Old Apr 25, 2010, 05:28 PM
Finrotor is offline
Find More Posts by Finrotor
Joined Mar 2010
Question
How to calculate the values for multiple motors based on Drive Calculators results?
Hey!
Sorry for staring a new thread if there's an answer to my question elsewhere already.
We are starting a student project with a quadrotor: http://www.rcgroups.com/forums/showthread.php?t=1202361
and we are trying to define the right components for the quad.
The Drive Calculator doesn't have an option for multiple motors/rotors, so can somebody tell me how is it possible to calculate the change of flying time when adding three more actuators on the system?
Oh, and how does the thrust change? I don't think it's just 4 x thrust of one actuator, cause the battery load changes.
Thanks a lot!
Finrotor is offline Find More Posts by Finrotor
Old Apr 26, 2010, 01:30 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
It won't be quite 4 times the thrust because (as you guessed) the battery's voltage drops more. So... just choose a battery with the same C rating but 1/4 capacity, then Drivecalc will give you a more accurate value.
If that's too confusing then download Motocalc, which does handle multiple motors.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Apr 26, 2010, 08:14 AM
Finrotor is offline
Joined Mar 2010
So if I pick a battery from the database and make a new version based on it, I'll just change the capasity by 1/4 and the battery weight, for example:
Original battery: XCell 5000 (30C) 3S
Imax = 100A
Imax short = 150A
Capacity = 5000 mAh
Weight = 375 g
Ri = 2,5 mOhm
Cell voltage = 3,7 V
Modified battery: XCell 5000/4 (30C) 3S
Imax = 100A
Imax short = 150A
Capacity = 1250 mAh
Weight = 145 g (approximation)
Ri = 2,5 mOhm
Like so? With this modified battery the max thrust value is exactly the same as it was with the 5000 mAh battery, so is it only dependent of the C number?
Old Apr 26, 2010, 08:57 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Changing the capacity also changes max current and Ri. A 20-30C 1250mAh battery would only have Imax of 25A/37.5A. Ri will also be higher, likely around 10 mOhm.
Steve
slipstick is online now Find More Posts by slipstick
Old Apr 27, 2010, 06:21 AM
Finrotor is offline
Joined Mar 2010
Thank you both very much!
I'm allowing myself to go offtopic on my own topic.
I also tried the MotoCalc to compare the results and I ran into this problem: the calculated flight time doesn't change when I add or reduce the weight on the airframe, how come? Does it have something to do with the fact that I didn't add any values to the wing span or the wing area fields ('cause it's a quad)?
Old Apr 27, 2010, 08:27 AM
Staffs, UK
Joined Nov 2003
The flight time won't change because the weight changes. It's still the same motor, prop and battery drawing the same current so why would the run time change ?
What changes are the flight characteristics, speed, climb rate etc.
Steve
Old Apr 27, 2010, 09:44 AM
Finrotor is offline
Joined Mar 2010
Yes of course, if the program calculated the hovering time, then the weight would matter.
Old Apr 28, 2010, 12:14 AM
Joined Jan 2001
To calculate hovering time, back the simulated throttle off until static thrust is 10% greater than weight (the extra 10% is to account for propwash pushing the model down).
Old May 05, 2010, 04:45 AM
Finrotor is offline
Joined Mar 2010
Steve
Ri is the internal resistance of the battery, right?
Is it getting bigger only because the Ohm's law: R=V/I, so if the current drops to 1/4 then the resistance rises to 4xR?
Old May 05, 2010, 08:49 AM
Joined Jan 2001
Yes.
No. Ohm's law works on the principle that resistance is a constant, ie. not affected by current. The internal resistance of a battery is largely a function of electrode size (surface area, thickness) so a smaller battery will have higher internal resistance.
If it were possible to cut a Lipo battery in half to make two smaller batteries, the internal resistance of each half would be double that of the original battery. If you then wired these two halves in parallel, the combined resistance would once again be equal to that of the original battery.
Old May 05, 2010, 10:13 AM
Finrotor is offline
Joined Mar 2010
So if I'm trying to simulate the situation where the Drive Calculator uses four motors insead of one, I'll just divide the capacity, Imax, Imax short and the weight of the battery I've chosen by four:
Original battery: XCell 5000 (30C) 3S using one motor
Imax = 100A
Imax short = 150A
Capacity = 5000 mAh
Weight = 375 g
Ri = 2,5 mOhm
Modified battery: XCell 5000/4 (30C) 3S using four motors
Imax = 25A
Imax short = 37,5A
Capacity = 1250 mAh
Weight = 93,75
Ri = 2,5 mOhm
Is this correct? (Please say yes)
Old May 05, 2010, 02:14 PM
Staffs, UK
Joined Nov 2003
What do you think ? Bruce says if the battery was half the size the internal resistance would be double. I said (as the equivalent battery is 1/4 the size) "Ri will also be higher, likely around 10 mOhm".
It would be a lot easier to just use Motocalc.
Steve
Old May 05, 2010, 04:50 PM
elecfryer is offline
Find More Posts by elecfryer
The 6 P principle works for me
elecfryer's Avatar
United States, CA, Camarillo
Joined Aug 2007
To the best of my knowledge drivecalc is more accurate (real world) than motocalc (I usually use motocalc) however, both will get you in the ballpark, i.e. within 5%-10%. Not all props work the same, different brands of batteries = different resistance, different connectors and different gage wires, so on and so forth. Get close and go for it! If you have the equipment, check amps/volts/watts in prior to flying. Sometimes just changing the prop (or 4 in this case) can make a big difference. The secret to electric flying is "Matched Components". Thats my story and I'm a stickin to it!
Michael (if your not fryin, your not tryin!)
elecfryer is offline Find More Posts by elecfryer
Old May 05, 2010, 05:17 PM
Joined Jan 2001
Imax = 25A
Imax short = 37,5A
Capacity = 1250 mAh
Weight = 93,75
Ri = 2,5 mOhm
No. The battery is now 1/4 the size, so Ri must be 4 times higher, ie. 10 mOhm.
Old May 06, 2010, 03:45 AM
Finrotor is offline
Joined Mar 2010
But the battery is not 1/4 the size, but it's the same old size battery simulating the use of four motors. Why would the resistance change in that situation?
slipstick:
This is not about what would be the easiest way, It's about understanding this whole thing.
Discussion How to Calculate a set up for F5J and FXJ (heihgt limited) Edwinzea Electric Sailplanes 17 Mar 17, 2010 10:23 AM
Question How to Calculate a set up for F5J and FXJ (heihgt limited) Edwinzea High Performance 1 Mar 14, 2010 04:34 PM
Discussion how to calculate lift on airfoil b-29er Modeling Science 4 Oct 08, 2009 07:28 PM
Cell values for motor calculators KatManDEW Batteries and Chargers 2 Mar 12, 2004 09:17 AM
How to calculate the gear ratio for a gear box with teeth on the inside. sn1973 Foamies (Kits) 5 Oct 02, 2002 09:04 PM
