Old Apr 24, 2010, 09:06 AM
Michaelpilon is offline
Find More Posts by Michaelpilon
Michaelpilon's Avatar
USA, PA, Bradford 16701
Joined Feb 2010
Aviastar .46
Can anyone tell me about this engine ? Aviastar .46 from Sig Manu.
Michaelpilon is offline Find More Posts by Michaelpilon
Old Apr 25, 2010, 10:17 AM
flying-things is offline
Find More Posts by flying-things
In love with aviation
flying-things's Avatar
Joined Apr 2010
http://www.rcuniverse.com/forum/m_74...tm.htm#7468461
http://www.rcgroups.com/forums/showthread.php?t=703810
There isn't too much information about the engine, but from what I've read they are good value and Sig is eager to offer warranty replacements.
flying-things is offline Find More Posts by flying-things
Old Apr 25, 2010, 11:55 AM
AB Bob is offline
Find More Posts by AB Bob
AB Bob's Avatar
USA, VA, Spotsylvania
Joined Jan 2009
Some buyers have had tuning issues (rcu thread) but I have an Aviastar .46 that has been great right from the start. Seems to have more power than my Evolution .46. I'd recommend it for the price.
Bob
AB Bob is offline Find More Posts by AB Bob
Old Apr 25, 2010, 12:05 PM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
No problems with mine. I am well satisfied with performance and price. Do use a lot of Castor with it and I found an idle bar glow plug the best as it gave an outstanding low idle. SIG seems to advise using the idle bar plugs even though they are well out of vogue for general use.
Cheers,
Chip
Chip01 is offline Find More Posts by Chip01
Old Apr 26, 2010, 11:14 AM
bigedmustafa is offline
Find More Posts by bigedmustafa
Omaha, NE
Joined Apr 2006
I have broken in and flown the Aviastar .46 from Sig Mfg. The ones I've worked with haven't had the bad carburetor problem others have reported (transition is bad no matter how lean you make the low end). The ones I've broken in and tuned have been good to go right from the box.
It may have been a happy coincidence that I often use Fox R/C Long glow plugs for my two stroke engines. They have an idle bar, and the Aviastar .46 definitely liked the plug.
I'd certainly buy another Aviastar .46 or .53 again for the right project. They're quite user friendly and reliable with the right fuel (low nitro and plenty of castor oil) and the right glow plug. They also seem to deliver plenty of power.
bigedmustafa is offline Find More Posts by bigedmustafa
Old Apr 29, 2010, 04:29 PM
Joined Feb 2010
On it's way
Thanx everybody........ the mailman is bringing me one ! He's so nice...
Old Apr 29, 2010, 04:31 PM
Joined Feb 2010
Magnum XL 30 RS
What do you guys know about starting a motor that has been sitting for years ? Brand new, display model. Magnum XL 30 RS
Old Apr 29, 2010, 05:22 PM
Patxipt is offline
Find More Posts by Patxipt
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
Pre-lube it, make sure everything runs ok by hand and fire it up!
Patxipt is offline Find More Posts by Patxipt
Old Apr 29, 2010, 08:18 PM
Joined Feb 2010
Prelube
Pre lube would mean a tiny amount of machine oil in the cylinder ?
Old Apr 29, 2010, 09:30 PM
Joined Apr 2010
wd-40, castor oil, whatever. Just to loosen up the engine.
Old Apr 30, 2010, 10:26 AM
Chip01 is offline
Joined Dec 2006
Just remember WD-40 is a solvent, not a lubricant. It does have some slick stuff in it but that is used to drive off moisture. Its okay to use, just remember it is not a lubricant. It may indeed loosen up a stuck engine but after that use some oil, tranny fluid or whatever besides WD-40.
Cheers,
Chip
Discussion aviastar .46 grasschopper Fuel Plane Talk 20 Mar 28, 2010 01:38 PM
Discussion Aviastar .46 questions KMKAZE Engines 12 Jan 29, 2010 12:09 PM
Discussion aviastar .46 grasschopper Engines 2 Dec 26, 2009 01:21 PM
Sold Aviastar AV-46 Engine fabiano_2002 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Dec 07, 2009 04:15 PM
Discussion Break-in Prop for Sig Aviastar .46 JohnsPop Engines 6 Sep 18, 2009 04:02 PM
