Old Jan 29, 2013, 04:26 AM
jrandle is offline
Find More Posts by jrandle
Sydney, Australia
Joined May 2005
Hi Guys,
I was scouring the internet for possible motors for this aircraft with a Kv a bit lower than the 2630 that I am currently running on 5S with a 4.75x4.75 prop. I would like to run a bit bigger prop at a bit lower RPM for hopefully more efficiency.
I came across the EFlite BL32 Ducted Fan Motor, 2150Kv.
Type: Brushless Inrunner
Size: 32-size for Ducted Fans
Bearings or Bushings: Bearings
Wire Gauge: 14 AWG
Voltage: 14.8V - 22.2V
RPM/Volt (Kv): 2150Kv
Resistance (Ri): 0.026Ω
Idle Current (Io): 2.6A @ 20V
Continuous Current: 62A
Maximum Burst Current: 75A
Cells: 4S-6S Li-Po
Speed Control: 80A
Weight: 5.70 oz (162g)
Overall Diameter: 1.10 in (28.0mm)
Shaft Diameter: 0.20 in (5.0mm)
Overall Length: 2.00 in (52.0mm)
So, my question is has anybody run one of these in a plane like this....or even thought about doing it ?? I actually have one in a Habu 32 EDF and it certainly handles the power that they say it will, the bearings seem good, it is pretty reasonably priced for this type of motor etc etc.
Jag
jrandle is offline Find More Posts by jrandle
Old Jan 29, 2013, 03:41 PM
fishboy77 is online now
Find More Posts by fishboy77
In search of RC nirvana
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
If efficiency is what you are after than I wouldn't be considering an Eflite motor. I could be wrong but you just don't see much discussion of those motors in high power applications. Check out the Mega 16/30/2 which is about the same size and Kv and can likely handle a lot more power than that Eflite motor. Just my $0.02.
fishboy77 is online now Find More Posts by fishboy77
Old Feb 06, 2013, 04:34 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Originally Posted by Arcteryxxx View Post
Would be nice if everyone who has got a setup to recommend posted the specs and backed it up with a video...
Geared drive:
Got a 4400kv Scorpion (HKII 2221-6) mated with a KPG25 5.2 gearbox. Oh man that motor can deliver!.....
Do you have any 3S numbers for this setup?
Im thinking of putting my wasp of a diet, go back to a 3S 1800 setup. The 6s setup is fast as, but I really dont think thats what wasps are about Want to go back to a more flicky hyperactive (ie lightweight) setup.
Tempted to try a 2221-6 5.2:1 on 3S with the rfm 14.5x14s (trimmed to fit)
jackosmeister is online now Find More Posts by jackosmeister
Old Feb 06, 2013, 11:27 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
I can rig a test for you, if you give me a couple of days. eCalc seems to be pretty accurate with the Scorps, so check it out for some pointers.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Feb 07, 2013, 04:57 AM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
Datas from Andy Reisenauers HP:
3s - 11V - 14,5x14, 7200 rpm,114 Amp.1255 Watt, Schub 5026g, Eta 69,0% max. 5-8 Sek.
This is with 5:1 GB,you will get some lower numbers due to the slighly different gearboxratio.
Eta is a bit low static but will rise when Motor unloads.
If you dont have the KPG in your shelf, maybe the Reisenauer ME NL 5:1 could be an option, you could save another 35-40g, which is almost the weight of 1cell!
Yello
Mreyello is offline Find More Posts by Mreyello
Old Feb 07, 2013, 08:07 AM
miche is offline
Find More Posts by miche
miche's Avatar
Joined Oct 2008
Scorpion 4400kv HKII 2221-6, Reisenauer 5:1 GB, lipo Rhino 3S 1850mah 40C
Static test: @ 1250 meters ASL
- GM prop 9x21.5, current:50amp, rotational vel.: 8125rpm
- AJ AeroModel Prop 10x19, current: 70amp, rotational vel.: 7400rpm
miche is offline Find More Posts by miche
Old Feb 07, 2013, 03:03 PM
Arcteryxxx's Avatar
Joined Feb 2010
My sporting setup is with the 2221-6, KPG5.2, 4S1800 and RFM 10x17. About 100A and 1400W turning the prop at 10400rpm. I use the RFM 12x17 to get real hot and it draws about 135A on 4S.
Graph of the 10x17:
Old Feb 07, 2013, 05:00 PM
Auckland NZ
Joined Aug 2007
Cheers guys.
Am looking in the bits box, have unused kpg25 4.2 here. A Reisenauer would be cool though (really need to try one of those things )
69% eta is pretty heavily loaded.
Maybe I should go lighter. Reisenauer 5.1, 2213-14, that would be ~800W and 60+ grams lighter than a 2221/KPG setup. Lower performance than the bigger motor, but 800W is still going to heaps of fun in a wasp.
Hmmmm
Old Feb 08, 2013, 02:42 AM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
Jacko,
If you think about new motor and new gearbox you may also have a look at those Peggy Peppers 2221-with higher KV:
http://www.reisenauer.de/artikeldeta...1525&sprache=2
I also would prefer a 12x17 RFM, at light planes it would give a much better climbrate than the 14,5x14
Yello
Old Feb 08, 2013, 04:11 AM
Arcteryxxx's Avatar
Joined Feb 2010
Cheers guys.
Hmmmm
I wouldn't build it too light either, as the plane is not the most streamlined in the world and looses speed rapidly while gliding. My setup is 990g and I would not have it any lighter than that because of the speed retention issues.
Old Feb 09, 2013, 06:04 AM
Dr.Tom is offline
Find More Posts by Dr.Tom
Youtube: TomRi25
Dr.Tom's Avatar
Croatia, City of Zagreb, Zagreb
Joined Aug 2010
is 50mm from LE correct CG for HobbyKing Reverb ?
my build is slowly coming to an end...
Dr.Tom is offline Find More Posts by Dr.Tom
Old Feb 09, 2013, 03:43 PM
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Looking good! The range seems to be from 50 - 55 mm. I'm at 52 and like it.
Old Feb 09, 2013, 04:15 PM
Arcteryxxx's Avatar
Joined Feb 2010
Nice, Tom! Hope you can report about how those Tgy servos work for you.
I suggest you apply some bright color to the top of the wing. Vinyl tape, paint or whatever doesn't matter, but unless you have the eyes of a Hawk(intentional) you gonna need some bright colors to make the visuals better for orientation.
Maybe it's the old man flying for too long in the snow syndrome, but hey! The all white wing gets lost flying inverted in a cloudy sky. I'm sure you don't want that....
Old Feb 09, 2013, 10:17 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Looks good.
Not sure how much (if you have at all) spolierions set up for landing, but you want them 2 or 3 times more up alieron than you are showing in that picture if possible. Helps slow it right down without being unstable at all.
Will fly fine without of course, just means a longer landing run.
+1 on interested to hear about those servos.
sykotic is offline Find More Posts by sykotic
Old Feb 09, 2013, 10:39 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
Flew the Reverb fitted with Dr MadThrust 2200KV motor and DUP's 4.75 x 6.2 folder today... 5S 1800 Zippy lipo
Section of the graph from the flight:
BulletMaster is offline Find More Posts by BulletMaster
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
