Old Apr 29, 2010, 11:47 AM
triplane is offline
Find More Posts by triplane
Shanghai, China
Joined Mar 2010
Build Log
Crimson, my home designed 2 meter woody (plans added for free download)
Hi all,
Am new here and my name is Patrick, coming from China. My first post here is my just finished 2meter woody,named after the lovely Crimson Rosella originated in Australia.
I build this tiny bird from drawing board, with total building time logged less than 50 hours. All materials used are balsa, Tong and pine wood. with simple R/E control, this bird demonstrates easy handling characteristics and thermals quite well. I use a couple of scrap Futaba 3003 standard servo for control and a cheap AM 2 channel radio, NO PROBLEM at all!
Wingspan: 1950mm
Wingcord: 220mm
Airfoil: modified SD 7037
Length: 1080mm
Weight: 750g
Here I enclose some pictures taken during the construction plus finished model, wish you like it.
PLEASE NOTE! On page 6 there are all plan necessary in PDF files for anyone who interested in this bird to download
triplane is offline Find More Posts by triplane
Old Apr 29, 2010, 12:07 PM
ArneHu is offline
Find More Posts by ArneHu
Balsa Builder. With some foam.
ArneHu's Avatar
Eastern Norway Scandinavia
Joined Dec 2009
Congratulations with a beautiful model and the great work! What sort of battery are you using? (Building a plane at nearby same size.)
ArneHu is offline Find More Posts by ArneHu
Old Apr 29, 2010, 12:14 PM
triplane is offline
Shanghai, China
Joined Mar 2010
well...simple 5 cell NiMH 1800mh 6V pack is used, think its more than adequate for such a plane.
P.S. THX for your comment buddy
Old Apr 29, 2010, 01:14 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Very nice job on a great looking model!!!
DT56 is offline Find More Posts by DT56
Old Apr 29, 2010, 01:28 PM
granada don is offline
Find More Posts by granada don
life long racing nut & modeler
granada don's Avatar
Granada Hills Ca.
Joined Nov 2009
Hi Patrick
Your new glider is about as nice as one could build just perfect looking in design and crafsmanship , one question is what did you use to cut the lighting slots and holes in your wing ribs. I have a super light woody 3M on the drawing board and would like to cut the ribs just like you have done, i too will use cap strips. In the photo of your knife and razor plane i was wondering what is the white item in the center, did you stack cut & sand your ribs and put in the lighting slots that way or one at a time.Can you let us know how she flys , thanks.
Its pretty neat how 2 people 1/2 way around world from each other can have the same ideas about a scratch built bird i too will use transperent red i will have some black trim, very cool stuff this sailplane building & flying
Sincerely
Don
granada don is offline Find More Posts by granada don
Old Apr 29, 2010, 02:03 PM
LVsoaring is online now
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
Beautiful work! Where did you get that red canopy?
LVsoaring is online now Find More Posts by LVsoaring
Old Apr 29, 2010, 02:32 PM
spinolio is offline
Find More Posts by spinolio
SoarNut
spinolio's Avatar
United States, MI, Kentwood
Joined Apr 2005
Great work, how does it fly?
spinolio is offline Find More Posts by spinolio
Old Apr 29, 2010, 02:38 PM
jtlsf5 is online now
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Probably the RIT dye trick on a clear canopy. Make up a solution of whatever color, then dip and keep dipping until the degree of tint is reached.
I'll let the OP confirm or disclose his method.
JT
jtlsf5 is online now Find More Posts by jtlsf5
Old Apr 29, 2010, 02:54 PM
Granada Hills Ca.
Joined Nov 2009
Just an added tip the Rit dye works on Ty Raps to make them the color you wan't
Don
Old Apr 29, 2010, 03:09 PM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
I used a transparent spray paint on mine. Worked much better than dye. I found it in the R/C car section of my LHS.
Wazmo is online now Find More Posts by Wazmo
Old Apr 29, 2010, 03:13 PM
LVsoaring's Avatar
Joined Jan 2006
Don't want to hijack the thread, but I always heard that the Rit dye trick was difficult to do because of the chance of warping the plastic in the hot water.
Old Apr 29, 2010, 03:32 PM
Granada Hills Ca.
Joined Nov 2009
I just used it warm for a Paragon canopy and let it set overnite to dye it yellow.
Don
Old Apr 29, 2010, 04:12 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
A super nice job on this plane!!! Fuse reminds me a little of a shark (fish). I'd like to hear some flight reports.
jaizon is offline Find More Posts by jaizon
Old Apr 29, 2010, 05:15 PM
georgeg is offline
Find More Posts by georgeg
United States, CA, Bakersfield
Joined Jan 2001
The water doesn't have to be boiling just hot. Tap water always worked for me. I've died several canopies (OK, it was a long time ago) and never had a problem with warping. I always died them before cutting them free of their base. Just pour the hot die mix into the inside of the canopy and let it stand for awhile. Pour it out and repeat until you get the tint you like. Quite simple really.
georgeg is offline Find More Posts by georgeg
Sold Nice woody 2 meter sailplane RTF rcdude01 Aircraft - Sailplanes (FS/W) 2 Dec 05, 2009 10:46 PM
Discussion My first home designed Quad IanJ Coaxial Helicopters 2 Nov 29, 2009 08:28 AM
Sold Rare Gemini 2 Meter Woody sailplane rcdude01 Aircraft - Sailplanes (FS/W) 5 Aug 18, 2008 05:20 PM
Sold Rare Gemini 2 Meter Woody sailplane rcdude01 Aircraft - Sailplanes (FS/W) 7 Aug 03, 2008 11:38 AM
Sold SkyBench Woody 2 Meter Osprey Advanfx Aircraft - Sailplanes (FS/W) 1 May 20, 2008 01:09 AM
