Old Feb 10, 2013, 12:59 AM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Is that good or bad, BM? How fast did it go? Interested to see how those blades went from a pilot's perspective....
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Feb 10, 2013, 02:07 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
Speed seemed around the same as the graupner cam prop - 5.2 x 5.2
Temps up a bit... but pushed the pack a little far. 61 degrees for battery, 67 degrees for motor. Used around 1400 mAHr out of 1800 pack.
Alloy turbo Spinner worked better... just wish the yoke was smaller.. might have to look at making a unit myself.
I had a cam there, but forgot to use it... will do so next time I head down...
BulletMaster is offline Find More Posts by BulletMaster
Last edited by BulletMaster; Feb 11, 2013 at 07:28 AM. Reason: forgot about the cam bit..
Old Feb 10, 2013, 04:22 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
I have a Mega 16/45/1.5 RCE planned for one. Specs are 1985 kv and 200g...a wee bit heavier than the Dr. Mad but it has a 5mm shaft (that is the "C" for combat) which adds 10g over a 3.17mm. 6 pole too so hopefully a tad more torque so it can spin a Graupner 5.5x5.5 fixed prop. I just need CHY to finish so my planes arrive.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Feb 11, 2013, 01:28 PM
Dr.Tom is online now
Find More Posts by Dr.Tom
Youtube: TomRi25
Dr.Tom's Avatar
Croatia, City of Zagreb, Zagreb
Joined Aug 2010
Originally Posted by Arcteryxxx View Post
Nice, Tom! Hope you can report about how those Tgy servos work for you.
I suggest you apply some bright color to the top of the wing. Vinyl tape, paint or whatever doesn't matter, but unless you have the eyes of a Hawk(intentional) you gonna need some bright colors to make the visuals better for orientation.
Maybe it's the old man flying for too long in the snow syndrome, but hey! The all white wing gets lost flying inverted in a cloudy sky. I'm sure you don't want that....
Thnx for the tip,
but luckily I have 10/10 vision and can fly small planes without markings very very far away,
me163 80cm gps locked over 800 meters/310km/h
http://www.rcgroups.com/forums/showp...&postcount=618
but once I get to that point, flying it,
it's all downhill and plain fun,
I hope servos will hold up to the task, and motor/prop combo will work ok on 4s.
I don't have 5x5 for now, only 4.75x4.75 so it won't fly as fast as i would like it to, but at least the amp draw will be smaller so batt. will cycle in properly
Dr.Tom is online now Find More Posts by Dr.Tom
Old Feb 11, 2013, 02:09 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Didn't the 5x5 APC used to be thought of as a poor prop? I know I've mentioned it before but it's been a while and can't remember what was actually said. I'm not sure if it was mentioned in the old FJ thread?
feefo is offline Find More Posts by feefo
Old Feb 11, 2013, 02:16 PM
Youtube: TomRi25
Dr.Tom's Avatar
Joined Aug 2010
great news since I have a bag of 4.75 from previous 2w20 driven planes...
about 5x5, I think I saw it recommended somewhere (even here maybe) for 2w25 (2660 KV) 4S pylon use combo
Old Feb 11, 2013, 03:10 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Yes it's recommended but I just remember it being said it wasn't a particularly good prop, maybe inefficient compared to others? I'll have a look and see what I can find later as it's bugging me now.
Old Feb 11, 2013, 05:23 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
I can't find the thread/post I read waaaay back about the 5x5 (pretty sure it was in the original FJ or maybe Stryker thread) but I did find a small thread on it.
http://www.rcgroups.com/forums/showt...t=5x5+ineffici
Seems my memory isn't too bad , the 5x5 might not suit certain airframes, draggy foamies being 1 of them, but seems it's good for slippery airframes. Posts 3 and 12 explain a bit more.
Old Feb 11, 2013, 06:18 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Feefo,
This might be something other than what you are trying to find....but:
Some guys claimed APC 5X5 not being as good as other similar sized props.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Feb 11, 2013, 06:58 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Yeah that's what I remember being said, but it was a while since I read it so I wasn't 100% sure.
Old Feb 13, 2013, 09:57 AM
fishboy77 is offline
Find More Posts by fishboy77
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Dr. Kiwi has done tons of prop and motor tests here on RCG and he has always maintained that the 5x5 is garbage. But his opinion is based 100% on his static tests - he sees pretty poor static thrust compared to watts in. Lots of people have argued with him that in the air, the 5x5 does just fine.
fishboy77 is offline Find More Posts by fishboy77
Old Feb 13, 2013, 11:40 AM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
My biggest concern about the APC is the lack of material around the hub. The Aeronaught has an option for 8mm prop adapters and the hub is very solid.
Old Feb 15, 2013, 05:51 AM
Chillaxin dude!
Joined Apr 2003
Video of yesterdays flight... please excuse the language at the end... deployed spoilers before I had straightened for approach & lost roll authority... mad switch flipping occurred!
Not the clearest video... lens was a little dirty and some zoom would have been nice... it's only a cheapie KeyChain cam, velcro'd to my sunnies! Watch in HD for best results
This is HK Dr MadThrust motor on 5S1800 Zippy with Ice 100A ESC and DUP 4.75 x 6.2 CF folders.
Reverb Flight (2 min 8 sec)
Old Feb 19, 2013, 06:45 AM
Chillaxin dude!
Joined Apr 2003
Video of J Randle's HK Reverb with cheapie HK motor on 5S..... watch in high def!
Top Speed of 308 Klm/Hr!!
Reverb1 (0 min 48 sec)
Old Feb 19, 2013, 06:50 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Yeah!!!!! Nice, BM!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 05:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 02:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 09:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 08:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 10:21 AM
