This thread is privately moderated by nxtee4509, who may elect to delete unwanted replies.
Old Apr 28, 2010, 08:37 PM
nxtee4509 is offline
Find More Posts by nxtee4509
Build, fly, CRASH, repeat
nxtee4509's Avatar
Hitchcock, Texas
Joined Nov 2006
Predator Drone
The Predator drone , MQ-1, MQ-9 , The Reaper . Ohhh now these are some bad @ss radio control planes. When I saw the plans and video of this UAV
foamie my interest was peaked. My builds are usually in the 30inch wingspan area but what the heck a 60 incher coudnt be to tough to build and fly for a blucore foamie.
The original plan calls for cutting the nose section out of solid foam. I used Google Sketchup instead and a plugin program to slice the image into 6 mm sections . These were printed out like a plan and I glued these sections to form the front pod.
This same technique was used to design the air intake. Although the front pod is a little bulbous or fat in my model someone could easily design a more scale or realistic plan using the same technique. And the same can be said of the air intake or any other cowling.
nxtee4509 is offline Find More Posts by nxtee4509
Old Apr 28, 2010, 09:10 PM
j3tman is offline
Find More Posts by j3tman
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
that uav looks really sweat do you have an onboard camera?
j3tman is offline Find More Posts by j3tman
Old Apr 28, 2010, 09:33 PM
nxtee4509's Avatar
Hitchcock, Texas
Joined Nov 2006
Have not gotten some bugs out yet. The wing is presenting some problems with washout.The plan designer recommends adding wing tips, similar I guess to what some gliders use. If this fix works and and some other adjustments tame this plane I would love to add a camera. The front pod section is completely empty.
Old Jan 06, 2012, 03:05 PM
alibehtarin is offline
Find More Posts by alibehtarin
Joined Jun 2011
hi , Please put the aircraft on the plan here . thanks
alibehtarin is offline Find More Posts by alibehtarin
Discussion Plans for Predator Drone, C-130, Edge 540, and More mitchrichie Foamies (Scratchbuilt) 44 Jun 09, 2015 05:25 AM
Discussion MQ-9 Predator Reaper Drone - 98" Span xplaneguy Giant Electric Planes 24 Mar 08, 2015 08:53 PM
Discussion Predator Drone with KF wing (With video) (with PLANS) grenadapult Foamies (Scratchbuilt) 134 Jan 05, 2015 05:56 AM
Discussion Predator Drone Prototype mitchrichie Foamies (Scratchbuilt) 42 Mar 02, 2010 12:30 PM
Discussion Predator Drone Plans Now Available mitchrichie Foamies (Scratchbuilt) 4 Mar 01, 2010 05:15 PM
