Old Apr 25, 2010, 05:35 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Build Log
The BD-5 ---edf 70mm
As it is not finished yet it should be here in its own build log.
it is not a tested way of building but i like to go to the edges, to see how far we can push things.
we have minimized the thicknes of the foam core to 6 mm ( less than 1/4 ") and it looks ok even to work with but with one limitation.. one have to have the glass inside before sanding the outside to finished shape.
the foam we have used is 4 inch thick, and a template at each side to cut it
cutting is started with biggest outside first and smallest inside ... then the "chease cutter" to correct the "difference" working out from the middle to the edge.
our 14 days of work acivement.
Ron and Claus
at area 52
clausxpf is offline Find More Posts by clausxpf
Old Apr 26, 2010, 01:34 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
great!
I built the BD-5 from parkjets.com.
Your version looks so much better! You just inspired me to get started on a new project
kimhey is offline Find More Posts by kimhey
Old Apr 26, 2010, 06:17 AM
Glong-flyer is offline
Find More Posts by Glong-flyer
Glong-flyer's Avatar
Ballarat, Australia
Joined Jan 2007
Very nice work keep it up
Pete
Glong-flyer is offline Find More Posts by Glong-flyer
Old Apr 26, 2010, 09:23 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
todays installation of the ducting and the fan unit.
having all the parts done there was only to put it in the plane with glue for the final placement. It worked out pretty well and simple.
Old Apr 26, 2010, 09:54 AM
eatond is online now
Find More Posts by eatond
EDF Jet Jam 2017, June 15-18th
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Claus,
What weight cloth are you using on the inside? Are you using epoxy or WBPU to coat the cloth?
I'm interested in trying this technique but too much in the queue right now to get to it.
Dan Eaton
eatond is online now Find More Posts by eatond
Old Apr 26, 2010, 11:55 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Dan
I am now using 49gr/m2 ( 0.16oz/feet2)
i have tried the wbpu but it is hard to keep in place and the cure time for the real stregth is long, so now i am using airplane grade epoxy, it is a little more sticky and one more thing i cut the pieces into 8 inch wide bands with a ½" overlap to make it easy to get in place.
a little extra trick is the 3M replaceble spraymount on the fiberglass to hold it in place on hard to do forms.
1/4 " foam thickness is what it takes to make "timber" when it is glassed both sides.
but do not try to sand the outside to shape before the inside glass have hardened.
Claus
at area 52
Old Apr 26, 2010, 12:56 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Nice project Claus.
Your NACA ducts look good. The lip on the back edge can be cut back and rounded more if you need more static thrust. Don't expect miracles though. Mine doesn't do too well until it's flying.
Steve C
Steve C is offline Find More Posts by Steve C
Old Apr 26, 2010, 01:16 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Steve
i am well aware of that! My work with the Windrider model of BD-5 have shown to me that there is gain in doing the inlet propper, even only modiffiing the the stock one.
Claus
Old Apr 26, 2010, 09:00 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
very nice Claus ...im trying to get the Draken Thread moved over here. hows the Draken going ?
AIR SALLY is online now Find More Posts by AIR SALLY
Old Apr 27, 2010, 05:22 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
this is next to speed building.
just a few updates on the project.
Old Apr 28, 2010, 05:29 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
I already thought on previos pics this is a big plane. 70mm fans can have 90mm edf sized jets easely.
good work!
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Apr 28, 2010, 11:25 AM
KenSt is offline
Find More Posts by KenSt
Scratch builder
USA, PA, Telford
Joined Apr 2004
Hi Claus!
Does the inner duct walls seal around the motor?
Will the low pressure in the duct pull cooling air through the motor?
KenSt is offline Find More Posts by KenSt
Old Apr 28, 2010, 12:37 PM
fltlevel450 is offline
Find More Posts by fltlevel450
fltlevel450
Georgia
Joined Dec 2006
no seal to the motor to the inner duct sides.
the way WM 400 is done with cooling of the outside of the motor through the airgab between the housing and the motor, ending right in front off the fan..means suction from through the the not sealed inside "walls" als well as through the motor.
this one is not pure perfect but will work ok.
Claus
at area 52
fltlevel450 is offline Find More Posts by fltlevel450
Old Apr 28, 2010, 05:15 PM
CARL SCHIMNOWSKI is offline
Find More Posts by CARL SCHIMNOWSKI
Joined May 2007
Claus very interesting 70mm build. I really like the BD5j version. Will there be plans or drawing available for this size aircraft, or even 90mm edf
Carl
CARL SCHIMNOWSKI is offline Find More Posts by CARL SCHIMNOWSKI
Old Apr 28, 2010, 06:47 PM
fltlevel450
Georgia
Joined Dec 2006
Carl .
lets have it into the air first then we can talk.
Claus
Article Windrider BD-5 EPP - EDF Version Bajora Foamy EDFs 27 Apr 14, 2011 11:45 AM
Build Log Windrider EPS EDF BD-5 to sloper conversion suirendoujin Slope 15 Sep 11, 2010 10:19 PM
For Sale NIB Starmax F-5 70mm EDF ARF earaoz Aircraft - Electric - Jets (FS/W) 8 Apr 04, 2010 01:39 PM
Wanted info from a guy that was at Perry, GA with a 3rd scale BD-5 EDF jet RTF for sale mechengineer03 Aircraft - Electric - Jets (FS/W) 3 Mar 09, 2010 01:22 PM
Discussion BD-5 EDF 90 mm Glass fuse OzparkPilot High Performance 5 Jan 19, 2010 01:36 PM
