Old Nov 15, 2012, 09:38 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
No shims on mine. Ive heard of others that dont fly quite right out of the box though, Its possible some need shimming.
Arctery - Same old 16/25/2 (old as the hills motor thats been in 4 different models and gets an ass wooping in each and still keeps on cranking! ) KPG25 5.2:1 6S 1600 45C (2x3S) ICE100 lite with a 14.5x14 slim RFM trimmed to 14" on a 36mm +5 degree spinner.
jackosmeister is online now Find More Posts by jackosmeister
Old Nov 15, 2012, 11:41 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Sure, man!
My slow November brain interpreted it as a direct drive setup
My bad.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 15, 2012, 11:58 PM
Auckland NZ
Joined Aug 2007
Think im gonna get a V tail wasp fuse to stick my spare wing too. Then set it up purely to do eggbeaters and other dumb stuff
Old Nov 16, 2012, 01:12 AM
Arcteryxxx's Avatar
Joined Feb 2010
Nice plan. Wonder how much free space there is in the fuse after tail servos are mounted....
Old Nov 16, 2012, 02:51 AM
Auckland NZ
Joined Aug 2007
Im thinking 2 D47s shoved up the boom somewhere. Only ~500w on an outrunner and AN folder for power. Something light and flicky, My 6S 1kg+ one is great fun and grooves really well, but its heavy and doesnt have the same spritelyness with the thumbs in the corners as a light weight wasp.
Old Nov 16, 2012, 04:17 AM
QDRevenger is offline
Find More Posts by QDRevenger
QDRevenger's Avatar
New Zealand, Auckland
Joined Jun 2011
The V Tail Swift fuse is a bit narrower then the T Tail. Jacko, I got one on the bench if you want to bring some gear to test fit and do some thinking
I'm putting my old 2W-20 on 4S setup in my V Tail and probably only one tail servo, will make carbon arms and pair the linkage together.
I'll post some pics of my new T Tail Swift soon, going to be running an out runner on 5 or 6S and one of DUP's 6x10 or 7x10 folders.
QDRevenger.
QDRevenger is offline Find More Posts by QDRevenger
Old Nov 19, 2012, 10:07 PM
robusp is online now
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
I was able to rebuild my swift after last stupid crash I had sometime this past summer.
I was slow putting my hand on the stick and she nosed in.
Right about when i was ready to put old gear in it, I got in a trade Mega 20-22-2 2875kV and 5mm shaft. So instead my proven 30A, 700W folding prop setup I went with pylon setup.
Had little hard time with the motor diameter, but was able to fit it in. Only concern I had was lack of space around the motor and blocked air vents. I also got 50A ESC with extended wires, so battery fits in front of it. For the prop I went with 5x5 and the plane rocked. I flew it for couple of weeks like this, but needed more.
Saturday I changed ESC to 100A and prop to 5.25x6.25.
I love it.
I can actually see plane leap forward when I move the stick from 3/4 to full throttle.
When I checked the numbers on 1800mAh 4s today I got 80A and 1100W. This tells me I have room for more prop.
I don't thing this plane will ever see folder
Rob
robusp is online now Find More Posts by robusp
Old Nov 19, 2012, 10:59 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Rob,
Was 1100W static?
What RPM on APC E 5.25X6.25
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Nov 19, 2012, 11:39 PM
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Gryphon,
No idea on RPMs. My meter is shot.
And yes the numbers are static.
Rob
Old Nov 19, 2012, 11:53 PM
GryphonRCU's Avatar
Joined Mar 2008
Hi Rob,
Assume 30,500 RPM (static) till you see otherwise.
That is my best guess based on recent multiple tests with that prop.
If your motor was in a Stryker, I would push you for 50% more AMPs for single passes but this application is way different.
Name of the game: cooling for motor.
Have fun,
Gryphon
Old Nov 20, 2012, 06:10 AM
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Gryphon,
I ran it like that on Sunday.
I do get some air in. My spinner is only 32mm dia. and is about 3mm away from the nose.
There is a slight gap between fuse and motor at the vents. I actually had to grind some of the material away when I was installing the motor for the first time.
The temp outside was in mid 40s.
Motor was at 140s after good hard 6 min flight.
I'll keep an eye on it. I don't want to fry it that's for sure.
Rob
Old Dec 16, 2012, 12:25 AM
QDRevenger's Avatar
Joined Jun 2011
Hey guys,
Last few weeks I have been building a new Swift in between work. Decided to try something a little different. Inspired by the German Speed Cup planes, I wanted to try a an outrunner in the nose instead of an inrunner. I used Hyperion DS-11TMB servos all around this time, didn't trust the 09's after the pot issues I had with my last Swift. I will be running a Hyperion HS-3026-1600kv motor with a 6 x 10 Carbon Folder setup (DUP's special) on 5S initially. 3 + 2 2250mAh 65S Nano-Tech lipo's. Machined up a mount, offset slightly to keep the thrust angle the same as the stock mount, not sure if this will be correct or not, but only one way to find out. I will drill and tap M3 screws after its had a paint to make sure it cant spin or move incase the epoxy and milled fibre doesn't hold. Pitch speed calculates out quite quick, I'm curious to see how quick it can go.
Description: Name: IMG_1042.jpg
Description: Name: IMG_1119.jpg
Description: Name: IMG_1118.jpg
Description: Name: IMG_1165.jpg
Description:
Need to tidy up inside and give the nose a quick touch up and it will be ready to maiden.
Old Dec 16, 2012, 12:28 AM
Auckland NZ
Joined Aug 2007
Very very nice work.
DS11 = DS09 with different case and gearset The innards are identical.
Old Dec 16, 2012, 12:32 AM
QDRevenger's Avatar
Joined Jun 2011
Thanks, don't tell me that , I have 20+ 11's, never had any drama. Only ever had 3 x 09's and two played up. Oh well, it is what it is now.
QDRevenger.
Old Dec 16, 2012, 01:31 AM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Originally Posted by QDRevenger View Post
Hey guys,
Attachment 5376207Attachment 5376208Attachment 5376209Attachment 5376210Attachment 5376211
Beautiful engineering m8 as usual HPR5 would have been the go to glue that mount I hope it hold out fine
you running the YEP 100 Amp speedy?
Let me know when you maiden it I'll come get some video
Cheers
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
