Old Oct 01, 2012, 07:31 AM
AndrésMtnez is offline
Find More Posts by AndrésMtnez
AndrésMtnez's Avatar
Madrid, Spain
Joined Dec 2004
Originally Posted by feefo View Post
I doubt I ever use that sort of movement from the servo arm. Except on a delta wing for the ailerons..... maybe.
45ş total, not each side
AndrésMtnez is offline Find More Posts by AndrésMtnez
Old Oct 01, 2012, 09:20 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Great job, FB!!!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Oct 01, 2012, 02:36 PM
fishboy77 is online now
Find More Posts by fishboy77
In search of RC nirvana
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Originally Posted by sebbe View Post
Great man, looks fast and it is really not a slow airframe as you are getting 179mph with that setup,, REALLY nice..
I wunder if you would gain more speed with a 4.7x5.5 prop
It's worth a shot. That prop has been great for me on an Electrifly Rifle and on my friend's SR3. I'll try it out next weekend.
Originally Posted by Arcteryxxx View Post
Great job, FB!!!
Thanks man!
fishboy77 is online now Find More Posts by fishboy77
Old Oct 02, 2012, 03:11 PM
Arcteryxxx's Avatar
Joined Feb 2010
Be warned: this is just a mock-up
Following the latest craze I was too tempted to explore the possibility.
Mounted (loosely) a HK H3126 to the miniHawk fuse, stuffed a 2S2200 as far back as possible and a 3S2200 in front of it. Right behind the firewall I placed a Himodel 100A and mounted the wing. CG at 40mm.
I think that with the longer fuselage of the HK Reverb, a carefully chosen pair of 4S lipos (or what sums up to about 4S3000) for the 1600kv or 5S of equal size for the 1300kv it will be possible to run this combo with a 7x13-ish folding prop.
Just some crazy thoughts from a dude which still has to use his motherinlaw's kitchen table for the tinkering
So.....tempted anyone?
(I'm putting the 16/25 back in but will be playing with the thought of it....)
Description:
Description:
Description:
Old Oct 02, 2012, 03:30 PM
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Dude I've been following the Swist thread and had that exact same idea of putting a big outrunner on the front of the firewall. Balance will be the only challenge. I have an old MSH Protos 500 helicopter motor sitting around. 800 Kv and 180 grams. I'm thinking 12s. 2x 6s 1200 mAh 30C Gens Ace and the HW 70A HV ESC. Prop for about 40 amps and 1.75 kW. Maybe get a Reverb close to 200 mph? Those packs are 175 grams and 105x34x24 mm. Hopefully they can fit far back enough in the fuse to get a decent CG.
http://www.hobbypartz.com/98p-30c-1200-6s1p-6666.html
http://www.hobbypartz.com/07e-c-plat...a-hv-opto.html
Old Oct 03, 2012, 02:49 AM
Madrid, Spain
Joined Dec 2004
With a 180g in front of the motormount you won´t be able to balance correctly without a ton of weight in tha tail, if you add such a heavy battery pack.....
I´m using a 180g motor in the back of the motormount (standard position), and even with a 180g batery I need around 40-50g in the tail
Old Oct 03, 2012, 11:21 AM
mattbrignoli is offline
Find More Posts by mattbrignoli
Joined Sep 2008
hello, what is the speed with a het 2w25 in 4s ?
i think the 2w25 is a got solution with 4 sells
thanks a lot!
mattbrignoli is offline Find More Posts by mattbrignoli
Old Oct 03, 2012, 11:55 AM
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
What are the dimensions of your battery? With very thin packs, one might be able to slide them far enough back into the fuse to get a decent CG.
Also what 180 gram motor are you using?
Old Oct 03, 2012, 11:57 AM
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
thanks a lot!
Yeah that will be a great motor for the Swift. With a 5.25x4.75 you will probably get about 160 mph. 150 mph with a 4.75x4.75.
Old Oct 03, 2012, 01:06 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
I like to use a 5x5 w/the 2W25 on 4s. definitely faster than 160
stanordave is offline Find More Posts by stanordave
Old Oct 04, 2012, 02:36 AM
Madrid, Spain
Joined Dec 2004
108x35x23, I push it back until it touches the wing nut
The motor is an axi 2826/10 I had around here, not even 600W, but it´s a good brick to build a bit of speed in the dives and hold some energy in the fly bys
Old Oct 04, 2012, 12:55 PM
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Hmmm. I haven't messed with mine yet, but if you can't get the battery any farther back than that then I agree it will be an issue. Maybe a 36 mm inrunner on the inside of the firewall would be a good option.
Old Oct 04, 2012, 01:20 PM
Arcteryxxx's Avatar
Joined Feb 2010
You can push a 2S2200 all the way back beyond the wing nut and use a 3S2200 or similar size in the normal position. With the ESC up front and e.g an AR7000 under the canopy with the sat in the tail above the elevator servo you can use a 150g outrunner in front of the firewall an find a CG between 45 and 50mm. Best guess based on the mockup posted earlier.
Old Oct 07, 2012, 10:01 PM
Demon 6 is offline
Find More Posts by Demon 6
Dir. of Innovation at Alert 5
Demon 6's Avatar
United States, FL, Fort Lauderdale
Joined Jul 2011
I'm at 52mm and it flys sweet!
Demon 6 is offline Find More Posts by Demon 6
Old Oct 12, 2012, 02:34 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
The slightly smaller version which I know as the Hummingbird is available from a US dealer now. http://www.alofthobbies.com/killer-bee.html
Maybe they'll get the Swift/Reverb in stock soon? They also stock the Flying Fish (they call it the Genesis) which can be converted to electric.
I wonder if he's going to stock other Launchmodel planes, such as the Radiant...http://www.launchmodel.cn/enProductShow.asp?id=164
feefo is offline Find More Posts by feefo
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
