Old Apr 27, 2010, 04:59 AM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
Iím excited
Hardware coming very soon
chaosMurphy is offline Find More Posts by chaosMurphy
Old Apr 27, 2010, 08:46 AM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
Can I get some of you guys to try this test with your ArduShield? I wondering if this is a soldering problem on my end or if we need to add some more wires to the shield...
You'll need your ArduShield, ArduPilot and a multi-meter where you can test continuity (Ohms). Plug your shield into your pilot and then touch one probe to the purple connection on source 2 and then touch all the other purple and red connections.
Then touch the cyan circle on source 2 and touch all the other cyan and yellow connections. Please post your results like those shown below:
From Source 2 - Purple to:
Source 1 - Purple - Good Connection
#1 - Red - No Connection
#2 - Red - No Connection
#3 - Red - No Connection
From Source 2 - Cyan to:
Source 1 - Cyan - Good Connection
#1 - Yellow - Good Connection
#2 - Yellow - No Connection
#3 - Yellow - Good Connection
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Apr 27, 2010, 11:17 AM
jon davies is offline
Find More Posts by jon davies
S. Wales
Joined Jun 2008
Have you decided whether the shield is actually needed for the AP?
Jon
jon davies is offline Find More Posts by jon davies
Old Apr 27, 2010, 11:23 AM
Brunswick, OH
Joined Nov 2005
Jon
No, but I believe the code makes use of the pressure sensor to determine throttle. Without it, the ArduPilot would just have to use a fixed throttle setting. So "needed", no. Preferable, I think so.... I'll find out in Step 4....
I'm hoping to get step 2 posted today.
Old Apr 27, 2010, 11:42 AM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Hi HK,
here are my results.
Ardupilot with V2 shield: I confirm your readings, but
Ardupilot with V1 shield:
#1 - Red - Good Connection
#2 - Red - Good Connection
#3 - Red - Good Connection
Strange is that on V1, 5V GPS connector has TX-RX-5V-Gnd, instead of V2 IN-OUT-5V-Gnd.
3V GPS connector has RX-TX-3V-Gnd, that match with V2 IN-OUT-3V-Gnd.
Don't know if this could be of interest, but it sounds a little strange to me.
Hope this will help a little,
chilo
chiloschista is offline Find More Posts by chiloschista
Old Apr 27, 2010, 12:12 PM
Brunswick, OH
Joined Nov 2005
Thanks! My V1 readings are the same as yours
I'm working on my step 2 instructions right now. I have figured out a solution to the GPS lock problem with the V2 shield. If you jumper the source 2 purple to the #2 red it goes solid and locks no problems. I put a detachable connector on it to confirm and sure enough. When it's connected, lock, disconnected, no lock.
Old Apr 27, 2010, 05:44 PM
johann123 is offline
Find More Posts by johann123
GRAVITY SUCKS
Australia, WA, Perth
Joined Apr 2010
Originally Posted by AndrewBurns View Post
I have all of the things needed and I'm very interested in getting this working
Is the ublox GPS recommended by Ardupilot better than the one included with remzibi? Could somebody make a revision to the remzibi firmware to allow it to use the ublox protocol.
Will there be a firmware revision in the future to provide an artificial horizon? If Ardupilot is feeding in data from the IMU the roll and pitch angles would be available to the OSD and I'd love an artificial horizon option.
HappyK
Correct me if I am wrong, but I remember reading somewhere that Remzibi did release a firmware set with artificial horizon already.
johann123 is offline Find More Posts by johann123
Old Apr 27, 2010, 05:51 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
The ArduShield "Kit" includes a Pitot Tube, the wiring between the shield and the sensors (we don't need that) and a toggle switch (which I have not used so far).
Can we source the pitot tube elsewhere if we don't need the rest? Seems like an expensive $20 tube... Is there anything special about the rest of the kit?
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Apr 27, 2010, 06:51 PM
Brunswick, OH
Joined Nov 2005
Originally Posted by johann123 View Post
HappyK
Yes, the issue is my config software doesn't really allow you to place it on the screen (yet). The firmware is called "Ardu" and although Remzibi is ready, my stuff is still a work in progress. It's going to be part of my work on step 5 of this thread (and provide me the motivation to get it done!!!!)
Old Apr 27, 2010, 06:55 PM
Brunswick, OH
Joined Nov 2005
Most of the shield is unnecessary when you add the ArduIMU. It's nice that the shield has a "break-out" and power for both 5V and 3.3V GPS's but that won't be necessary after step 3 of this thread. Which is a revelation I just had while cutting the grass. Step 2 is purely academic....step 3 will make step 2 unnecessary.
To the best of my knowledge, the shield allows connections for thermopiles (not used with ArduIMU), connections for GPS's (not used with ArduIMU) and a MPXV5004DP pressure sensor. You're right, it seems like it would make more sense to just use that sensor instead!?!?
Old Apr 28, 2010, 12:59 AM
Brunswick, OH
Joined Nov 2005
This might be the better solution: http://store.diydrones.com/product_p/br-0004-02.htm along with this http://store.diydrones.com/product_p/ac-0001-02.htm
Old Apr 28, 2010, 06:21 AM
KC9TPL- Get Legit
Joined Aug 2007
Note: see post 63 for an in-stock solution.
http://www.rcgroups.com/forums/showp...5&postcount=63
This one for the true do-it-yourselfers:
http://search.digikey.com/scripts/Dk...DP&FV=fffc0177
Datasheet:
http://www.freescale.com/files/senso.../MPXV5004G.pdf
Page 2 has the resistors and capacitors:
http://www.freescale.com/files/senso...ote/AN1646.pdf
Last edited by BloomingtonFPV; May 01, 2010 at 02:50 PM. Reason: added second datasheet; link to current source
Old Apr 28, 2010, 03:03 PM
rshep is offline
Find More Posts by rshep
crashology student
Ontario, Canada
Joined May 2008
I'm attempting this project as well - shield, IMU, and Official cable on the way. Step1 went well up to the last paragraph ... attaching the Remzizi GPS. I get only a flashing blue and if I use Hyper Terminal I see a data stream but get the "no GPS for 20s". Turning down the servo tester does give "stabilization" prompts for a line or two - but no solid blue, even after 20 minutes.
I moved the GPS to the Remzibi OSD and saw (on TV) the lock on 4 satellites - so the GPS is OK (I am using the white-blue wires correctly).
Any suggestions? Any continuity to check from the 4 GPS pins?
rshep is offline Find More Posts by rshep
Last edited by rshep; Apr 28, 2010 at 03:38 PM. Reason: cable coming (using Sparkfun)
Old Apr 28, 2010, 04:43 PM
Brunswick, OH
Joined Nov 2005
rshep, I think I forgot something!!!
When you power up your OSD what baud rate does it say your GPS is using? It's going to be 9600 or 38,400...
Edit your GPS_NMEA tab
Code:
void init_gps(void)
	Serial.begin(9600);
	delay(1000);
	//Serial.print(LOCOSYS_BAUD_RATE_38400);
	//Serial.begin(THIRTY_EIGHT_K_BAUD);
	//delay(500);
	Serial.print(NMEA_OUTPUT_1HZ);
	delay(500);
	Serial.print("$PMTK220,1000*5F\r\n");
	delay(500);
	Serial.print(SBAS_OFF);
Also edit your ArduPilot_2_6 tab
Code:
void setup() {
	#if GPS_PROTOCOL == 0
		Serial.begin(9600);
	#endif
	#if GPS_PROTOCOL == 1
		Serial.begin(FIFTY_SEVEN_K_BAUD);
	#endif
	#if GPS_PROTOCOL == 2
	#endif
	#if GPS_PROTOCOL == 3
	#endif
	#if GPS_PROTOCOL == 5
	#endif
	init_ardupilot();
Tell me if this works. Please don't try a higher output rate right now. At 9600 baud there might be a problem with faster rates.
Old Apr 28, 2010, 04:55 PM
rshep is offline
crashology student
Ontario, Canada
Joined May 2008
Happy - "GPS detected 9600"
Discussion Remzibi OSD (Poor Man's OSD) integration with ArduPilot HappyKillmore FPV Talk 543 Apr 07, 2015 12:27 PM
Video REmzibi OSD current sensor test mmormota Electric Plane Talk 7 Oct 10, 2009 10:13 AM
Video Fasst dropout test with Remzibi OSD mmormota Electric Plane Talk 0 May 29, 2009 11:48 AM
Discussion Getting "waiting for GPS data" on Dragon OSD Vaportech FPV Talk 9 Aug 18, 2008 10:58 AM
