Old Sep 05, 2012, 07:31 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
almost done With the Gear Cad Stuff (the gear is very.... F-16 like just longer..)
Keenan smith is offline Find More Posts by Keenan smith
Old Sep 05, 2012, 10:03 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Nice. That's awesome K. How's everything going?
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Sep 05, 2012, 10:17 PM
Joined Dec 2010
good
Old Sep 06, 2012, 01:27 AM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
That is a beautiful bird! I purchased some of the Styro Spray 1000 from Polymer Industries in Houston Tx. I understand that it is the same product that Wow Planes sells. I have only used it once but it is a great product. There was a learning curve involved with getting the right humidity during application but after a good sanding with my mouse sander it left a very smooth and durable finish, and relatively light.
Lt599 is offline Find More Posts by Lt599
Old Dec 03, 2012, 11:11 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Jaguar, Jaguar,Jaguar. . . .XKE converible. . . .lolJust kidding the plane!. . .can't wait for more sepacat updates.
demondriver is offline Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Dec 04, 2012, 04:37 PM
Joined Jan 2009
the project has been re-started Chris. I'm just waiting to receive the CAD files for the fuselage and landing gear and I can get going on the those items. what is happening at the moment, is the wings are being constructed. I won't be posting any pics for a week or two, because I want to get the construction technique correct before I post anything. there's really not much to post anyway, since it's all dry fitting at the moment. I'll post some pics as I've got something solid to post.
basically, it's two spars that will be in an FG/foam/CF composite sandwich, or I may substitute ply for the foam. I've made a test piece to see how the foam holds up to a weight test in both compression and tensile strength. if it doesn't hold up to at least 200 lbs of weight applied, I won't use it. this equates to about 7G's of loading on the spars.
Old Dec 04, 2012, 04:52 PM
Joined Jan 2009
once I've found the best solution for the job, I'll get to work on assembling the wings.
not sure I've informed everyone, but I've changed direction with this build. I won't be doing a plug and mold for the time being. it will be a construction technique similar to the Chimera build and other builds by Frank, Claus, D-Fast, unclecrash and others. I already have the templates cut out for this method, but I'm waiting on more accurate CAD templates for this and we'll see how accurate my drawings were. I know I'm accurate, but let's face it, CAD is gonna be better, so may as well use it.
bottom line is, I couldn't keep going as it was. I was stressing myself out and had to let it go. kitting a plane at this juncture of my life is just plain crazy, so it's gonna be a one-off..........................for now. I just don't have the inclination, or the monitery means of building a plug and mold. so I'm gonna do a hotwire and FG shell, and it will most likely be powered by a single, 120mm fan, or a Dynamax. a twin would be cool, but that will be later. I am also thinking that it won't have intake ducting either. I'm thinking open intakes, with a bellmouth inlet on the fan. this should also give a lovely, whooshing sound with all that open fuselage. I'm not looking for a plane to win a speed contest, just something that flies very scale-like and can also move out when the throttle is pushed further. so, we'll see where this goes over the winter. I'll post pics when I have something worth posting. till then, I'll keep an update going.
Rich
Old Dec 04, 2012, 06:24 PM
TANGOSIERRAROM is offline
Find More Posts by TANGOSIERRAROM
James L
TANGOSIERRAROM's Avatar
Beck Row Mildenhall
Joined Mar 2009
Rich that is interesting why did you pick 7g have you worked out that this is maximum rate the airframe will produce or is it figure you think you will never fly beyond?
If an aeroplane is flying at stalling speed, then its wing is at its maximum lift coefficient.
Keep it at the angle for CLmax but increase speed by a factor of 3 that means that the lift generated increases as the square of the airspeed, factor of 9
So to work out the maximum g a plane can experience in an unstalled condition we can say that it is the the square of (max air speed/stall speed) so if it flies at 3 times the stall speed then a max rate turn will put 9g on the airframe. This is not an absolutely accurate method but it is very close to it and easy to work out.
With full size the pilot experiences the load and to sme extent he regulates it. As modellers we do not have that luxury so we need to be stressing big models to accommodate the maximum load that the aeroplane can generate.Largely because a 9g turn with a big model can still look nice and smooth just danged fast,
TANGOSIERRAROM is offline Find More Posts by TANGOSIERRAROM
Old Dec 04, 2012, 08:43 PM
Joined Jan 2009
oops, I meant to type 9G. I figured if I could get the spar to about 9 times the weight of the aircraft weight, for stresses, then it should be ok with the rest of the structure to add even more rigidity. sound thinking!? I dunno, but it sounds like it should be about right. I figure the plane should weigh less than 20 lbs RTF, so if the spar could withstand about 200 lbs of weight stress, then it should be in the right ballpark. personally, I don't think the foam is going to cut it, but I will try both and see what gets the best results.
Rich
Old Dec 04, 2012, 08:44 PM
Joined Jan 2009
here's a cool vid of the main gear. hope it loads
Joined Jan 2009
nice. it loaded. just click on the picture and it'll redirect you to play the movie.
Old Dec 05, 2012, 03:13 AM
jumpy is offline
Find More Posts by jumpy
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Hey Rich hows tricks? Nice video, glad to hear you haven't given up on the Jag, with your knowledge and experience im sure it will work out fine how ever you decide to build it. I was kind of hoping you were going to make a plug so i could follow your method and apply it to my 'froggy', looking to do a plug aswell. Good luck and look forward to updates.
Phil
jumpy is offline Find More Posts by jumpy
Old Dec 05, 2012, 10:01 PM
Joined Jan 2009
Phil, if you want to follow the method I will eventually follow, just go to either the F-14 thread, or the Horton 229 thread by Invertmast. it's about as simple and to the point as it gets. Thomas is an awesome guy and will help you with any questions you may have. in fact, he will even follow your thread and give you pointers on there, if he isn't already on your thread.
Rich
Old Dec 05, 2012, 10:02 PM
Joined Jan 2009
how's things over there in Cornwall? not as cold as it is here, I bet. LOL.
Old Dec 06, 2012, 12:22 AM
Up-Out-&-Gone
Joined Mar 2007
Nice Jag Gear video Rich. . . .Sepecat really had to fit some tough carrier like landing gear into a very small space. . . . .I can't wait to see how you will tackle those gears in RC form.
Build Log Binder EB29 1/4 scale 7.3 meter scratch build yyz Scale Sailplanes 564 Dec 13, 2010 09:09 AM
Build Log 7th Scale Jaguar Build LuvEvolution7 Electric Ducted Fan Jet Talk 145 Apr 26, 2010 05:49 PM
Discussion SEPECAT Jaguar JDM71 Pusher Prop Jet Models 18 May 19, 2006 01:25 AM
sepecat jaguar nhoj62 Electric Ducted Fan Jet Talk 25 Sep 04, 2004 02:50 PM
Sepecat Jaguar PJF Electric Ducted Fan Jet Talk 2 Oct 25, 2001 09:20 AM
