Old Apr 24, 2010, 06:20 AM
karosi is offline
Find More Posts by karosi
Joined Apr 2010
Question
Cessna 182 (980 mm, EPO) Art-Tech
Hi all,
I have bought an 'Art-Tech Cessna 182 Skaylane 2.4GHZ RTF V3 EPO mit Simulator BLAU' several days ago from hobbyfly.de. It was nice and it has worked properly. However, I tried to disconnect the battery from the speed controller by a small screwdriver. The connection was very-very tight. During this manipulation sparks have occured. Now the plane does not operate, only a continuous bipping from the brushless motor can be hear. The servos are pulsating. It does not referr to the radio signs. Is the problem great? What should I do?
Thanks, Tamás Karosi
karosi is offline Find More Posts by karosi
Old Apr 24, 2010, 02:21 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Sounds like you fried something.
NEVER use a screwdriver to unplug a battery!!!!!!
Xpress.. is online now Find More Posts by Xpress..
Old Apr 25, 2010, 08:38 AM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
If you shorted the battery terminals then you can discard and replace the battery. You may have to replace more than that but start with the battery.
fmw is offline Find More Posts by fmw
Old Apr 27, 2010, 02:38 PM
avt is offline
avt
Find More Posts by avt
avt
Hell Flyer
Israel
Joined Nov 2006
If you have another battery, try it.
If the problem is not solved - look for a new ESC.
avt is offline Find More Posts by avt
Discussion How to install Spektrum DX6i in Art-Tech Cessna 182 V2 kahays77 Electric Plane Talk 9 Jul 01, 2015 01:01 PM
Discussion Art-Tech Cessna 182 Version 2 tagmann50 Parkflyers 0 Apr 09, 2010 02:38 AM
Discussion Art Tech Cessna 182 nitro conversion !!! ryank Fuel Plane Talk 8 Sep 08, 2009 02:10 PM
