Old Mar 20, 2011, 08:19 AM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
Nothing wrong with that video, I think your girlfriend did very well to keep up with it
Looks like everything I was hoping for in this little plane and that wing must be strong to take some of those moves! Mine should be here in a couple days so I need to get ordering servo's.
wastegate is offline Find More Posts by wastegate
Old Mar 21, 2011, 03:29 PM
Joined Nov 2005
Well mine's arrived and I like it a lot
Quality of the fuselage, wing and h-stab is pretty damn good and there's plenty of room in the fuselage for what I intend to install. The only criticism I have is that the wing bolt hole is about 1mm off to the side of the centreline of the wing which means the wing ain't square to the body and I like things square and true! I'll fill it with epoxy and re-drill it. Need to get ordering the servo's now.
No point in me posting pics as mine is exactly the same as Jacko's.
Old Mar 21, 2011, 10:30 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Weird on the hole being off line. Id triple check that it is before shifting it
What power system are you planning?
Ive been tweaking the throws and CG over the last hundred plus flights, it feels pretty near perfect. Got a slight down throttle to down elevator mix too from memory. Ill post em up if your interested.
jackosmeister is offline Find More Posts by jackosmeister
Old Mar 22, 2011, 03:25 AM
Joined Nov 2005
My 2200mah 4 cell 30-40c batteries slot in nicely although the ESC placement could be an issue. I'm thinking HS65's in the wing but at 12mm wide I'm not sure if they're too wide for the tail. May go for an SD150 in the tail instead. Rx will be a Spekky 6200.
Old Mar 22, 2011, 04:17 AM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
I have metal geared digital MKS DS470 servos in my E-Wasp.
danger_mouse is offline Find More Posts by danger_mouse
Old Mar 22, 2011, 04:38 AM
Auckland NZ
Joined Aug 2007
Sweet, If i built mine again id use MKS DS450's all round too.
I have hyperion DS09's in the wing and an HD2212MG on the elevator, id expect an HS65 would fit in there easily though.
I measured up my wasp, outta curiosity, and its square, you musta got a friday arvo one
These are the throws in using at the moment, with a solid amount of expo as it very maneuverable, particularly at speed!
Spoilers 24mm up @IB edge
Aileron 22mm up, 9mm down @IB edge
Elevator 5mm up/down @centre
Throttle-Elevator .5mm up at full throttle @centre.
CG @ 52mm from centre LE.
Landings are a walk in the park compared to a speed400 pylon, its quite easy to drop it at your feet, with the spoilerons up it bleeds speed and lift quickly.
Old Mar 23, 2011, 02:27 PM
Joined Nov 2005
Wing is sorted so should get some work done this weekend. The motor mount is not a particularly positive fit so I'll need to fettle it a little.
Old Apr 03, 2011, 11:42 AM
yipwssg is offline
Find More Posts by yipwssg
Singapore
Joined Oct 2008
Hello,
about your setting :
Are you sure ? I don't think the throw is able to set more than 10mm. can you verify again ?
yipwssg is offline Find More Posts by yipwssg
Old Apr 10, 2011, 05:05 PM
Auckland NZ
Joined Aug 2007
Sorry been out of town for last few weeks, the numbers are right. Can post a pic if your still having trouble.
Old Apr 11, 2011, 01:32 PM
Leopard is offline
Find More Posts by Leopard
Si
Joined Aug 2004
Leopard - Any idea on how many rpm your getting out of the turnigy motor with your 11x10?
Sorry guys for late reply...
Today a measure the max. rpm with Turnigy tachometer. 8500 with Aeronaut 11x10 prop (Turnigy 3542-1250kV).
Leopard is offline Find More Posts by Leopard
Old Jun 18, 2011, 03:47 PM
Joined Nov 2005
I finally got around to building my E-Wasp today and everything went together very nicely due to the very good quality of this plane. The elevator linkage was a little fiddly but not a big deal with a little planning and thought. I have used a Mega 16/15/4 on 4 cell 2200mah batteries with a Hobbywing 60A ESC and Graupner Speedcam 5.5x5.5 as I wanted to set it up for some pylon style flying. Everything fits in nice and neatly as the fuse is just perfect for 4 cell batteries. Pitch speed is around 140mph so I'm hoping for around 120mph straight and level. Overall, a great plane for the money!
Old Jun 18, 2011, 06:55 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Good luck with the 1st flight.
Just got back from flying mine. Such a great little plane
sykotic is offline Find More Posts by sykotic
Old Jun 19, 2011, 08:37 AM
Joined Nov 2005
Maiden tomorrow so thought I'd better take some pics just in case!
Old Jun 19, 2011, 07:15 PM
Auckland NZ
Joined Aug 2007
Very Nice, looks good as a pylon racer.
The wasp can out turn any other plane ive flown, it will seriously rip around a turn fast than you can think.
I hope they havent stopped making them, it looks like they have though
Old Jun 20, 2011, 01:45 AM
Joined Nov 2005
They're still listed by the manufacturer here.
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
