Old May 23, 2012, 09:18 AM
fishboy77 is offline
Find More Posts by fishboy77
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
OK I have a few questions about hardware.
1) The elevator horn is tiny (about 10mm) and there is no slot in the elevator for it to fit into. Should I cut a slit in the elevator and epoxy the horn in? Or should it be glued directly to the surface of the elevator, which would seem like a really weak joint? I'm tempted to get something like this that is much larger and has more surface area that would allow a better glue joint and get the control rod down a bit more so it won't hit the screws that hold in the horizontal stab:
http://www3.towerhobbies.com/cgi-bin...&I=LXK107&P=ML
2) The aileron servo horns only screw in about half way before they get really hard to turn by hand. Should I torque them down to the base of the threads with pliers or should I leave some threads protruding?
3) The threaded rods and metal clevises for the aileron pushrods have a decent amount of slop in them. Do people normally solder or glue the clevises to the rods to eliminate the slop? Is there any reason not to just use nylon clevises?
Sorry about all the questions but this is my first nice molded plane and I want to get it right. I did check out the manual but my Slovenian is a little rusty.
fishboy77 is offline Find More Posts by fishboy77
Old May 23, 2012, 11:10 AM
TimR74 is online now
Find More Posts by TimR74
United Kingdom, Wales, Monmouthshire
Joined Aug 2011
Yeah, you need to dremel a small slot just through the bottom surface of the elevator and epoxy the horn in. 1/2 hour or 12 hour epoxy is best. I ended up making a larger horn from fibreboard for a bit more glue surface area and to clear the tailplane screws.
The brass ail. horns should be screwed all the way in, try cleaning the thread out with an m2 tap if you can. I also epoxied the brass horns in.
I normally wick some thin cyano into the clevis threads when I'm happy with the set up, to eliminate any movement. You want zero slop on the control surfaces for no flutter. One other trick is to put a very small drop of thin cyano (use a small screwdriver) onto the control horn pivot with the clevis fitted, hit with some kicker, wait a few secs then break the bond carefully using the servo. Leaves you with a cyano 'bearing' surface which takes the last tiny bit of slop out.
Hope this helps.
TimR74 is online now Find More Posts by TimR74
Old May 23, 2012, 11:56 AM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
That helps a lot - thanks!
Old May 23, 2012, 02:27 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
Pre-installed firewall? Not the same as the Mini-Hawk, Swift, (pick your name) etc
Good! One less thing to mess up (unfortunately I'm real good at that)
stanordave is offline Find More Posts by stanordave
Old May 23, 2012, 02:47 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
None of mine have ever come with hardware I use 2/56 sullivan clevises and threaded rod on ailerons, on the elevator a ball link at the servo and clevis at the other end.
Biggest thing is getting the linkages mechanically good, 100% servo throw should equal max throws, using EPA to tone down the throws should be avoided as much as possible.
On the ailerons, offset the servo horns so you get a lot more up throw than down, the wasp likes differential, and LOVES lots of spoilerons on landing. Ive posted my throws before somewhere in this thread
jackosmeister is online now Find More Posts by jackosmeister
Old May 23, 2012, 03:30 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
What do you mean by Offset the Horns. ? I am so used to my big gas aerobats where we have to have the horn and ball link dead center of the hinge line.....now I look at all the builds on these speedsters, and guys have the horns all over the place.I only ask this cause I am about to redue the horns on the Swist with clevises and taller horns for better mechanical advantage ....I have my radio dialed way back with the stock horns they gave.I redid the one on the elevator about 3mm taller and it made a HUGE difference,hence doing the ailerons.
VooDoo Child is offline Find More Posts by VooDoo Child
Old May 23, 2012, 03:45 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
VooDoo: your servo arm should be angled slightly forward when the servo is centered.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old May 23, 2012, 07:54 PM
Joined Aug 2010
Got ya ! So that is better then using the differential in the radio? That is what I have always done
Old May 23, 2012, 08:09 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
It's mainly so you get alot of "up" throw so you have heaps of spolier usable when you come into land. The Wasp loves it, the more you get the better.
As a positive side effect you get the differential mechanically built in
sykotic is offline Find More Posts by sykotic
Old May 23, 2012, 11:00 PM
Joined Aug 2010
Schweeeet,I will give that a shot.....my 11X will probably get mad at me though, for not using it's capabilities
Old May 24, 2012, 01:32 AM
QDRevenger is offline
Find More Posts by QDRevenger
QDRevenger's Avatar
New Zealand, Auckland
Joined Jun 2011
I used Dubro clevises at both ends on my current Swift, but do like Jacko's ball link to the servo idea. Will do that on my next one
Description:
QDRevenger.
QDRevenger is offline Find More Posts by QDRevenger
Old May 27, 2012, 05:22 PM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Well I was thinking about getting a HET 2W-30 motor for pylon style flying but after reading more of Jacko's and Voodoo's posts it seems that 2200 Kv is a little low for the range of cell counts that I want to use, 3s-5s. Looks like about 2500 Kv is the way to go. The HET 2W-25 gets good reviews but I've seen reports that it gets pretty hot even on 4s and on 5s they can start to come unglued. So I think I'll go for the Mega 16/25/2 green F5D. Supposedly that thing can take some serious heat. The problem is I can't find a good non-folding 36 mm spinner that will fit a 3.2 mm shaft. Does anyone have a source for these?
Old May 27, 2012, 06:49 PM
momomo is offline
Find More Posts by momomo
Joined May 2005
I bought this on ebay
(I have not received yet,I do not know whether it suits)
http://www.leaderhobby.com/product.asp?ID=9394001224501
momomo is offline Find More Posts by momomo
Old May 27, 2012, 07:37 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Fishboy,
There are various options that you can have on that custom MEGA.
Consider 4mm and 5mm shaft options if that works with other spinners.
......among other tweaks.
Gryph
GryphonRCU is offline Find More Posts by GryphonRCU
Old May 27, 2012, 07:49 PM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Wow, $1.26 for an aluminum spinner! I'd be surprised if it's balanced for 35k rpm but at that price I guess it's worth a shot!
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
