Old Jan 14, 2012, 12:59 PM
Farmer_Joe is offline
Find More Posts by Farmer_Joe
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
Gryphon - even 14" prop doesn't fit the Wasp, you must cut about .4" that it don't strike the wing.
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Jan 14, 2012, 01:02 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Ah, I see.
Thanks.
Gryphon
Edit: maybe 16/25/1.5S 2990 KV (3050+ actual) would be closer for running similar props.
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jan 14, 2012, 02:29 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Heya Gryphon, I was kidding with the 7S, that'd be a tad nuts
Poor wasp was designed for 300W little outrunner, 2kW will be fine
Sweet, ive shimmed the motor/box up to as much as sanely possible, have about a degree down and .5 degree right.. we shall see how it goes
jackosmeister is online now Find More Posts by jackosmeister
Old Jan 14, 2012, 02:55 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
But the far end of sanity is our playground...right, Chris?
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jan 24, 2012, 11:27 PM
Auckland NZ
Joined Aug 2007
Finally got my pinion to hold on
2060W, 100A, for 7900 rpm, 158mph pitch speed.
Should be adequate...
Old Jan 29, 2012, 01:22 AM
Auckland NZ
Joined Aug 2007
It flies
Maidened it off a slope at Raglan (west coast of NZ) today, in 20 odd knot winds, baptism by fire.
Maiden flight done with a straight centre peice for a 14x14 prop, got a solid amoun t of get up and go, slower than the X-plane on 4S, but not massively slower (16/35/1 5.2:1 14.5x14) , I say it'd do an honest 140-150mph (and it gets there very quickly )
The extra weight over the old setup means energy retention is pretty awesome, but its lost a little of a its spritelyness with the sticks in the corners, still no slouch though. I Like it
Put lots of G's on it, reinforced wingseat showed no sign of failure.
Now to crank up the pitch and try it on a calm day!
Got some video to have a look at an edit, if its visible Ill upload it.
Old Jan 29, 2012, 07:40 AM
Auckland NZ
Joined Aug 2007
Mibo eWasp at the beach (2 min 23 sec)
"slope soaring"
Old Jan 29, 2012, 11:23 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Very cool!!!
Flyextreme is offline Find More Posts by Flyextreme
Old Jan 29, 2012, 03:25 PM
GryphonRCU's Avatar
Joined Mar 2008
That was awesome.
I loved the vertical capability of your plane.
Gryphon
Old Jan 29, 2012, 03:32 PM
Arcteryxxx's Avatar
Joined Feb 2010
Great, Chris!
Old Jan 29, 2012, 06:40 PM
Auckland NZ
Joined Aug 2007
It gets my two thumbs up approval, nothings hot, batteries seem fine, and the ICE100 is within the zone of being able to use a throttle (instead of switch). Once the prop bites it launches forward, plenty of thrust to hit the pitch speed in a few split seconds.
ICE100 recorded 95A, and 9500rpm in flight, so its more likely to be around 80A (this is with a straight centre peice)
Whats kinda interesting is that the rolls are pretty axial power off, but power on vertically you can nearly throw it into a spin with the aileron stick in the corner, must be some sorta torque thing. Dispite the big prop, the ailerons are well out of the prop wash.
Old Feb 11, 2012, 09:30 PM
Auckland NZ
Joined Aug 2007
A few more flights on the straight centre peice, its fastish, but it definetly runs out pitchspeed.
Add a +5 degree centre peice, Whole new kettle of fish, 21" of pitch is a good thing!
Big difference in performance! 160+mph now. Acceleration is down a touch on the straight centre peice, but not horrifically (its still definetly a "hot" liner!)
Loving this plane. Unfortunatly no video, rubbish overcast weather.
Old Feb 12, 2012, 12:38 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
LOL!
Chris,
I had my first experience with 23 inches of pitch today and was flabigasted with how fast these perfectly behaved little planes can go on so little power!
We need more of this I say!
(Factual stuff here: http://www.rcgroups.com/forums/showp...0&postcount=29 )
Regards
Peter
Peter M is offline Find More Posts by Peter M
Old Feb 12, 2012, 12:55 AM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
After seeing yours fly Jacko I'm seriously considering keeping my second one and finding a silly fast setup for it....
I think my yellow one needs to stay as a hack with the "slow" power it has now or I'll kill it with eggbeaters
sykotic is offline Find More Posts by sykotic
Old Feb 12, 2012, 01:08 AM
Auckland NZ
Joined Aug 2007
Its a pity you had to leave early man, it really came to life with more pitch! Went from "yeh, thats pretty quick" too "ohh daammmmn"
I have a few spare KPG's here if you want one (also have that GM prop and roll of insulation in the car, doh!)
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
