Old May 01, 2010, 11:34 AM
DrZiplok is offline
Find More Posts by DrZiplok
USA, CA, San Francisco
Joined Feb 2004
Mibo E-Osa/Axis/E-Wasp
I'm looking to replace/upgrade from a Micro Chili/Sparkle, and noticed the E-Wasp at Soaringcomposites.com, which looks just about perfect. A bit of research shows that it's a Mibo model called the E-Osa ('Axis' I think).
Does anyone know if there's anyone carrying it in the US?
= Mike
DrZiplok is offline Find More Posts by DrZiplok
Old May 02, 2010, 01:52 AM
ongl is offline
Find More Posts by ongl
Joined Jun 2009
Mike,
You can try soaringusa , espritmodel or icare-rc (nearer to where you are located). As a last resort, I believe soaring composites do send overseas. I have dealt many times with them.
leo
ongl is offline Find More Posts by ongl
Old May 05, 2010, 01:49 PM
babasmurf_35 is offline
Find More Posts by babasmurf_35
Originally Posted by ongl View Post
Mike,
leo
Yeah, ONGL has practically bought the whole collection that Soaring Compaposites has to offer...minus the sloapers though
babasmurf_35 is offline Find More Posts by babasmurf_35
Old May 05, 2010, 03:44 PM
DrZiplok is offline
Joined Feb 2004
Hmm, does that mean that he has one of these already? If so, any opinions?
I have a Micro Flash already, so I'm not really looking for a pure hotliner, more something that I can hotdog around with under power, though I'd probably use a folder and a couple hundred watts...
= Mike
Old May 07, 2010, 12:21 AM
ongl is offline
Joined Jun 2009
DrZimlok,
The MicroFlash is a 1.5m wingspan plane (ehawk 1500?). We have tried this motor prop combination with great success. Motor turnigy 2836-2350kv motor (It has a 4mm shaft and you can get one from hobbycity.com) to a 7x5 apc (you may want to opt for a folding version , try to get the one with the 8mm /3mm mounting size) and 2200 30c 3s battery. Works great!
Flies like a half hotliner half pylon.
leo
Old May 07, 2010, 01:47 AM
DrZiplok is offline
Joined Feb 2004
Leo,
Were you referring to the Micro Flash or to the Micro E-Wasp?
Also, I just realised in looking at the Mibo site that the regular E-Wasp is €189 vs the Micro E-Wasp at €329. That seems just a bit outrageous. 8(
= Mike
Old May 07, 2010, 10:29 AM
ongl is offline
Joined Jun 2009
Mike,
The recommended powertrain is suitable for both the planes. I have actually tried the setup on small pylon planes (0.8m wingspan) to gliders of 1.5 meters and it worked beautifully.
Both the "e-wasp" and "micro e-wasp" are the same plane. The "micro e-wasp" is bundled with the motor , esc , servos, spinner. Funny!
leo
Old May 17, 2010, 09:14 AM
big bird is offline
Find More Posts by big bird
Belfast / Dublin
Joined May 2004
e wasp and micro e wasp have different spans - 12cm in the difference
big bird is offline Find More Posts by big bird
Old May 17, 2010, 12:15 PM
DrZiplok is offline
Joined Feb 2004
Do you have any reference/links for the difference? The Mibo webstore has no specifications for the non-Micro E-wasp at all, and the only difference between the two listings is that one is Model 800401, and the other is 800401.SET.
= Mike
Old May 17, 2010, 12:29 PM
big bird is offline
Belfast / Dublin
Joined May 2004
http://mibomodeli.si/trgovina/index....oducts_id=4242
in german but the specs are just numbers
both the german and the slovenian refer to an "e-wasp" and a "micro e-wasp"
maybe its the same plane and this is a misprint of the specs as you are right about the catalogue number 800401 in both cases
wierd huh?
Old May 17, 2010, 12:39 PM
big bird is offline
Belfast / Dublin
Joined May 2004
the micro e-wasp is designated as 1200mm on its webpage thumbnail
i've emailed Mibo for clarification
Old May 18, 2010, 03:58 AM
big bird is offline
Belfast / Dublin
Joined May 2004
ok - the 1320mm span is the new model, the 1200mm span will nolonger be available, so there is only one model and it has been updated, according to Bogo at Mibo
Old May 18, 2010, 11:37 AM
DrZiplok is offline
Joined Feb 2004
Interesting. At 51" it's now the same size as the Royal Models Snipp, which is somewhat easier to get here (though realistically, no cheaper).
= Mike
Old May 18, 2010, 09:45 PM
ongl is offline
Joined Jun 2009
Just measured my micro?/e-wasp. The invoice says micro e-wasp but the wing span is 1320mm
Old May 18, 2010, 10:06 PM
DrZiplok is offline
Joined Feb 2004
@ongl - any chance of some close-up pictures? I'm particularly interested in how much space there is in the fuse (e.g. what batteries will fit), what the motor area looks like (space for a 28mm outrunner, or inrunners only), and of course any opinions you have about the model.
Thanks!
= Mike
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
