Old Jun 20, 2011, 07:02 AM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
Maidened today and it flew flawlessly as expected but it was nowhere near as quick as I expected, maybe 100mph if I'm lucky. It makes the right noises in the air but just doesn't seem to have the drive so maybe I need to step up to a 6 inch prop. I think the Graupner 5.5x5.5 is not a good prop as I had a similar thing with it on the same setup in my funjet. I'll try an APC 6x4 first and then a 6x5.5. Because the motor doesn't get much air through, it was also very hot!
wastegate is offline Find More Posts by wastegate
Old Jun 20, 2011, 07:37 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Glad it fly's nice man, sound slike ya need a bigger mega
That link you posted before has me right confused.
http://www.launchmodel.cn/enProductShow.asp?id=150 Swift - New Version Wasp.
http://www.launchmodel.cn/enProductShow.asp?id=149 Hummingbird - Old version Wasp
http://www.launchmodel.cn/enProductShow.asp?id=165 Clash R - Wasp Wing
Im sure mine has a NAN/Mibo models tag on the inside of the fuselage somewhere, but maybe theyre all made in china! And if they are, the best chinese moldie ive ever seen.
And this looks very interesting http://www.launchmodel.cn/enProductShow.asp?id=164
jackosmeister is offline Find More Posts by jackosmeister
Old Jun 20, 2011, 01:32 PM
Joined Nov 2005
Well all I can tell you is that mine is exactly the same as yours but mine was made by, and sourced from, Launch models in China who also make the Hawk F5B. This model is also branded as the Mini-Hawk in Germany. It looks to me like Mibo just rebranded the same plane!
What Mega would you suggest for use with 4 cell and a fixed prop?
Old Jun 20, 2011, 04:27 PM
Auckland NZ
Joined Aug 2007
A 16/30/1.5S would be interesting on 4S with a 6x6 graupner speed ~1000W ~30k rpm, with headroom too push it harder than that too.
But I think this would be cool to try
http://www.rcgroups.com/forums/showt...53406&page=121
Old Jun 21, 2011, 08:09 AM
Mr Abe is offline
Find More Posts by Mr Abe
Vasteras Hasslo, Sweden
Joined Sep 2003
Originally Posted by wastegate View Post
Maiden tomorrow so thought I'd better take some pics just in case!
Wastegate, nice spinner. Is it a Pelikan 35mm?
Do you know where to buy them?
I need one for my Mini-Hawk and one for my HK E-speeder.
Im running a Feigao 380 8L 3613KV in my Mini-Hawk
600W on a GR 4.7x4.7 3S
Regards
Anders
Mr Abe is offline Find More Posts by Mr Abe
Old Jun 21, 2011, 08:48 AM
Joined Nov 2005
Here you go. Although it shows silver spinners, I was sent a red one. Actually, I ordered 3 different ones and they all were red.
Old Jun 22, 2011, 08:34 AM
Mr Abe is offline
Joined Sep 2003
Thanks for the link.
I orderd the 35mm spinner from Giant Cod about a year ago and received a silver spinner.
But its way out of balance,I cant use it.
Maybe the red spinners are better.
I would like to try a red RCM Pelikan 35mm spinner, but I cant find them in any online store.
/Anders
Old Jun 22, 2011, 01:35 PM
Joined Nov 2005
All 3 of mine are fine but I did have a vented Pelikan one that was useless as the thread was so soft it stripped instantly.
Old Jun 22, 2011, 02:51 PM
Mr Abe is offline
Joined Sep 2003
Thanks for the info about the Pelikan spinner quality.
I will order the Giant Cod spinners again, and hope to get the good red spinners.
/Anders
Old Jun 23, 2011, 06:06 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
jackosmeister,
Rimripper in Canada has been flying his Multiplex Fun Jet with MEGA 16/30/1.5SEC which has just 5% lower KV or so (due to "E" rotor) as compared to your mentioned 16/30/1.5S above.
C means Combat shaft (5mm).
He has been flying it on 4S and was looking to put on the Graupner CAM 6X6 among other props. Mean while he played with APC Pylon 6.5X5.5 and similar props and was Dopplered at about 147 MPH in level flight...no dives.
He already has a 5S ready to go (has some static data), but first wants to see 150 MPH on 4S.
ICE ESC has been logging his flights.
His data can help you make a closer approximation for your needs.
Your airframe is much more aerodynamic.
Keep in mind that he is in much cooler climates than most folks.
Tell him I said Hi and that you are a friend of mine...he'll help.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jun 24, 2011, 02:05 PM
Joined Nov 2005
Fitted a Het 2w-25 (2720Kv) today with an APC 4.75x4.75. Getting 55 amps and over 800 watts on the meter so that should give some sprightly performance. Its sounded pretty evil spinning up in the garden! The motor came with a finned heatsink which I haven't fitted but maybe I should?
Old Jun 24, 2011, 11:14 PM
Auckland NZ
Joined Aug 2007
Id fit the heatsink, it wont harm it!
Be interesting to see how fast a pylon prop pull the wasp. How hard have you tried to turn the wasp yet? Pulling 130mph turns in about 1m radius is one of the coolest things it can do
Im still happy as pie with my 16/25/2.5S on 3S with 8x7+5's in the wasp, suits the wasp perfectly. Does around 120-130mph flat out, folding prop means its slippery in a glide, and I can get 6minutes of flying with lots of throttle, well over 10minutes if less throttle happy.
Old Jun 25, 2011, 01:56 AM
Joined Nov 2005
I've done a few hard bank and yanks and it's turning capability is pretty scary but it's energy retention with power off is far beyond anything else I have. Initially I thought I had a problem and the plane was still on partial throttle as it whizzed by but it wasn't!
By the way, pitch speed should be up around 160 mph but whether it has the thrust to match remains to be seen!
Old Jun 29, 2011, 04:47 AM
Joined Nov 2005
Tried the Het 2w-25 today and all I can say is "OMG! It works and works well". Based on my Dago (which was clocked at 120mph) and flying them back to back I would say the Wasp is doing over 130mph, maybe 140! It is definately quicker and by some margin but what I like most is that shriek of the prop at full whack Motor came down hot so time for some heatsink compound and refit the heatsink.
Old Jun 29, 2011, 07:06 PM
Auckland NZ
Joined Aug 2007
Damn! Need video
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
