Espritmodel.com Heli Air
Old Jun 23, 2001, 06:19 PM
Professional Goofball
OCModels's Avatar
United States, WA, Port Orchard
Joined Dec 2000
How Do You Charge Your Nimh Packs?
I purchased a new 8cell 120mAh Nimh pack and placed it onto my FMA Supernova charger to charge the pack up. I cycled the pack three times and could only get about 80mAh out of it. I placed it back on the charger and tried a couple more times but could not get any more than the original 80mAh. I have the charger set for Nimh, 8 cells at 150mAh, a charge rate of 100mAh and a discharge rate of 500mAh. I can't figure out what I could be doing wrong? I understand that Nimh take a few cycles to get to full capacity but after about ten cycles I still can not get anywhere near 120mAh. When I plug the pack into the plane and run it up it seems to be lacking in power too. I run a 6 cell Nicad pack and I get more rpm’s from the motor. I contacted the dealer and he said to send the pack back but if I am doing something wrong I don't want to send it back and have them charge it up and find nothing wrong with the pack. I would really like to get this thing to work. Any help would be greatly appreciated...
Thank you,
Jeffrey Park
OCModels is offline Find More Posts by OCModels
Old Jun 23, 2001, 07:14 PM
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
You should perform a slow charge for 12-14 hours at .01 amps to equalize the cells in the pack. You probably are having cells peak before others. When you discharge it (run motor) you notice the weak cells.
Good luck!
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Jun 23, 2001, 07:38 PM
OCModels's Avatar
Joined Dec 2000
No can do! I don't have a charger that goes down to .01 amp nor do I know of one that does. I am charging the pack with an FMA Supernova charger and do not want to have to buy another charger just to charge Nimh packs. If that is the case I will be sticking with Nicads.
Jeffrey Park
Old Jun 23, 2001, 08:42 PM
rscamp's Avatar
Dundas, ON Canada
Joined Feb 2001
Jeffery.
You are discharging at about 4C. I would think this would lower your discharge voltage and cause an early termination of your discharge cycle (cut off is usually about 0.9V/cell). The impedance of small NiMh cells would be pretty high.
I'm betting at a lower discharge rate you will achieve the 120 mAh capacity.
Rob
rscamp is offline Find More Posts by rscamp
Old Jun 23, 2001, 08:55 PM
OCModels's Avatar
Joined Dec 2000
Originally posted by rscamp:
Jeffery.
Rob
How can that be too high? The motor on my plane draws little over one amp. 500mAh would be about half what my motor is pulling.
Jeffrey Park
Old Jun 23, 2001, 09:12 PM
Austin, Texas USA
Joined Mar 2001
Smaller NIMH cells have a high internal resistance.
Are you sure that these cells will pull a 1 amp load? I doubt it. That is a 10C discharge, and even the best AA size (Sanyo 1600 Twicell) are at their limit at 16 amps (10C). At lower discharge rates you should get better than 80 mah. Can you discharge at less than 500 mah?
Just out of curiosity, why did you choose this particular cell/pack? Did anyone recommend it or have experience with it at these loads?
Shawn
<a href=http://www.eflightpower.com>Eflightpower.com</a>
sf_247 is offline Find More Posts by sf_247
Old Jun 23, 2001, 09:53 PM
rscamp's Avatar
Dundas, ON Canada
Joined Feb 2001
Jeffery.
These are very small NiMh cells. Their internal resistance would be high enough to cause a relatively large voltage drop at .5A, let alone 1.0A.
You have already noticed that you are getting more power from your NiCds. In light of this, why would my previous message surprise you?
Cheers,
Rob
Old Jun 23, 2001, 10:06 PM
OCModels's Avatar
Joined Dec 2000
OK! I can understand that but why am I not getting a full pack when I charge it and why would it be so much Less than a 6 cell nicad pack??? I would think I would at least get the same if not better performance from an 8 cell Nimh pack. Am I wrong in assuming this? I went to 2 more cells to gain performance not lose it...
Jeffrey Park
Old Jun 23, 2001, 11:07 PM
Rxb
Olympia WA U.S.A.
Joined Apr 2001
Are you using the auto charge setting on the FMA Supernova? The instructions tell you not to use it on NIMH packs just Nicad.
Rob
Rxb is offline Find More Posts by Rxb
Old Jun 23, 2001, 11:18 PM
OCModels's Avatar
Joined Dec 2000
I rarely use the auto feature on this charger any more. I like being able to control the charge of each pack.
Jeffrey Park
Old Jun 23, 2001, 11:37 PM
Austin, Texas USA
Joined Mar 2001
To further clarify - The "capacity" of cells are given at a certain current. As that discharge current goes up, the usable capacity goes down. The 500 mah discharge may be very high for these cells and they can not perform at these levels.
Try a lower discharge and see if the numbers improve any. If so, then they are being pushed too hard.
Shawn
Eflightpower.com
How do you charge your big Lipo packs? Rainman-ACRF Batteries and Chargers 14 Dec 27, 2005 04:27 PM
How do you Charge your LiPo Packs II RD Blakeslee Batteries and Chargers 15 Dec 15, 2004 05:21 AM
How do you charge your LiPo packs? RD Blakeslee Batteries and Chargers 26 Aug 26, 2004 08:00 PM
How do you Charge your Li-Pos for your Heli ? mdttb Micro Helis 2 May 07, 2004 07:43 PM
How do you charge your Litestick batteries? mrebman Parkflyers 1 Jun 25, 2001 07:48 PM
