Old Mar 06, 2013, 04:04 PM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
what happened? Dumb thumbs?
wollins is offline Find More Posts by wollins
Old Mar 06, 2013, 06:12 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
Much more dramatic than my last loss...I just flew out of range..still haven't found it.
What was the setup? Looked like it was moving very well..
stanordave is offline Find More Posts by stanordave
Old Mar 06, 2013, 11:11 PM
SuperEfly is offline
Find More Posts by SuperEfly
Joined Feb 2013
Hi Dave, I just happened to be there with my vid camera It was moving along
not sure of the setup
SuperEfly is offline Find More Posts by SuperEfly
Reply With Quote  (Disabled)
Old Mar 07, 2013, 12:20 AM
stanordave's Avatar
Joined Jan 2006
oh well...thanks..
Old Mar 07, 2013, 02:02 AM
QDRevenger is offline
Find More Posts by QDRevenger
QDRevenger's Avatar
New Zealand, Auckland
Joined Jun 2011
Yeah pretty dramatic, that was it's second flight. Setup was Hyperion HS-3026-1600kv motor with a 6 x 10 Carbon Folder setup (DUP's special) on 5S. 3 + 2 2250mAh 65S Nano-Tech lipo's. YEP 100 ESC. This setup didn't seem that fast while I was flying, but now seeing the vid it does look pretty quick. There are a few pics on post #867 on page 58 of this thread.
Nah, not dumb thumbs, I was still getting used to the plane, it really hauled out of that last turn, heading towards me I lost it visually for a split second, tried to correct it but not in time. In hindsight I should have buttoned off But hey st happens, I'm over it, looking forward to building another one.
QDRevenger.
QDRevenger is offline Find More Posts by QDRevenger
Old Mar 07, 2013, 03:06 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
QDRevenger to bad about the plane,,,
do you have any clue about the ampdraw with hat setup ?
sebbe is offline Find More Posts by sebbe
Old Mar 11, 2013, 03:39 PM
QDRevenger's Avatar
Joined Jun 2011
Hey Sebbe, I am guessing around 130 - 140A, I have an Eagletree logger but I was more excited to fly the plane than solder the new connections to it
If I was to do it again (which I probably will at a later date) I would use the 1400kv motor on 6S and maybe a pitchier prop. I couldn't fit 6S with the 2250mAh lipo's I had, 5S just fitted.
QDRevenger.
Old Mar 11, 2013, 04:19 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
130-140 amps, are you sure.I Think I read jacko tried the same prop and measured static amps to like 55-60 with a 1400kv motor and 5s lipo, dont think another 200kv should raise the amps from 55-60 to 130-140....
Im asking as I am trying to get a hint of what kv to use with that prop and 5s lipos..
Old Mar 11, 2013, 04:22 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
here are the numbers
创创创创创创创创创创创创创创创创创创
Scorpion 3026-1400
CC125 5 degrees timing in outrunner mode
5S 1800 65C turdigies
Tested kV - 1428
6x10 DUP Folders -
25531 rpm (242mph pitch speed )
1115W
56.77A
19.5V
Old Mar 11, 2013, 04:24 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Remember mine are on a 32mm RFM spinner sebbe, so its a 5.5" prop will make a solid diffence.
jackosmeister is online now Find More Posts by jackosmeister
Old Mar 11, 2013, 04:32 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
jacko, i know, still the 80-90 amps more seems to much....even twice the amps like 110 would be almost to much to I think...
32mm spinner compared to 38?, thats only 6mm more diameter, and 172kv/volt more,,,, all we know is that your numbers are correct, the other numbers from QDRevenger is just a guess... still think he is in the 100 amps region... no more..
Old Mar 12, 2013, 01:28 AM
jrandle is offline
Find More Posts by jrandle
Sydney, Australia
Joined May 2005
Hi Sebbe,
Is yours motor actually a Scorpion 3026 -1400kV or or a 3226-1400kV ?? The 3226 series motors seem to be about 40grams heavier than the 3026 series, as well as being a bit bigger all around.
I can't seem to find mention of a 3026-1400 anywhere !!!! Ok.....just found it. Thy have discontinued it
Are your numbers static or in the air ??
Have you measured the speed in flight, as the pitch speed seems pretty good for only 1100W input.
Strangely enough, I seem to be getting very high percentage of the pitch speed with my 4.75x4.75 setup. Maybe somebody else has some thoughts on this ?? Obviously it varies with types of model, but I would be interested to know for F5D type models.
Jag
jrandle is offline Find More Posts by jrandle
Old Mar 12, 2013, 02:19 AM
Auckland NZ
Joined Aug 2007
Motor is a 3026-1400, its a pity they discontinued them the 3226 are big lumps in comparison.
They are still available though
http://www.aircraft-world.com/shopexd.asp?id=4637
http://www.aircraft-world.com/shopexd.asp?id=3795 ( or in blue )
Numbers are static, pitch speed isnt accurate, pitch of prop reduces when run on smaller diameter centre peice ( ie its physically only a 5.5" diameter)
I just went through and worked out the theoretical pitch, to reduce the comfusion
DUP 6x10 on RFM 32mm spinner is a 5.5x9.16 prop.
25531rpm = 222mph pitch speed.
What percentage of pitchspeed are you seeing? Is this using inflight rpm or static?
Old Mar 12, 2013, 08:22 PM
jrandle is offline
Sydney, Australia
Joined May 2005
Hi Jacko,
Thanks for the links. I had not realised that the Hyperion HS series is a rebranded Scorpion !!
My inflight average RPM (according to Castle ) was 42,280 on the APC 4.74x4.75C once up to speed. This is on the flight where I was regualrly radared at 300km/h with a peak of 308km/h. I had thought I was flying the pylon course but I now know I was going long on pylon #1 so was flying bigger, and thus getting a longer straight to accelerate in.
According to my trusty HP this leads to 85.02m/s or 306km/h
So, I now have absolutely no idea what is going on with this
All suggestions gratefully recieved.
Jag
Old Mar 13, 2013, 09:00 PM
BulletMaster is online now
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
hey... I have a HK 3026-1400KV motor here... might makeup the spare Reverb fuse with this motor and a set of DUP 6 x 10 folders....
BulletMaster is online now Find More Posts by BulletMaster
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? Andr閟Mtnez High Performance 27 Jun 20, 2005 09:21 AM
