Old Apr 29, 2010, 08:31 PM
doubleduce is offline
Find More Posts by doubleduce
USA, CA, San Anselmo
Joined May 2003
Converting an old NiCad Zagi 400X to lipo
The first question should I do it?
I stopped using the Zagi a few kids ago (a good 4-5 years ago) and I am now getting back into flying. I think,,,, my 3 NiCad battery packs are toast so I was going to but some new ones and someone said I should look at going the LiPo route.
What do I need to get? Lipo Battery, ESC, Motor,????
it is expensive to make the conversion?
If someone had done this,(yes, I tried searching but nothing came up) please give me some help.
Is it worth it??
Thanks a ton
doubleduce is offline Find More Posts by doubleduce
Old Apr 29, 2010, 09:33 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
I'd overhaul the entire power system. You can get a hot setup to double or tripple the speed and power for less than $60
Xpress.. is offline Find More Posts by Xpress..
Old Apr 29, 2010, 10:26 PM
Joined May 2003
Any help on telling me what I need to get to get this bad boy airborne
Old Apr 29, 2010, 10:30 PM
Red_N_White is offline
Find More Posts by Red_N_White
Needs more moose!
Brisbane. Australia.
Joined Jan 2007
3S 11.1v 2200mah lipo. 25 Amp speedy. 2000kv 28mm inrunner. 6x4 prop. Pick your fav brands.
Red_N_White is offline Find More Posts by Red_N_White
Old Apr 29, 2010, 10:38 PM
unlvace is offline
Find More Posts by unlvace
Las Vegas
Joined May 2008
setup
cheap
http://www.hobbycity.com/hobbyking/s...hless_Inrunner
http://www.hobbycity.com/hobbyking/s...Blue_Series%29
with a zagi prop, or apc 5x5
better
http://www.highendrc.com/index_eprod...products_id=28
http://www.hobbypeople.net/gallery/701466.asp
any 2100 20c or higher 3s will do the trick on both setups
unlvace is offline Find More Posts by unlvace
Old Apr 29, 2010, 11:21 PM
rwp is offline
rwp
Find More Posts by rwp
rwp
rwp
rwp's Avatar
Joined Nov 2003
Is it worth it??
Thanks a ton
If your 400X is stock you'll need at least 3 CF spars to keep the wing from flapping if you go brushless. They can be added easily.
rwp is offline Find More Posts by rwp
Old Apr 30, 2010, 12:04 AM
jdltuna is offline
Find More Posts by jdltuna
USA, NV, Las Vegas
Joined Jan 2007
400x
My 400X is on its third rebuild. The motor is a rewound blue wonder with an 18 amp ESC from Hobby King and a 1000 mAh 3c lipo. The biggest up grade you can do is dump the winglets and go with a double inboard tail like the Wild Wing. No more Zagi death spirals! I now have to work hard to get the wing to spin, it just gives a clean stall break and drops the nose. I also made an EPP foam pocket for the battery in the nose. The receiver and ESC are hot glued in.
Jerry
jdltuna is offline Find More Posts by jdltuna
Old Apr 30, 2010, 12:30 PM
Joined May 2003
Yes, my 400X only has one CF Spar. Where should I place the 2 additional spars???
Old Apr 30, 2010, 12:33 PM
Joined May 2003
Originally Posted by unlvace View Post
So is this all I need and will all this be compatible?
Rhino 2350mAh 3S 11.1v 20C Lipoly Pack $39.58
Mystery 30A BEC Brushless Speed Controll.. $12.69
HXT 2835 (380S) 2700kv Brushless Inrunne.. $19.50
Am I missing anything?
Old Apr 30, 2010, 11:24 PM
unlvace is offline
Las Vegas
Joined May 2008
this might be a better chose on esc 10 dollars more better bec inside.
and you can run a 6x4 (around 32 amps) but I would use throttle management. 5x5 (around 25amps) prop might not get you full vertical.
http://www.hobbycity.com/hobbyking/s..._25C_Lipo_Pack
if this zagi goes to fast you will get the zagi flap, that is why the extra spars are required,
Old May 02, 2010, 04:00 AM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Spars should be in a aframe set up one down the middle and one each down the le of the wing about 1 to 2 inches back.. straping tape and packing tape will still likely flap.. but i suppose is worth a try..
PaulVi is offline Find More Posts by PaulVi
Old May 05, 2010, 06:26 PM
Joined May 2003
Thanks for all the advice, I have place an order and now I have to wait to build her up.
Old May 10, 2010, 05:45 AM
fpvnick is offline
Find More Posts by fpvnick
My other vehicle is unmanned
fpvnick's Avatar
Joined Jan 2010
Did you get a lipo charger as you will not be able to charge it of your old charger i have 2 of these and they work great for the price. Poli Max B6 6 cell Lipo balance charger about 30
fpvnick is offline Find More Posts by fpvnick
Old May 10, 2010, 01:46 PM
Joined May 2003
Thanks for checking. I am all set I have the Triton EQ already.
Old May 10, 2010, 02:03 PM
Joined May 2003
What is the best way to add the the CF spars? I am thinking 2" from LE and glue with Gorilla Glue and tape over.?.?
Question Converting an old Kyosho Jet arrow to esc/brushless/lipo? branflake12 Racing Boats - Electric 24 May 30, 2010 12:15 AM
For Sale NIB Zagi 400X rcsoar4fun Aircraft - Electric - Airplanes (FS/W) 6 Mar 18, 2010 09:51 PM
Discussion Stock Zagi 400x and 3s Lipo norstaroption Flying Wings 13 Nov 18, 2009 11:30 PM
Sold Zagi 400X norstaroption Aircraft - Electric - Airplanes (FS/W) 3 Nov 17, 2009 09:40 AM
Discussion Some help converting an old bird nerys Parkflyers 5 Sep 08, 2009 12:41 AM
