Old Sep 09, 2012, 07:08 AM
FlyLT's Avatar
Earth
Joined Oct 2009
Originally Posted by Farmer_Joe View Post
FlyLT - Great video, i relay need this wide lens #16.
you will not regret it
FlyLT is offline Find More Posts by FlyLT
Old Sep 10, 2012, 01:38 PM
FlyLT's Avatar
Earth
Joined Oct 2009
I was wondering if anyone using flaperons on the mini hawk?
If Im not mistaken the instructions suggested using spoilerons..?
Old Sep 10, 2012, 02:05 PM
C4X
Glider Junkie Beyond Help
C4X's Avatar
Canada, BC, Victoria
Joined Nov 2008
Basically, spoilerons are your friend with this type of flyer. You still retain full roll control (not so with flaperon, as an up aileron command only yields neutral, and somewhat of an opposite response from the aircraft than intended because of the drag from the other down aileron). Spoilerons create drag and dump lift to slow down and plunk 'er down. Helps with the extra speed of a pylon plane to be able to spot land a bit better.
C4X is offline Find More Posts by C4X
Old Sep 10, 2012, 02:12 PM
C4X
C4X's Avatar
Joined Nov 2008
...hoping to have my Reverb in the sky before the rains. I'll post up for sure when I do. Will be running:
HET 2w20
4.75x5.25
60a Exceed ESC
GensAce 2200 3s
Old Sep 10, 2012, 02:19 PM
Joined Dec 2003
that should be a good setup
lennyk is offline Find More Posts by lennyk
Old Sep 10, 2012, 02:27 PM
C4X
C4X's Avatar
Joined Nov 2008
It worked very nicely on a 'slipso' like airframe, about 150 mph. Probably a bit slower on the mibo, but easier to see (and oh how I love fully molded ships :thumbup. Can't wait to try 4 or even 5 cell with an appropriate Mega! I'll post pics of my paint job using a tamiya rattlecan. Came out very nice (save for a bit of bleed under the masking tape) and dried literally in minutes. Very easy to make out the topside
Old Sep 10, 2012, 02:58 PM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Because of the location of the ailerons on the Reverb wing, flaperons are not a good idea. You do not want to be adding washin when you are coming in for a landing as that will increase the tendency for tip stalling and losing aileron control. Since the control surfaces are close to the wing tips, flaps will do just that. Spoilers on the wingtips add washout which will stabilize the plane by reducing the tendency of the wingtips to stall. If the control surfaces were inboard, flaperons would be preferred.
fishboy77 is offline Find More Posts by fishboy77
Old Sep 11, 2012, 01:28 AM
AndrésMtnez's Avatar
Madrid, Spain
Joined Dec 2004
Spoilerons actually kill this tendency completely, I´ve tried full spoilerons and full eleveator up (with more elevator throw that you can use in normal flight), and it does not tipstall, only goes down with the tail doing a leaf movement (up-down-up-down)
AndrésMtnez is offline Find More Posts by AndrésMtnez
Old Sep 11, 2012, 02:32 PM
FlyLT's Avatar
Earth
Joined Oct 2009
Oh... now I got it
Old Sep 16, 2012, 03:24 PM
Jabberwocky_'s Avatar
Montreal
Joined Aug 2009
Darn... I went to go maiden my Reverb today but when I got to the field, I could not get the CG forward enough, despite my wildest efforts. It was at least 45mm to 50mm from the LE, which seemed to be way too far back. So I did not fly it. My HET-2W-20 with a 2200mah 3S and Ice 50 Lite are just too light and don't weight down the nose enough. Better to be safe than sorry.
Where are you Reverb guys setting your CG at?
Jabberwocky_ is offline Find More Posts by Jabberwocky_
Old Sep 16, 2012, 03:32 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
50 is perfect!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Sep 16, 2012, 03:57 PM
Montreal
Joined Aug 2009
Originally Posted by Arcteryxxx View Post
50 is perfect!
Ah jeez, so that means I was ok to fly. Ok... I think I'm going to walk back to the field.
Thanks for your very quick reply Arcteryxx!!
Old Sep 16, 2012, 04:03 PM
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Good luck on your maiden flight.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Sep 16, 2012, 04:10 PM
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
Good luck from my side, if fly it at 50mm too.
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Sep 16, 2012, 04:19 PM
Arcteryxxx's Avatar
Joined Feb 2010
Have fun! You'll love it big time
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
