Old Apr 29, 2010, 08:47 AM
redtail is offline
Find More Posts by redtail
Joined Dec 2005
My wowplanes B26 Marauder before it seconds before it crashed!
Hello fellow flyers,
I maidened my B26 Marauder yesterday-didn't go well.Within seconds of taking off she banked to the left,I applied opposite aileron but she keeped on going left if anything the turn tightened then she plowed in,I should add my ailerons worked in the correct sense-you can see in the photo I was applying opposite ban to the last moment.
I'm thinking maybe the torque of both engines turning the same direction might have been too much,was one wing producing more lift than the other,or were my engines mis-aligned with a bad thrust line ? I'm thinking of buying another kit and building her again. If you guys have any comments would be great to hear from you,I should say I have flown lots of planes mostly ARF's this is my first kit build,so I must have built something wrong to have such a reaction.
redtail is offline Find More Posts by redtail
Old Apr 29, 2010, 09:04 AM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Wow! I feel your pain. I'm amazed you are ready to build another one so fast. I don't want to insult your intelligence so this is a dumb question I'm sure but did it have sufficient speed on take off? It looks like a stall from the fact that it is not responding to your input. I would not think the same rotation would cause this but the real plane was known for being really tricky because of the small wing area to the size of the plane.
Is it a total loss?
Good Luck on the rebuild
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Apr 29, 2010, 09:45 AM
howlingriffon is offline
Find More Posts by howlingriffon
Joined Oct 2009
Were you using any rudder? In the photo it looks straight.
howlingriffon is offline Find More Posts by howlingriffon
Old Apr 29, 2010, 09:52 AM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
redtail,
Did you check both motors to make sure current draw was the same? Also, was it possible that you had a large warp in one outer wing panel? The wing cores on mine were super thin out at the tips and took a lot of care to keep straight. Differential thrust from miss-matched motors are more likely. What motors and speed control did you use, and did you run both motors off one battery?
Sorry to hear about the crash ---Stacker
stacker is offline Find More Posts by stacker
Old Apr 29, 2010, 09:58 AM
redtail is offline
Joined Dec 2005
Is it a total loss?
Alan
Thanks Alan and Howling Griffon,
Yes the rudder is straight,it happened just after take off-had plenty of power on as she lifted of the grass in a short distance,I wasn't airbourne long probably 10 seconds - guy at the model shop said might be a wing warp problem-I might order a new kit as I have all the gear for her,plus I know the build procedure-wasalso looking for an ARF twin which will take 2 x Eflite power 15 motors and spring air retracts-still looking lol!
Old Apr 29, 2010, 10:16 AM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Redtail would you recommend the Wowplanes kits? I've had my eye on the ME-110 for awhile as I love those planes and they don't seem to be modelled frequently.
Alan
Old Apr 29, 2010, 11:42 AM
redtail is offline
Joined Dec 2005
Alan
Hi Alan,
Yes,despite my little mishap lol! Wowplanes are very good kits and yes they do some very good subjects like the Marauder,this was my first foamy kit build,tell a lie and I built a foamy kit A7 Corsair from X-flight. You must have a little experience of building as alot of the decisions are left to the builder.I was rather gutted as it took me awhile to put my plane together,mind you we all have experience of righting planes off lol ! You just move on and build another plane. I should add Fahim of Wowplanes always emails you back with advice when you need it-excellent communication.
Old Apr 29, 2010, 02:02 PM
makemcool is offline
Find More Posts by makemcool
makemcool's Avatar
Lansing, Michigan
Joined Oct 2003
looks like there is a lot of down aileron. You should have aileron differential either built, or programmed in. { down aileron is MUCH less than up]. Especially with tapered wings, and high wing loading, down aileron produces high drag, and possibility of stall, causiing it to increasingly roll in the opposite direction you have input. I am building a highly tapered wing De Havilland Comet, with which I am VERY worried about this effect.
makemcool is offline Find More Posts by makemcool
Old Apr 29, 2010, 04:31 PM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
sorry for the loss...she was a beauty and hopefully she can be repaired...for multis, definitely check each motor's output with a wattmeter and rpm with a tachometer...
gunracer is offline Find More Posts by gunracer
Old Apr 29, 2010, 04:51 PM
Slider2732 is offline
Find More Posts by Slider2732
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
Although I have as much experience flying one of these, as I do with paint stripping oil tankers, i'm in agreement with makemcool's observation.
That's a lot of down aileron travel straight after takeoff...if anything, I would have expected to see almost zero deflection in this nearside one. Perhaps then I wouldn't have been studying the picture and have learned from this discussion though !
Or, as mentioned in the car earlier. Did you check the fluid level for the indicator lights ?
Best wishes for the rebuild/remake/redo
Slider2732 is offline Find More Posts by Slider2732
Old Apr 29, 2010, 11:37 PM
pookielips1954 is offline
Find More Posts by pookielips1954
Joined Aug 2004
I'm quite sure that's a tip stall - you mentioned it took off after a short run. Because of the accelerated airflow of the props over the wing, a multi to an extent generates it's own lift - over the inboard section of the wing. The outboard section, with the ailerons isn't quite flying yet. On the next one, make sure you have plenty of speed before lift-off.
The B-26 has a pretty high wing loading and isn't a park flyer. My HL B-25 exhibits exactly the same behavior if I horse it off the grass before it's ready to fly (I get off the up elevator pronto!)
BTW, there is no torque associated with a twin with wing mounted motors - torque acts along the centerline of the motors, and airplanes roll along their fuselage centerline. There is P-factor, at high angles of attack and high power settings, but that won't have any effect if you have flying speed (which in this case you didn't!) Sorry about the accident and I hope you build another, love the B-26 - keep 'em flying! Russ Farris
pookielips1954 is offline Find More Posts by pookielips1954
Old Apr 30, 2010, 02:33 AM
redtail is offline
Joined Dec 2005
Hi Russ,
And all the other guys who have given me advice on my maiden flight,I am definitley going to build another B26 as I have all the equipment to go in her.Russ,you had me thinking about my take off,I did throttle up fairly quickly and maybe put a little too much elevator as she leapt into the air.I'm so glad for peoples advice as I now have a better understanding of the dynamics.
Thanks again.
Paul Johnson - New Forest U.K
Old Apr 30, 2010, 05:50 AM
redtail is offline
Joined Dec 2005
Originally Posted by stacker View Post
redtail,
Hi Stacker,
Sorry about the late reply,I was using 2 x Eflite power 15 motors and 2 x Boss 26amp ESC all off one 11.1v 3900 3S battery.
Old Apr 30, 2010, 10:48 AM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
redtail,
Was there any undamaged parts? Maybe you can order just the damaged parts from Wow to save money and speed up the build. Might be able to cut on the fuse seam and re-glue new sections.
Take care -- Stacker
Old Apr 30, 2010, 11:11 AM
Larry076 is offline
Find More Posts by Larry076
Warbird E-Pilot / Hack Builder
Peoria, Arizona
Joined Feb 2009
I'd piece it back together, no mater how ugly, and make it fly. Then maybe build another airframe. When I see a plane flip over like that I fist suspect a stall which is made worse with aileron input. Maybe there is too much aileron travel. You neeed to get it up in the air and dialed in.
Larry076 is offline Find More Posts by Larry076
New Product B26 Marauder awrightbrother Scale Kit/Scratch Built 522 Jun 14, 2012 06:02 PM
Gallery My Wowplanes B26 seconds before it crashed. redtail Combat 7 Jul 24, 2010 06:34 AM
Discussion Wowplanes B26 Marauder 60 inch wing span. redtail Electric Warbirds 7 Apr 09, 2010 05:17 AM
Discussion EPF Hobby digital retracts-Wowplanes B26 Marauder redtail Electric Warbirds 5 Jan 03, 2009 06:01 PM
Discussion B26 Marauder or Ju88 Flyer88 Electric Warbirds 4 Aug 18, 2007 05:13 PM
