Old May 07, 2010, 02:58 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Originally Posted by rickbones View Post
10s! Ya know this thing is made out of foam? Post Video.
Hey, if this guy can put a real turbine in a FlyFly, Vic can run this one on 10S!!
Although the real turbine sounds way cool... it looks slower than a 2KW setup on 6S....
Flyfly F100 super sabre with Lambert Kolibri P20 turbine - first flight and flame out (4 min 9 sec)
chalmrast is offline Find More Posts by chalmrast
Old May 07, 2010, 04:36 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Yup, Chad knows I can do it...
AceMigKiller is online now Find More Posts by AceMigKiller
Old May 07, 2010, 05:40 PM
rickbones is offline
Find More Posts by rickbones
rickbones's Avatar
Joined Sep 2005
Im just north of you guys in flag, if your going to be flying that thing around some time let me know.
rickbones is offline Find More Posts by rickbones
Old May 07, 2010, 07:16 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
"Beat the Heat" in July!!!! If Vic doesn't tear the wings off by then...
Old May 07, 2010, 10:54 PM
rickbones's Avatar
Joined Sep 2005
Sounds good...hope the weather is better this year.
Old May 08, 2010, 11:01 AM
Joined Jul 2004
Pffft... even in that torrential wind and rain I got up and flew my Parkzone Radian, that was hilarious! And then JAMES ripped the wings off of it! (But I was doing some crazy things with it just prior to handing off the controls... )
"Beat the Heat" is a definite GO. Hope to see you guys there!
Vic
Old May 08, 2010, 12:34 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Yeah, it was kind of funny watching the wings turn into paddle wheels!!
Old May 08, 2010, 08:28 PM
CRCJA is online now
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Let's Compare
So excuse the mess behind the planes, but let's compare the size of the L-39 to previous planes.
Turbulence
CRCJA is online now Find More Posts by CRCJA
Old May 08, 2010, 09:34 PM
Joined Jul 2004
That's a big bird... I'm gonna like it!
Just got my Fan and Motor (thanks Robert!) so I'll be testing it out on 10s soon!
I'll be running one of those brand new HET Typhoon 700 series motors in the also new HET 9305 V2. Anxious to see how many lbs. of thrust that combo kicks out! I'll post specs and results here too.
Vic
Old May 09, 2010, 10:37 AM
rickbones's Avatar
Joined Sep 2005
Vic
What size batteries are you going to run?
Old May 09, 2010, 11:52 AM
Joined Jul 2004
Hyperion VX (35c) 4200's. I have a 4s and a 6s pack so I'll just slap'em together...
*just as a number crunch* to hit 2kw on 10s, all I need is about 54 amps; easily done. If I can get about 60 amps (while still being efficient with this motor) I'll be seeing around 2220 watts. So even if I make it porky at around 7.5lbs, I'll still have about 300 watts/lbs.
I'm eager to see what kind of thrust this new 9305 V2 puts out!
Vic
Old May 09, 2010, 08:39 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
whats changed with the fan?
AIR SALLY is offline Find More Posts by AIR SALLY
Old May 09, 2010, 08:43 PM
rickbones's Avatar
Joined Sep 2005
I am waiting to see how your power system turns out. I am interested in the V2 fan as well. So far I have:
Scorpion 3026 1400kv
4000ma 35c 8s
sentilon 100a hv ESC
This ESC is a brick, its about the size of a pack of cigaretts. it will do up to 12s so I may have to do a dragster setup in the future
Old May 09, 2010, 08:50 PM
rickbones's Avatar
Joined Sep 2005
Im not sure where MIGKILLER is getting his setup but this is might be what it looks like http://www.extremerc.com.au/estore/i...order=6&page=2
I wish I had seen this before I bought my setup.
Old May 10, 2010, 05:11 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The new HET 9305-700 fan has been available for a little while now, its basically a 9305 with new larger motor housing to take 39mm cans, and a slightly revised rotor.
When I tested a handful of the sample motors for HET I had the 1400Kv on hand, it pulls over 80 amps on 10 cells, and over 45,000rpm too which should make for some interesting performance I have it in the fan sitting here, am thinking about what to put it in, maybe a new L39
Incidentally I did test it on 12s too, only half charged 4000mah packs but I saw 100A and over 48K rpm, almost 4000 watts. With fully charged 5000mah packs it will be a monster, 50K rpm will be obtainable so make sure that rotor is set up perfect!! (Of course no idea if the motor will take it but results have been pretty good so far in testing)
Extreme_RC is offline Find More Posts by Extreme_RC
Found FreeWing L-39 flyandi Aircraft - Electric - Jets (FS/W) 2 Mar 25, 2010 10:00 PM
Sold ***PRICE DROPPPPPING*** HURRY!!!Great Planes L-39 driftcrawlslop Aircraft - Electric - Jets (FS/W) 5 Mar 09, 2010 03:07 PM
Wanted Sapac 70mm Jets L-39 or T-45 (DFW area) turbinefancy Aircraft - Electric - Jets (FS/W) 1 Mar 07, 2010 12:56 AM
Sold K&A L-39 rtf hole digger Aircraft - Electric - Jets (FS/W) 2 Mar 03, 2010 01:40 PM
For Sale Sapac(foam)l-39 esb-help Aircraft - Electric - Jets (FS/W) 2 Feb 28, 2010 10:56 AM
