Old Sep 16, 2012, 06:55 PM
Jabberwocky_ is offline
Find More Posts by Jabberwocky_
Jabberwocky_'s Avatar
Montreal
Joined Aug 2009
Damn! It was gusting too hard by the time I was ready to go back to the field. Now I'll have to wait until Thursday when I get off early from work to fly her. The sun is too low after work on normal days now. Bye-bye summer.
Thanks for all your well-wishing guys.
Jabberwocky_ is offline Find More Posts by Jabberwocky_
Old Sep 16, 2012, 07:13 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
I like 50mm too..
stanordave is offline Find More Posts by stanordave
Old Sep 18, 2012, 08:22 AM
23t23dS is offline
Find More Posts by 23t23dS
Singapore
Joined Oct 2008
My E-Wasp on the maiden.
23t23dS is offline Find More Posts by 23t23dS
Old Sep 18, 2012, 08:25 AM
Itchy Thumbs is offline
Find More Posts by Itchy Thumbs
Peter, irl
Joined May 2012
If you're planning on flying this weekend (weather forecast is not looking favourable) let me know, I'd love to come watch. My Reverb is getting there but I'm still several build-hours away from a maiden.
Itchy Thumbs is offline Find More Posts by Itchy Thumbs
Old Sep 18, 2012, 11:39 AM
stanordave's Avatar
Joined Jan 2006
I maidened my new Swift w/the HET 2w23, 5.25x6.25 and a 65C 2200ma yesterday.
My flying buddy has the same setup and the engine would be about 135º after landing. I got 145º on both the battery and motor. I assume its because I don't know what throttle management is - I'm an on/off type flyer.
The speed seemed a little faster than the 2w25 with a 5x5 but not by too much (no data, just an impression) but I like the -23 a wee bit better...
Old Sep 18, 2012, 11:54 AM
fishboy77 is online now
Find More Posts by fishboy77
In search of RC nirvana
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
I tried the 5.25x6.25 on my Reverb over the weekend. Mega 16/25/2 F5D, Gens Ace 4s 2200 mAh 25C. We had some trouble getting RC Speedo to pick it up - only got a handful of dopler readings. Fastest was 175 mph. Not sure I believe that one. The others were around 170 mph. Only got about 1:30 of full throttle per pack with that prop. By comparison, I was getting about 160 mph with the 5.25x4.75 and the current draw seemed to be significantly lower. My interpretation of this is that the higher pitch prop is not making a big improvement in speed while it is costing a lot of amps. I think the airframe is a bit draggy for this size prop. Maybe something closer to 6" is needed to see 180 mph. I'd really like to try the Graupner Cam speed 5.5x4.3 but it won't fit on my cheapo spinner. Guess I could just use a prop adapter.
fishboy77 is online now Find More Posts by fishboy77
Old Sep 18, 2012, 01:42 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Fishboy, have you tried the APC 4.75 (dia) x 5.5 (pitch) prop, think it's classed as a pylon prop?
A calc program I have claims the 16/15/3 on 3s and a 4.75x4.75 APC is 28a and 130mph pitch speed, the 4.75x5.5 is 'only' 32a but 148mph pitch. In reality my 16/15/3 was closer to 32a on the 4.75x4.75 but maybe that's down to batteries holding voltage better than the calc says.
Ok calcs aren't great and can be way off, but maybe for a few £££/$$$ it might be worth a try?
Only point about that prop is I'm not sure it gives you that extra speed that easily. Kinda hard to explain but I think you need to get your turns right to carry the speed. If you screw that up, it doesn't seem to be any faster IMO.
BTW, I only tried that prop on a Cavallino, probabaly not the best airframe to try it on really, and I didn't get many turns right either!
feefo is offline Find More Posts by feefo
Old Sep 18, 2012, 02:38 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Interesting observation, FB!
I still think 170 is a great number, and with 1:30 motor time it's quite economical too.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Sep 18, 2012, 02:53 PM
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Hey now Feefo. I have not tried the 4.75x5.5 on the Reverb. I found that the 4.75x4.75 was lacking in thrust as evidenced by the fact that I got much better performance with the 5.25x4.75. So I assumed that the extra pitch of the 4.75x5.5 wouldn't do any good for this airframe. However, that is my favorite prop for the Rifle on 3s with the Het 3W. It is almost as fast with that setup as it is on 4s with a 4.1x4.1.
I think you are right about the turns. And I think the reason for that is drag. With a small prop on the Reverb you better be efficient with your flying or else you will drop a lot of airspeed and the plane will take a while to get back up to speed because it is not very aerodynamic compared to something like a Viper that has a razor-thin wing. That's my guess anyway.
Old Sep 18, 2012, 02:54 PM
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Haha yeah Arctery I know you have gone with the 6x5.5 all along. I'll have to give that a shot.
Old Sep 18, 2012, 03:19 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
There's also the APC Pylon props intended for 'gas'. They're available in 6.5" dia and 5, 5.5, 6 and 6.5 pitch. They normally drop a few amps over the electric version i.e 6x4 pulls less than a 6x4E so you might be able to use the 6.5x5 or 6.5x5.5 over the 6x5.5E.
Old Sep 18, 2012, 03:34 PM
Arcteryxxx's Avatar
Joined Feb 2010
Actually there's a 5.25x6.25 on the speeder now, but I haven't flown it yet with that prop.
With APC pylon props you will have insane vertical performance but you will lack the top speed and drawing too many amps. I have used a 6.5x6.5 in a Stryker with the MEGA 16/25/2EC at appx 110A on 4S with a 4S5000 lipo. With a 16/25 F5D you can expect around 120A and 27000rpm if - and only if - your battery can deliver. Will sure be a rather interesting but unfortunately short flight with a 4S2200...
Please post a video
Old Sep 18, 2012, 03:55 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Well I was thinking more the 6.5x5 (or maybe the 6.5x5.5 but I think it'd be too much) in comparison to the 6x5.5E. But you're probabaly right in them being too thrusty for this plane and I doubt they'll give the top speed FB is looking for anyway.
But...you could cut them down, so you could use the 6.5x6.5 cut down to say 5x6.5.
Old Sep 18, 2012, 04:31 PM
Arcteryxxx's Avatar
Joined Feb 2010
Why not make a 6x8 from a 7x8sport? Would be a sturdy bastard, tho
Old Sep 18, 2012, 05:19 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Don't want to catch them on landing tho
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
