Old Oct 30, 2011, 02:34 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Bit of a warning to those cranking big throws -
My elevator wiper popped out of the TE, jamming the elevator full up.
jackosmeister is offline Find More Posts by jackosmeister
Old Oct 30, 2011, 12:00 PM
Dbox is online now
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Exactly the reason I dont have wipers on horizontal fin in any of my speed planes.Been there....
Yuri.
Dbox is online now Find More Posts by Dbox
Old Nov 15, 2011, 09:30 PM
Auckland NZ
Joined Aug 2007
Its amazing what you can do with CA
Old Nov 15, 2011, 09:37 PM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
THAT my friend ... took a little more than just CA!
Colin
wollins is offline Find More Posts by wollins
Old Nov 15, 2011, 10:38 PM
Jabberwocky_ is offline
Find More Posts by Jabberwocky_
Jabberwocky_'s Avatar
Montreal
Joined Aug 2009
You big joker Jacko! I can tell it's your new fuselage, cuz of the different shape of the cutout in the side air intake. I want one these! Going to see one at Icare this Thursday. He carries it under the Mini Hawk name, with the 48" wingspan (the smaller version).
J
Jabberwocky_ is offline Find More Posts by Jabberwocky_
Old Dec 04, 2011, 01:34 AM
Auckland NZ
Joined Aug 2007
Time to finally get a little silly with the woteva its called today mini hotliner
800W was feeling a little tame
16/25/2, KPG25 5.2, 6S 1800 (2x3S), ICE 100 lite 14.5x14 RFM slim trimmed to 14" (the absolute biggest diameter that'll fit) on a +5 hub, works out to 21.5" of pitch ~2.5kW guesstimate.
Too get the rear 3S pack in, it has to go through the wing seat area, so that got opened up. Carbon tow will be run around the wingseat, and down the edge of the canopy too the motor mount (this motor on 6S has caused in flight rhinoplasty before...)
Finally found a use for that little lump on the front designed for outrunner wires too...
Old Dec 04, 2011, 01:58 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Jacko,
Suggest you double check your nuts before you fly it!
(Just to be clear, the ones on your prop.)
Peter M is offline Find More Posts by Peter M
Old Dec 04, 2011, 02:08 AM
Auckland NZ
Joined Aug 2007
Need to install the power system properly before I start worrying about my nuts
Old Dec 04, 2011, 03:36 AM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
You're nuts, but I can't wait to see the video
I too opened up the little bump for ventilation and it works pretty well with the ram air effect. Is it right that the air outlet area has to be 3 times that of the inlet for air to flow or it just ends up pressurising the fuselage?
wastegate is offline Find More Posts by wastegate
Old Dec 04, 2011, 06:46 AM
Auckland NZ
Joined Aug 2007
Thats the theory with the air outlet.
Because the Rx and rear lipo literally plug the boom of the wasp now, needed a new speed hole
Old Dec 22, 2011, 03:50 AM
Auckland NZ
Joined Aug 2007
Progress.. Finally
Carbon tow laid into the fuse, to put and end to the cracking wingseat/rear mount, and to reinforce the nose to handle the 2+ kW
It was about as much fun to get in there, as pulling teeth, and is probably a messier process...
Old Dec 24, 2011, 05:39 PM
Farmer_Joe is offline
Find More Posts by Farmer_Joe
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
Nice, my wasp is getting a new drive too... Het 2W-25, KPG 4.2:1 and 6S
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Dec 28, 2011, 01:11 AM
Auckland NZ
Joined Aug 2007
LHS has started stocking some new packs, Horesons, terrible name but I thought Id give em a go.
AUW is 1028grams with 6S(2x3S) 45C 1600, CG is easy to attain (and I can remove the big chunk of lead I had in the tail with the previous setup!). Should be just a tad over 2000W/kg, which will be spritely
With the opened up wing seat, packs go in and out easily.
Its looking good, just gotta solder it all up and cycle the packs
Old Dec 28, 2011, 01:40 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
in my language that name means "son of a prostitute"
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Dec 28, 2011, 03:48 AM
Auckland NZ
Joined Aug 2007
Haha, yup, its a terrible name
Fits with room to spare
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
