Surrey, UK
Joined Oct 2010
Here is a video to demonstrate my point. Don't try it on real heli.
http://www.youtube.com/watch?v=BZOSJz8MX7s From my experiences (I make games for living), it looks like huge control lag/not enough resolution on the controls. I am using no expo anywhere. I just got response from nice people at Phoenix. The advised to change frontal/lateral cyclic to 0.3 under flybar and that did help (I put it on 0.25, 0.3 was too much). Turning off VSync helped a lot with that underwater feeling as well. |
Surrey, UK
Joined Oct 2010
Yes, Fraps, record your flight, then fraps it
United States, FL, Ocala
Joined Nov 2010
Well I had my first real lesson with Captjac yesterday and all I can say is WOW!
First, Captjac really knows his stuff. I spent a lot of time on the net looking for info on setting up and using Phoenix, the info available doesn't hold a candle to Captjac's knowledge and experience. This alone should be enough to start taking lessons with him. His experience as a teacher really shows - he makes you feel relaxed and has a great sense of humor - all positive attributes for an excellent teacher. I tried to list a few pros and cons as to using Phoenix Flight Sim and Captjac's training. Cons: Pride - you think you know it all or you think you can learn on your own. Cost($) - you have very deep pockets and can afford to constantly be replacing parts. Cost(time) - you love to rebuild your heli more than flying, like to take a long time to master flying helis. Frustration - You love and thrive in a frustrating environment - and are willing to quit! Pros: Cost($) - Getting Phoenix will far out weigh the cost of repairs. Cost(time) - you will be flying your heli of choice quickly! Just the time to properly setup your heli and Tx are worth spending time with Captjac. Cost(Experience) - I have no idea how folks before us had learned to fly without a simulator. Pure trial and error is nothing more than pure and simple frustration! My Experience: After my first lesson Captjac had my heli and Tx tuned perfectly. I learned how to properly lift off and land using a Trex 500 and DX7. (I just finished building a Tarot 500 but won't try flying it until I get a few more lessons under my belt) And to top it off I was doing figure 8's - Incredible! - something I thought I wouldn't be doing for a long time! This may sound like an advertisement for Phoenix and Captjac - it isn't, I have absolutely no affiliation with either party. This is my own personal experience. So if you're sitting on the fence about taking the plunge into a flight sim and training don't hesitate, go get Phoenix and lessons with Captjac and enjoy yourself - you'll have a blast! |
I do not think it's worthwhile to try to get the simulator helis to fly like the real ones. You need to learn to fly helicopters in spite of their differences in performance. As long as the simulator is simulating realistic helicopter behavior, it will be beneficial as a training tool, regardless of how it compares to your real helis in terms of performance. In this case, I think the 250 is so far off, it's crossed the line into unrealistic land. |
Surrey, UK
Joined Oct 2010
, but only in place, not in froward flight/drift and a bit less stick movement ).Try to turn Vsync off and see if you can feel a difference. I do (maybe placebo effect, but I still do) |
With Vsync on, you're getting about 60 frames per second - this affects the physics. For each frame, the entire physics model is calculated. If the time between frames is large, then the calculations are less precise. However, if the time between frames is too small, you approach the precision limits of the machine, and again you can see errors. So yes, turning on and off the Vsync makes a physics difference. However, Phoenix should be happy with frame rates of 30 to 60 per second. Possibly with the Vsync off, you're getting such a high frame rate that it's working with very small numbers and calculations are failing due to zeros popping up internally.
-----------------------------------------------Keep those rotors spinning ![]() captJac |
Centreville, Va
Joined Nov 2010
I have phoenix 3.0 installed and have been practicing hovering with my DX7.
My question is does it matter that I have the model set up as acro (plane). I use these settings for my blade, mcx2,cx2,msr and sr 120 and do fine. I am trying to move into CP heli's. I have Walkera V400D02 in 2 attempts to hover the heli takes off on me resulting in a crash. ( 1st one broke off the tail motor holder, 2nd busted blades, stripped main gear, ball links broke etc.). I know I need more sim time but should I be setting up my radio in heli mode? Mike |
| Thread Tools | |
| Wanted phoenix Simulator W/DX6i adapter | -S- | Aircraft - General - Miscellaneous (FS/W) | 0 | Mar 06, 2010 06:46 PM |
| Sold gone | hacker002 | Aircraft - General - Miscellaneous (FS/W) | 0 | Mar 05, 2010 10:57 PM |
| Wanted phoenix simulator-paypal ready | hoehnelli | Aircraft - General - Miscellaneous (FS/W) | 1 | Mar 03, 2010 07:15 PM |
| Discussion I need help on flying sailplanes in Phoenix RC simulator | racin06 | Sailplane Talk | 2 | Oct 25, 2007 07:26 AM |
