This thread is privately moderated by The_Builder, who may elect to delete unwanted replies.
Old Apr 28, 2010, 08:56 PM
Hey was that a Thermal ????
Joined Nov 2009
Blade Repair
The new Mystress wing is quite thin at the tips and as a result my old methods of mounting a blade kept coming loose. Here is the method I have settle on and thus far it has help very well.
I did lightly sand the wing tip prior to starting this. When the hard point was solid I applied a small patches to the bottom and top of the wing. Simply shape the patch, cut a slit in it and slide it over the blade. Saturate the patch with foam safe CA and pretty it up.
All done.
If this is an original install simply remove the top skin and foam. Slit the bottom skin and tape, slide the blade through and so on.....
Paul
The_Builder is offline Find More Posts by The_Builder
Old Apr 29, 2010, 05:48 AM
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
realtimerecon is offline Find More Posts by realtimerecon
New Product 2010 Mystress The_Builder Hand Launch 75 Apr 28, 2010 09:55 PM
Discussion 2010 Mystress Fuse The_Builder Composites Fabrication 4 Feb 28, 2010 05:10 PM
New Product 2010 Mystress Pod The_Builder Hand Launch 13 Feb 17, 2010 06:19 AM
Video Time with my Mystress Double Pappa Sailplane Talk 2 Jul 03, 2009 07:20 PM
