger is offline
Find More Posts by QDRevenger
QDRevenger's Avatar
New Zealand, Auckland
Joined Jun 2011
What ever the name, brilliant little plane . Same manufacturer, marketed by different distributors, must be a good thing that so many want to call it thier own. Can't wait for the weekend to let it loose again .
QDRevenger.
QDRevenger is offline Find More Posts by QDRevenger
Old Aug 31, 2011, 03:36 PM
Adrian_M is offline
Joined Dec 2010
QDRevenger.
Where you flying I might come along have a look
Old Sep 02, 2011, 01:44 AM
QDRevenger's Avatar
Joined Jun 2011
Probably the North Shore field, quite enjoyed it out there last weekend. Will maiden the Sundowner first , need to break her in .
QDRevenger.
Old Sep 18, 2011, 02:32 AM
Auckland NZ
Joined Aug 2007
Forgot to take photos of the fix for my cracking fuse.
Laid out some carbon tow, roughly 50mm long, stuck it down the center of some 1" fibre reinforced tape. Wetted out the carbon with some 30m epoxy and stuck it up and under the wing seat using the tape. Clean and easy
Old Sep 19, 2011, 02:11 AM
Auckland NZ
Joined Aug 2007
Wasp spoileron throws.
23mm up at the IB ends, no elevator compensation.
It pitches up a touch, nothing scary or un-controllable, just adds to the drag.
Got it set up on LH slider BTW, its easy to land it at your feet like this, dumps heaps of speed and lift and doesnt do anything nasty while slowing down.
Old Sep 19, 2011, 09:23 AM
Joined Nov 2005
Got a couple of flights in with mine this morning for the first time in ages. Launches were scary as usual but once the prop got a bite she was up and away. Wind was gusting at 20mph but that doesn't seem to affect this plane as it seems to go as fast against the wind as it does with the wind! I still cannot fly this plane close enough for doppler readings (too fast and too many obsticles) but it's as fast as I want to go and much quicker than anything else at the field. Two batteries through it and I need my inhaler
Old Oct 24, 2011, 02:57 AM
Auckland NZ
Joined Aug 2007
Mibo eWasps Eggbeating (1 min 41 sec)
Eggbeaters! X2!
Symphony of destruction seemed to fit well
Highly recommend reinforcing the wing saddle as above before trying
Old Oct 29, 2011, 10:14 PM
Auckland NZ
Joined Aug 2007
After having too much fun playing eggbeaters..
My elevator servo decided to jam at high rates, full up. Flat spun into the dirt, SPLAT. Fuselage is toasted.
Anyone got a spare fuse?
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
