Old Aug 27, 2010, 05:07 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Havent done much flying recently, end of winter here (last weekend of winter actually!)
But the wasp is still going strong
I rekon 150mph would still be sweet, its a pretty rigid little plane.
Dunno if an F5D setup would be the way though, 4" prop would get eaten up by the 35mm spinner. Maybe something a bit lower kV with a 6x6 or so.
jackosmeister is offline Find More Posts by jackosmeister
Old Oct 09, 2010, 09:07 AM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
My Wasp turned up yesterday, what a sweet looking plane. Mines orange/blue.
I'll probably just start with the motor it came with (Emax BL2220/07 400watt outrunner) on 3s and go from there... Also ordering a Turnigy 480L V-Spec 1370kv Inrunner for the next step up with some 4s packs.
Got to get me some servos and folding prop bits so I can get it flying. Can't wait.
danger_mouse is offline Find More Posts by danger_mouse
Old Oct 09, 2010, 08:32 PM
Auckland NZ
Joined Aug 2007
Shweeet.
That turnigy 480L might be a bit big for the wasp, its pretty long and might hamper getting the packs in.
I did some testing on it, try search the motors thread for the details.
Old Oct 09, 2010, 08:51 PM
Joined Jan 2007
Damn, will have to get my measuring stick out.
Yep I've seen your posts on testing it. That's what made me enthused about the motor. I was guestimating with a bit of extrapolation that a 9x7 on 4s might get me around 700 watts. A bit more twist with a +5 centrepiece maybe another 100 watts....
Old Oct 18, 2010, 06:56 AM
Joined Jan 2007
Had some stuff turn up.
Seems like battery access will be fine with the turnigy 480L.
Problem is my new esc, (turnigy plush 60a) the thing is friggen huge. Will fit with 3 cells no problem, but I'll need to rethink the 4 cell packs I was considering (2200 45c nanotechs) for something flatter and wider.
What is the best way to put in the servos? Heatshrink them and epoxy in place? Still have to go shopping for pushrod hardware.
Old Nov 04, 2010, 06:54 AM
Joined Jan 2007
Awesome little plane.
I'm only running around 300 watts atm, but geez it moves along. Amazing how it glides about as fast as a 46 gas plane flies along.
Need to move the CG back more as it levels out in power off 45 degree downlines. Currently about 50mm.
My setup:
Emax 2220-07 1200kv, BB spinner, 9x7 Aeronaut Cam Carbon blades, Align BL35G esc, Flightmax 3S 35C 2100 cells, MKS DS470 MG digital servos, Dubro 2-56 Clevises and rods, Rhino 2S 610 receiver pack with Hobbywing 3A UBEC.
I'll leave it another week or so before I worry about putting in the Turnigy 480L. Not sure about stuffing in 4S packs, bad enough with 3S with lack of room. Might need to rethink my layout.
Only got one pic someone else took out at the club. The photo doesn't do the orange justice, she glows in real life. Need to find my camera, and get a few more pics.
Old Nov 04, 2010, 02:01 PM
Auckland NZ
Joined Aug 2007
Exzacery
Old Feb 20, 2011, 09:31 PM
Auckland NZ
Joined Aug 2007
Thread bump to get this plane back where it deserves too be!
Been flying it a lot, love it. Its well behaved enough to be the "warmup" plane, but after a few red bulls it'll take anything you can throw at it! Turns like a crazy thing, rolls surprising spritely and flies soooo crisply. Ive yet to see the wings flex, full noise dives and heavy yanking on the stick, its a very rigid slippery little airframe. Its more rigid than my voodoo.
My only gripe with it would be, put a bigger battery hatch and a rudder on it. Its screaming for more power (the airframe could easily handle 1kW+) and a rudder would be awesome for some high energy spins
Old Feb 23, 2011, 02:32 AM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
Jacko, I can pick one of these up for £150 so what do you think to a Mega 16/15/4 on a Speedcam 6x5.5 with 4 cell 2200mah 30-40c batteries? Looks like it should all fit and pitch speed would be around 130 mph at 25k rpm.
wastegate is offline Find More Posts by wastegate
Old Feb 23, 2011, 02:39 AM
Auckland NZ
Joined Aug 2007
Yup, it'd work and fit well, be easy to balance too.
What'd be cool to try, would be a 16/15/3, heatsinked, (or 3E for a bit more safety/sanity) on 4S. That'd move
Its seriously a great flying airframe, it'd still be a hoot at power levels as low as 300W
Old Feb 23, 2011, 03:06 AM
Joined Jan 2007
Yea I'm still only running 300w through mine and it whizzes along nicely. All the gas guys stop to watch whenever I fly it.
Been meaning to bolt in the Turnigy 480L I have, but just haven't got around to it yet.
It really is a sweet plane to fly.
Old Feb 23, 2011, 02:12 PM
Joined Nov 2005
I have my name on the waiting list, should be around 2 weeks
Old Feb 23, 2011, 02:36 PM
Leopard is offline
Find More Posts by Leopard
Si
Joined Aug 2004
Mibo E-Osa
My E-Wasp is powered by cheap Turnigy 3542-1250kV motor, Plush 60A ESC and 3S Rhino 2250mAh 40C Lipo cells. Total weight is 910g.
With Aeronaut 11x10 floding prop and Aeronaut spinner with +2,5° pitch it goes 190km/h in horizontal flight (measured with Eagletree Airspeed indicator).
On the ground my Wattmeter shows consuption max. 75A, but it quicky drops to around 65A (fully charged Batteries)
Great plane, but fuselage is to weak under the wings and around the canopy. A little harder landing and it starts to crack. Some carbon fiber solves the problem Otherwise is build well. Wings are very strong and survives vertical drops from 300m with easy
A video with previous much weaker setup (keychain quality):
http://vimeo.com/13540640
Leopard is offline Find More Posts by Leopard
Old Feb 23, 2011, 11:31 PM
Joined Jan 2007
Hi Leopard,
How did the 35mm outrunner fit up front? Must be a tight squeeze in there with it and that 60a plush esc. Got any pics of under the hood?
Old Feb 24, 2011, 02:57 AM
Leopard is offline
Si
Joined Aug 2004
Yes, the fit is tight, but if you put the motor in the position, that the cables are at the bottom, where is a little bulge, then you can get it in.
60A ESC is on the side of the fuselage, about 6cm after the motor. When the battery is inside they are in contact, but because ESC is only a little warm after the flight, there is no problem with that.
I will make a foto and post it, later!
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
