Old Sep 27, 2001, 08:05 PM
ramw5p is offline
Find More Posts by ramw5p
United States, SC, Rock Hill
Joined Jul 2001
Help with Guillow's Spitfire.....TIA
Okay, i recently purchased a guillows 27 wing span spitfire. i have the gws pico pack, and am assuming that i can use this for ruddel and elevator controls. i have no problem building the plane, but have absxolutly no idea what to power it with. i have [had thanks to wings letting go at 100 feet] a litestik...and that is the extent of my experience with e flight...more experience with glow
so if anyone knows what kind of engine/battery combo works, and any special building tips for maing this plane an electric PLEASE let me know, and give me any tips you have.
thanks fellas
scott
ps. i did do a search and didnt find anything
pps...not that it matters....BUT... if anyone had any glow ideas for the plane that would be fine to...but e prefered!
ramw5p is offline Find More Posts by ramw5p
Old Sep 27, 2001, 08:52 PM
Rotten Robbie is offline
Find More Posts by Rotten Robbie
Rotten Robbie's Avatar
Kent, Wa.
Joined Feb 2001
I have a 20" Grumman Wildcat that I am powering with a Graupner S280 motor, a GWS 5A ESC, and 8 150ma NiCads.
With a small airplane like that Spitfire you are better off with direct drive because of the prop size limitation.
Robbie
Rotten Robbie is offline Find More Posts by Rotten Robbie
Old Sep 28, 2001, 02:55 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Ask a simple question- get more confusing answers.
I suspect that your lightstick gear might work, although I'm a little concerned with the prop pitch speed. You should also be careful to keep the airplane as light as possible- shoot for about 6-7 ounces. Spitfires have a tendency to tipstall, use lots, repeat lots of washout and keep the cg forward. I'm playing with a Sterling P-40 in the same size range- my first guess at a power system is a Speed 280 geared 3:1 with a Gunther prop, and an 8 cell 300 mAH battery pack. Note that I haven't flown it yet. The rest of the gear from the Litestik should work. Check the website of rcmicroflight for the article that Tom Hunt wrote on a Bearcat. If you want to be zoomie- then try a Speed 300 direct drive on 6 cell 350 mAH nicads- flights will be very short though.
Sam Brauer
Norwalk, CT
Megowcoupe is offline Find More Posts by Megowcoupe
Old Mar 25, 2003, 10:38 AM
Warren Jones is offline
Find More Posts by Warren Jones
Warren Jones's Avatar
Langley,B.C,Canada
Joined Jul 2002
To ramw5p
Guillows "27 Spitfire.
I plan on building this one as well. I have the gear for it so far it is the following:
Dual IPS (S2) GWS motor
HS-50 Servos
GWS Single rate 5/6 channel "lightweight" reciever
GP C-10 micro esc ( weighs lighter than GWS 5 amp esc)
Batteries: 6-7 cell 500mah AAA Nihms
Note: I will be adding a little depth and lenth to the main wing.
I plan on ailerons and retracts despite any opposition.
I know this can be done because these kits can be built extremely light and "in the air strong" (like a real plane should be).
Covering will most likely be Silk Span.
* Ailerons, tail feathers will be super light pull-pull and cable with stearable tail wheel.
*Retracts will be direct link with HS-55 servo if needed.
Cheers
Warren Jones
Warren Jones is offline Find More Posts by Warren Jones
Old Mar 25, 2003, 02:08 PM
RCFlybry is offline
Find More Posts by RCFlybry
Faster Faster!!
RCFlybry's Avatar
Kaysville Utah, U.S.A
Joined Oct 2001
I would suggest ailerons rather than rudder, you'd have to modify the wing a little but it isn't too tough. If you do go rudder only up the dihedral a little. I also double... even triple what Megowcoupe said about the washout. The Spitfire is one of the best looking airplanes ever made but can get real nasty on you if not configured right. Best of luck with her!
Bryan
RCFlybry is offline Find More Posts by RCFlybry
Old Mar 25, 2003, 02:58 PM
Flight Engineer is offline
Find More Posts by Flight Engineer
1/1 scale engineer.
Flight Engineer's Avatar
Zurich Switzerland
Joined Sep 2002
have a look at this
and the thread on q&ef spitfire in this forum.
I really think you should consider ailerons. Remember turning on rudder is relying on the secondary effect of the rudder. This is ok for high wing pendulous types but for a low wing war bird with an elliptical wing you are just asking for trouble.
Good luck with the build and let us know how it goes.
Flight Engineer is offline Find More Posts by Flight Engineer
Old Mar 26, 2003, 05:47 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Gotta agree with Flight engineer. I am having extreme difficulty turning and banking a rudder only low wing design with 5 degrees dihedral. In fact, I am in the middle of drawing up an aileron wing for it.
The size SOUNDS like the sort of speed 280-speed 400 range. For a cheapo I'd plump for the GWS 300 motor geared up 3.75:1 on 7x5 or 8x6 prop. Nice on 7 cells.
Old Mar 26, 2003, 09:52 AM
ChuckHHill is offline
Find More Posts by ChuckHHill
Concord, CA, USA
Joined Dec 2000
Based on similar models I have seen friends fly, believe direct drive 280 with Gunther 140x110mm prop would work well.
Chuck Hill
ChuckHHill is offline Find More Posts by ChuckHHill
Old Mar 26, 2003, 05:51 PM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
[QUOTE]Originally posted by ChuckHHill
I agree with Chuck, a direct drive 280 on 6-7 270-300NIMH and a gunther push on 5 x 4 prop will make it go well. let's hope you can keep it to 8 ounces RTF.
Tom
Tom Hunt is offline Find More Posts by Tom Hunt
Old Aug 28, 2003, 11:21 AM
Langley,B.C,Canada
Joined Jul 2002
My Guillows Spit build
So far the wing is underway.
Ailerons, retracts and flaps. Total weight so far 1.4 oz.
I initally planed for a mega 16/7/12 motor. I have just noticed that Razor puts out a nice looking (even smaller) BL as well.
I don`t know much about the new "little" razors, so we`ll see.
Cheers
Old Aug 30, 2003, 01:11 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Consider the MPjet 25/25 - comes with box. Use 7x5 prop. Its small, light and has bags of power.
And doesn't cost a firtune either.
Help with my S&B ME163 before I build it. Lucas in Alaska Electric Plane Talk 2 Dec 16, 2009 02:20 PM
OK, I need some real help with my S&B ME163 Lucas in Alaska Foamies (Kits) 4 Oct 20, 2002 09:47 AM
looking for some help with PDA's newguy Life, The Universe, and Politics 4 Jul 09, 2002 09:37 PM
Guillow's Spitfire as electric R/C Clipperkite Beginner Training Area (Aircraft-Electric) 23 Mar 11, 2002 10:39 AM
Help with my S&B ME163 before I build it. Lucas in Alaska Foamies (Kits) 0 Sep 26, 2001 05:52 PM
