Old Jan 06, 2011, 11:37 AM
jumpy is offline
Find More Posts by jumpy
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Got the nose shaped today, made up from soft block balsa.
Phil
jumpy is offline Find More Posts by jumpy
Old Jan 10, 2011, 02:14 PM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Started making the 2 fan hatches, just taped over each end of where the hatch will be then start planking. When dry it should lift out while still retaining its shape ready for glasing, well thats the theory anyway!!
When thats done its a case of sanding down and then glassing the whole thing.
Phil
Old Jan 10, 2011, 03:43 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
you might want to mix a little bit of epoxy and thin it out with some alcohol, then brush a light coat over that panel, before you remove it. this will allow it to keep its shape better and can be sanded a bit to let you glass it later. just a thought.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 10, 2011, 07:04 PM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Good idea Rich, thanks.
Phil
Old Jan 10, 2011, 07:09 PM
Joined Jan 2009
anytime Phil.
Old Jan 11, 2011, 05:40 AM
Boogie_ is online now
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Good stuff Phil, keep the updates coming.
Julian
Boogie_ is online now Find More Posts by Boogie_
Old Jan 11, 2011, 02:30 PM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Will do Julian, I can see light at the end of the tunnel!!
Phil
Old Jan 22, 2011, 03:37 PM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Started glassing the wing tonight, never used this before so was a bit nervous to start but then got right into it. Hopefully get it finished together with all control surfaces in the next few days. Fuselage still needs alot more sanding yet
Phil
Old Jan 23, 2011, 11:06 AM
Joined Jan 2009
looks good to me Phil. if there are any dry spots after the glass is hardened, simply slit the cloth with a hobby knife, wick in some CA glue and press the glass down.........DONE!!!!!.
you are no longer a glass virgin. congrats. it looks very good.
Old Jan 23, 2011, 01:30 PM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Thanks Rich, starting to like this method. Iv'e noticed a couple of small spots which look like air bubbles, presumably i'll just slit them like you said and stick down. Got the underside done tonight.
Phil
Old Jan 23, 2011, 02:01 PM
Joined Jan 2009
looks good.
Old Jan 23, 2011, 04:48 PM
Boogie_'s Avatar
Joined Jun 2009
Lookin' good there Phil. Great work on the fiberglass.
A FG finish has this big mystique about it but once you do it, it's a piece of cake. And the results will make you stand out at the field.
Julian
Old Jan 25, 2011, 06:25 AM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Julian
Yep, definately got the 'fibreglass bug', as far as results are concerned, one can only asspire to the levels that you have acheived with yours. It must take alot of patience, something i unfortunately don't seem to have.
Phil
Old Jan 25, 2011, 08:14 AM
Boogie_'s Avatar
Joined Jun 2009
Nah, I wouldn't call it patience. More like, "I took 2-3 months to build it, why rush the finish."
One tip I can give you, coming from an auto body background, get it out of your head that it's only going to take one series of primer/putty/sanding to make it slick. And work with fairly coarse sandpaper (#180-ish) until your ready for the final sanding (#400) before paint.
Julian
Old Jan 25, 2011, 08:39 AM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Gotcha.
Phil
Discussion SU25K Frogfoot jumpy Scratchbuilt EDFs 106 Jan 03, 2011 12:14 PM
Question SU25 Frogfoot jumpy Electric Ducted Fan Jet Talk 28 Mar 09, 2010 04:22 PM
su-25 frogfoot Robbie d Electric Ducted Fan Jet Talk 7 Dec 03, 2009 10:02 AM
Sukhoi 39 Frogfoot Neil Straker Pusher Prop Jet Models 108 Sep 14, 2005 10:15 PM
EDF50 SU25 Frogfoot jah Electric Ducted Fan Jet Talk 46 Mar 26, 2002 06:11 PM
