Old Apr 25, 2010, 07:54 PM
kd7jz is offline
Find More Posts by kd7jz
Joined Aug 2009
slow stick brushless mount
Hi All;
Somewhat new to the hobby, building my 2nd lane, a GWS Slow Stick. I bought a brushless motor (a Motrolfly 2205-1350 from SubSonic), but I am having trouble working out the motor mount. It is really made for mounting on a firewall. It is about 32mm across the mounting arms. The mount I bought for the SS is only about 25mm inside clearence, so I have rigged up a firewall with some thin plywood, but really don't like it. Is there a proper mount available somewhere for this type of motor on a Slow Stick?
Thanks!
Tim
kd7jz is offline Find More Posts by kd7jz
Old Apr 25, 2010, 08:15 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Pick your flavor:
http://www.millenniumrc.com/MotorMount.html
Xpress.. is offline Find More Posts by Xpress..
Old Apr 25, 2010, 08:28 PM
kd7jz is offline
Joined Aug 2009
I found those, almost the same as what I have. The mounting holes on the Motrolfly are 29.5mm. Do you know the maximum distance on the millenimum mount from the end of one slot to the other?
Tim
Old Apr 26, 2010, 09:25 AM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Can you remove the motor Xmount and then mount directly to your mount from the rear?
bartricky is offline Find More Posts by bartricky
Old Apr 26, 2010, 09:43 AM
kd7jz is offline
Joined Aug 2009
I hadn't considered that.. I will take a look.. thanks.
Old Apr 26, 2010, 10:09 AM
eliworm is offline
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
Check out these from David at http://www.blueskyrc.com/index.php?m...8d33966e960d86
I laser these out for him. We have been flying them for about a year now and have been holding up real well.
Jim
eliworm is offline Find More Posts by eliworm
Old Apr 26, 2010, 10:12 AM
kd7jz is offline
Joined Aug 2009
Thanks.. that looks pretty cool. I could put a washer under the upper right X leg to give it the down and right that it needs.
New Product Laser-Cut Slow Stick Camera Mount Qrome Aerial Photography 23 Aug 07, 2010 11:17 PM
New Product Sky Surfer, Easy Star & Slow Stick Camera mounts crd Aerial Photography 21 Jul 29, 2010 06:01 PM
Wanted Looking for brushless Slow Stick setup RC Sumo Aircraft - Electric - Power Systems (FS/W) 11 May 01, 2010 08:39 AM
Discussion Brushless Help - Slow Stick ehooper Power Systems 3 Apr 19, 2010 08:13 PM
Alert Slow Stick Camera mount and landing gear for sale - cdi3d Aerial Photography 3 Oct 05, 2009 04:17 PM
