Help with a GWS Zero (rufe conversion)
I built a Zero and converted it to a Rufe,
Hope you don't mine, all the details are here on RCU http://www.rcuniverse.com/forum/m_9625739/tm.htm I need a motor/esc/battery size upgrade suggestion, Most likely a Brushless upgrade the stock EPS350C and ICS-300 Speed Controller is just not powerful enough to get it on step and out of the water I'm new to elec planes so thanks for any help |
GWS Zero can be with BL2212~ BL2215.
http://www.gwsus.com/english/product/motor/gwblm003.htm http://www.gwsus.com/english/product/motor/gwblm004.htm Or EPS-BL20 20mm inrunner with gear down. ![]() http://www.gwsus.com/english/product...tem/eps-bl.htm |
also
I was looking at that motor combo a guy recommend @ hobbyking http://www.hobbyking.com/hobbyking/s...idproduct=4706 I have a question if you know, When you look at the motor only http://www.hobbyking.com/hobbyking/s...idproduct=5111 it shows the plastic mount in the picture for the GWS stick,, But it doesn't show it in the "combo" picture,, you think it comes with it in the combo anyway? |
Drouin, Australia
Joined Sep 2003
Just to be sure may be order one of these
http://www.hobbyking.com/hobbyking/s...idProduct=5136 or these http://www.hobbyking.com/hobbyking/s...idProduct=3613 |
| Thread Tools | |
| Gallery Nakajima A6M2-N Rufe (zero floatplane) | prunner | Waterplanes | 0 | Nov 07, 2009 09:25 PM |
| Sold pica 1/12 a6m zero rufe | danny wilcox | Aircraft - Fuel - Airplanes (FS/W) | 1 | Sep 16, 2009 08:57 AM |
| Discussion GWS TM400, Pico Moth. Zero (Rufe) On Floats | ggray | GWS (Grand Wing Servo) | 5 | May 12, 2007 11:08 PM |
| Discussion GWS TM400, Pico Moth. Zero (Rufe) On Floats | ggray | Waterplanes | 6 | May 12, 2007 12:00 PM |
| Jws Zero to Rufe conversion | Lucam | Waterplanes | 0 | Feb 15, 2004 02:37 PM |
