RLG candidate
Anyone have any experience with these. Looks to me to be a good possibility.
sonicrcmodel — December 10, 2007 — Exciting new electrical retracts that weigh only 6.5 ounces for the total setup. Each strut has almost an inch of downward spring loaded travel for maximum shock absorption. Installation is as simple as mounting into your model and connecting the 3 retract units servo wire plugs into the master retract controller then plugging controller into your receivers gear channel. No air tanks, air lines, or complicated setups. Does require one servo for the nose steering. Struts are removable from retract unit allowing you to customize for your particular application. |
Your correct, my bad
If you have not already seen, there are three construction videos, build, motor upgrade, and remote video camera on you-tube.
js |
Tallahassee, FL
Joined Feb 2010
Glad you got it worked out. It happens. The guy in the build video had a similar problem that he attributed to a lack of instructions, using the fiberglass pushrod as a guide tube for a pushrod to the elevators.
I've watched all three videos numerous times. Mostly while waiting for my kit to ship/arrive. The videos are a great resource like this forum, giving people a chance to see how others did it and take the advice or think of alternatives. |
Tallahassee, FL
Joined Feb 2010
Front Landing Gear Construction Problem
Hoping for a bit of advice on this one. The manufacturer must have come up with a new formula for plastic that is impervious to all adhesives known to man and some not.
I have tried expoxy, CA and a plastics glue that claims to "bond to almost anything" and each time after adequate curing time I go to work on the strut cover, sanding/preping for paint and the two halves pop apart and whatever adhesive I had used practically falls right off. I wonder how the MQ-9 would perform as a taildragger... ![]() Any suggestions? |
Tallahassee, FL
Joined Feb 2010
You think your kidding. I'm just about there. Now I just have to decide between black and aluminum.
Black is scale and aluminum is shiny... I have never had this much of a problem adhesing something. Between various adhesive trys I have completely cleaned out the old and scuffed the surface. In the pick you can see the remains of some Medium CA. |
Tallahassee, FL
Joined Feb 2010
Horizontal Stab Install Mod
I previously reported that when I installed the horizontal stab spar I only inserted about 2" leaving about an 1 3/32" out so I can make the stabs removable.
I didn't like the idea of scrapping off or scratching up a whole bunch of area where the stabs mount, plus these things are almost as big as some wings so it may prove to be helpful. Anyways. See the attached picture for my idea and give me any thoughts you may have. While I have not finished the mod yet because I am lacking some washers and cotter pins, I think you will get the general idea. You can see where the spar exits the tube there is about a 1/4" exposed. My thought was to put a well fitted washer over the exposed portion (black line), seating it firmly against the tube (I may add a layer of material to the tube to give it a bit more girth) and drill a small hole through the spar through which I will put a pin (yellow line) that rests snuggly against the washer. Given the calculations I have done I think the top speed for this will be somewhere in the ares of the upper 60mphs with a stall speed of about 28mph and a comfortable cruising speed in the low 50mphs; so I do not believe the stabs will experience such a significant amount of drag that this alternative mounting method will cause grave danger. Anybody disagree? |
Tallahassee, FL
Joined Feb 2010
Possible Motor/Prop/Battery Combo
After given some long thought to the models characteristics and estimated performance specs I think I may go with the following (or similar):
Turnigy 4258-800: (Currently out of stock) http://www.hobbyking.com/hobbyking/s...ss_Motor_800kv With an 11x7/11x8 3 blade prop and 4S 3000mAh 15C battery. I'll probably go with a straight-up ESC, w/no BEC, and mount a receiver battery up front. ??? I attached a zip file with the specs for many of the Turnigy motors. |
Another possible power system
Because I already have one still in the factory wrappers, I think I will start with:
Great Plains Electrify RIMFIRE 35-48-850kV and buy a Great Planes Silver Series SS-60 (60A) HV brushless ESC and start with an APC 3-bladed 11x7 and 3-bladed 11x8 (both of which I already have) my starting battery will be a 3S 3300 mAh LiPo (of which I have several). I'll go with a BEC if and only if I decide to run with the retractable LG. That's my going-in picks for now, and the MotorCalc report looks pretty good for that mix, as long as I don't try to do much 3D stuff.
Tallahassee, FL
Joined Feb 2010
Do it! And send us pics of the clipped wing version after.
![]() Great Planes, Great Planes...If I had the stuff lying around I too would probably use it, but over the past year or so I have started to fall out of love with Tower Hobbies, ergo "my" choice. |
If you're still having trouble gluing that plastic you could try NoNails, since all the non solvent adesives have been rigid glues, maybe it needs something with a tiny ammount of flex to stop the joint cracking.
http://www.diy.com/diy/jsp/bq/nav.js...&isSearch=true This is the stuff, i expect you can get this or something similar where you are. |
| Thread Tools | |
| Discussion UAV MQ-9 Reaper 2500mm Military R/C Drone by ProJet | nitroplanes | Nitro Planes | 20 | Apr 13, 2013 07:23 PM |
| Discussion ProJet MQ-9 Reaper | Kul | Video Piloting (FPV/RPV) | 19 | Feb 21, 2012 07:24 PM |
| Discussion I have a Lanier SE5a coming, any tips or tricks............. | mtdoramike | Scale Electric Planes | 14 | Mar 19, 2011 06:17 PM |
| Question Gravity Hobby P 51 tips and tricks? | Lilbanks96 | Parkflyers | 0 | Apr 19, 2010 05:32 PM |
| Build Log Halfpipe 60 (HP60) build tips/tricks/whatever | Daemon | Slope | 158 | Feb 21, 2009 11:27 AM |
