That is not true at all. The B400 has a programmable Tx, is larger so it's more stable and the tail holds much better. It can be set up to be very docile for a beginner. It can use many Trex 450 and clone parts which are much cheaper than SR parts.
Latest blog entry: Some stuff
The only caveate with the 400 is the intimidation factor of the rotor doing anywhere from 2400 to 3000 rpm. The cost of the radio is soon amortized quickly when multiple helicopters (or aircraft) are programmed into it, saving the cost of a radio for each and every model. When a local experienced heli pilot is asked to help setup an older heli, then that can be used to get some experience on the CP platform. If a Blade CP is setup correctly and it has fresh batteries, main motor, and tail motor, they are quite nice to fly. If isn't anyone local to help, the 400 with help from some good pilots here is a very good choice that will not break the bank for typical upsets. I have decked mine twice since last November and the most expenive damage was 120 bucks as there was not too much undamaged. It now sports a 4 blade head on its way to becoming a Hughes 500C. Have fun.
Don |
Rhode Island
Joined Aug 2007
Hello,
I can't really comment on the CP or 400, I would probably be too intimidated by the 400 to make it my next step though. For what it is worth I found the transition from CX2/mCX/mSR to the Blade SR to be fairly smooth as long as your expecations are realistic. I believe I will outgrow the stock Tx in fairly short order though. I already would like more control of the throttle/pitch curves in idle-up mode. I believe if I could adjust this to my liking, I would already be using idle-up most of the time. I am reading on this forum that the CP can be tamed down with a programmable Tx so if you have a DX6i or something similar it may be worth getting the CP going. |
Joined Jul 2012
The comparison is interesting. A friend just gave me, I am a beginner, CP Blade SR. I have been practicing with an inexpensive FP, Double-Horse. Starting was full of vibration, but after installing the new main rotor which was thrashed, the heli smoothed right out.
A little nervous about taking it up for the first flight, even after following each step in the manual. |
Joined Aug 2003
hi,lil blade cp can fly on 2sor 3s battery ,an 800 or 1000mah 2or3s 20c battery
should fly heli ,the 1000 will still weight less than nimh pack , lil more than the 800 only recomended change change for 3s is moter pinon . if youre sure the nimh packs good ,check heli whith tail moter unplugged ,it may be going bad and hogging amps |
I second the vote for the 400. I learned how to fly helis on a Blade 400. They are easy to repair and the parts are readily-available as well as relatively inexpensive. I've had two Blade SR helis and while they are docile, they are not very durable and parts are more expensive. Funny how a smaller heli that's marketed towards beginners is less crash-worthy and more expensive to repair but I digress.
The tail does hold better on the Blade 400 and as long as the crash isn't major, it's quite easy to repair. Plus, like someone said earlier, it comes with a 10-model 6-channel computer radio that will allow you to fly almost any basic airplane as well as more helis. |
Latest blog entry: Chaos 600 ESP build
| Thread Tools | |
| For Sale Did you just buy a new E-Flite Blade SR? | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 3 | Feb 28, 2010 12:01 AM |
| Discussion Would Like To Buy E-flite Blade Cp Or Cp Pro In Mode 1 Where ? | FedericoA | Mini Helis | 4 | Aug 21, 2008 07:23 AM |
| Discussion Would like to buy E-FLITE t-34 or APRENTICE RTF BLADE CP OR CP PRO IN MODE 1 WHERE ? | FedericoA | Electric Plane Talk | 2 | Aug 04, 2008 02:49 PM |
| Help! e-sky belt cp or e-flite blade 400?? | MICHELT33 | Mini Helis | 14 | Mar 12, 2008 05:54 PM |
| Wanted e-sky belt cp or e-flite blade 400 ? | MICHELT33 | Aircraft - Electric - Helis (FS/W) | 1 | Mar 09, 2008 05:35 PM |
