Old Jul 01, 2010, 08:17 PM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Meaning to say one should leave the 5V USB power connected to ensure the "live mode" does not abort?
etman is offline Find More Posts by etman
Old Jul 01, 2010, 08:19 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Mine never has. I unplug every time.
man2000me is offline Find More Posts by man2000me
Old Jul 01, 2010, 08:42 PM
tashley is offline
Find More Posts by tashley
Aerial Images of Texas
tashley's Avatar
The Texas Gulf Coast where hurricanes come to play
Joined Aug 2003
Nor has mine, me thinks that if the camera's batt is full enough to start a/v out by temporarily attaching a remote batt it will stay that way even if the camera's batt discharges to some degree. Can anyone confirm?
tashley is offline Find More Posts by tashley
Old Jul 01, 2010, 08:44 PM
jbpilot is offline
Find More Posts by jbpilot
My other plane is the TARDIS
jbpilot's Avatar
Philly 'burbs.
Joined Feb 2009
I have been able to unplug it every time. Trying to think about how much battery I've drained though. Usually I get it started and then it stays on (with A/V out) for the duration of my flying time. Typically about an hour or so. When I start it's definitely fully charged. Not that way by the end of flying though.
JB
jbpilot is offline Find More Posts by jbpilot
Old Jul 01, 2010, 08:45 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
here is a video NOT fpv however
just testing for AP
http://www.vimeo.com/13017049
there were a few other tests done recently that you can see
the r5 is my choice
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jul 01, 2010, 10:14 PM
HariEdo is offline
Find More Posts by HariEdo
Central Connecticut
Joined Jan 2010
I can confirm. If the battery is FULL at the time you disconnect, it will stay in live video mode until the battery is DEAD. But if the battery is still charging when you disconnect, it will power off the camera immediately.
HariEdo is offline Find More Posts by HariEdo
Old Jul 02, 2010, 06:58 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
So if you power it from your rx permanently, isn't that safer? No chance of the battery going flat mid-air then... How many volts does an rx output anyway? Is it 5? I had a feeling it was 6. Am in an airport now so can't take a look
Gree is offline Find More Posts by Gree
Old Jul 02, 2010, 07:35 AM
HariEdo is offline
Central Connecticut
Joined Jan 2010
RC Receivers don't output a voltage, they're running from some other power supply. Many people put between 5 and 6 volts out of their regulators or BEC devices, which makes it suitable for driving the servos. For the GoPro, I would recommend staying very close to 5 volts, and not going much higher. I have wired a small 5V regulator into my camera harness.
Old Jul 02, 2010, 08:09 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
I supply 5v to the GoPro from the Rx directly with no problem at all.
The Rx is feeded with the UBEC at 5v.
saucisse is offline Find More Posts by saucisse
Old Jul 02, 2010, 08:17 AM
tashley is offline
tashley's Avatar
Joined Aug 2003
You certainly can provide power to the cam that way, in fact it's been done by installing a switch to an empty port on the receiver and to the cam. That way you can just turn power on and off to the cam. Each receiver port's pos and neg is connected to a bus and only the signal wire is independent.
Old Jul 02, 2010, 09:16 AM
boom is offline
Find More Posts by boom
NiCd + Mabuchi 550 was da bomb
NY USA
Joined Apr 1999
According to Eyeofmine.com,
You can set the live video out to be of either SD or HD, how does one toggle this setting?
boom is offline Find More Posts by boom
Old Jul 02, 2010, 09:26 AM
AlcoNaft43 is offline
Find More Posts by AlcoNaft43
Joined May 2009
May be they mean component HD-output?
AlcoNaft43 is offline Find More Posts by AlcoNaft43
Old Jul 02, 2010, 09:30 AM
boom is offline
NY USA
Joined Apr 1999
Nevermind,
I think the difference is whether you plug into the top HD port or the bottom TV port.
Old Jul 02, 2010, 09:37 AM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
I'm making wire harnesses to make my GoPro an FPV cam.
May I know the pin-out of a 2.5 mm mini jack?
I have just drilled two holes in the side of the waterproof case. Now its not waterproof anymore. But I will fill it up the holes with silicone. The idea is to never have to take the GoPro out of its case. Charge, playback, fly FPV, connect to USB while in the case.
Then I'll strap a video TX to it and fly.....
Oops, I realized the 2.5 mini-jack supplied is a 4-pole (video and stereo audio). What I have bought are all 3-pole (video and mono audio). Can it still be used?
Old Jul 02, 2010, 09:56 AM
boom is offline
NY USA
Joined Apr 1999
Originally Posted by ggtronic View Post
i'v built my own cable with a 3$ plug+servo connector:
Hope this helps?
Discussion Simple Effective GoPro HD Hero Parkzone Radian Mount (Snow Blizzard Footage) snoopy Aerial Photography 26 Jan 03, 2015 09:02 AM
Discussion GoPro HD Hero : Is your SD Card a Go or No-Go ? nicnaimless Aerial Photography 19 Jun 30, 2010 11:15 AM
Discussion PING: GoPro HD Users Blue Chip FPV Talk 11 Apr 24, 2010 10:09 PM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 09:40 AM
New Product GoPro HD Hero Wide - High Def Helmet Cam Zirt57 Aerial Photography 7 Aug 01, 2009 12:27 PM
