Old Apr 23, 2010, 10:27 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Oh no, 58" Vanquish or 62" Osiris...I didn't want to have to choose.
cwojcik is offline Find More Posts by cwojcik
Old Apr 24, 2010, 01:16 AM
Warbirds Rule is offline
Find More Posts by Warbirds Rule
Warbirds Rule's Avatar
Leesburg, VA
Joined Jun 2006
If it turns out to be approx. 8lbs then that will be great because then you will be able to fly it on 6S 5000 with an inexpensive outrunner, get reasonable flight times and have really good overall performance. It just seems like planes this size turn out closer to 9lbs which starts to tax a 6S/outrunner power system. Either way, I can't wait to see it perform. The Extremeflight stuff just flies so well no matter what the size.
Warbirds Rule is offline Find More Posts by Warbirds Rule
Old Apr 24, 2010, 10:12 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
The 70" Slick comes around 9lbs, and people are getting great performance on a 6S 5000 setup.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Apr 24, 2010, 11:07 PM
Daloaf is offline
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
I love my 78" extra, but don't think I have room in my stable for another 70" plane at the moment. But I love EF entering the 70" segment, because it just helps validate that size plane and you will start to see more manufacturers selling parts targeting this size plane.
Daloaf is offline Find More Posts by Daloaf
Old Apr 25, 2010, 01:52 AM
Vitter is offline
Find More Posts by Vitter
Gas Monkey Vic
Vitter's Avatar
Snohomish, WA
Joined Jan 2005
+1
Hovering at just under half stick, flying for 7-8 minutes putting 2629-3562mah back in the pack, and all components only warm. I think 6S 5000 is the new 3S 2200 and we will see more and more 70" airframes for this setup. I know I want this one and if they make a 70" EF Yak I will buy one. HINT HINT
vitter
Vitter is offline Find More Posts by Vitter
Old Apr 25, 2010, 02:40 AM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
Ben-Rod is offline Find More Posts by Ben-Rod
Last edited by Ben-Rod; Apr 25, 2010 at 02:44 AM. Reason: too much time on my hands
Old Apr 25, 2010, 02:41 AM
Ben-Rod is offline
Ben-Rod's Avatar
Joined Nov 2004
...Sorry for buggering up the thread.
Old Apr 25, 2010, 02:39 PM
Leesburg, VA
Joined Jun 2006
Actually, that's the plane I was thinking of when I mentioned 9lbs and a little too much for an outrunner on 6S 5000. From the videos I've seen the outrunner powered 70" Slicks look a bit sluggish. That's not to say the don't fly great because they do and there's plenty of video and satisfied customers around here to prove it. I also noticed it seems like a number of people are putting 8S in them these days. IMHO 7S or 8S i a more natural match when pairing the Slick with an outrunner power system. I'm sure it stays nice and cool and keeps the amps down so flight times aren't too short. All that said though the numbers you've mentioned below are very good. If you're hovering at under half stick throughout your flight and after 8 minutes you're only down 70% on a battery that's nice performance and reasonable flight times. What motor/esc are you using?
Thanks!
Originally Posted by Vitter View Post
+1
vitter
Old Apr 25, 2010, 06:47 PM
ambientech is online now
Find More Posts by ambientech
ambientech's Avatar
Central Texas
Joined Jun 2008
Thanks!
I am running 6s 5000 20c packs in my 70" Slick making 2300 watts. That is 255 watts per pound at 9lbs. I get 7 1/2 minutes only using 80%. Sure it isn't 15+ minutes like gas but not bad. IMO 6s 5000 makes perfect sense in this size.
Hacker A50-12L
Xoar 20x10
Ice 100 esc
ambientech is online now Find More Posts by ambientech
Old Apr 26, 2010, 01:22 AM
Leesburg, VA
Joined Jun 2006
2300 watts on 6S.....Wow! How many amps are you pulling? I guess the new batteries make all the difference?
Thanks.
Hacker A50-12L
Xoar 20x10
Ice 100 esc
Old Apr 26, 2010, 01:33 AM
Here We Go!
Joined Jun 2005
I'm running 8S in my Slick, and I'll run 8S in the 70" Extra when I get one. The reason I'm running 8S in my Slick isn't for performance though, it's because I already had a bunch of 4S 4000 packs that I use in other planes. It made sense to me economically to go that route and just run them in series. But you're right....it does keep the amp draw down. I'm getting about 2100 watts at around 68amps. Packs stay cool as well as the esc and motor. Not a bad setup IMO.
Old Apr 26, 2010, 06:40 PM
ambientech's Avatar
Central Texas
Joined Jun 2008
Thanks.
101 amps fresh of the charge drops to about 2100 watts. I am using Zippy 20-30c 6s 5000 packs the 50 dollar packs They don't get hot at all so I guess they are closer to 30c than 20c
Old Apr 26, 2010, 06:44 PM
ambientech's Avatar
Central Texas
Joined Jun 2008
This makes perfect sense If I had a bunch of 4s 4000 packs I would have done the same but since I didn't I went the cheap way which works well.
Old Apr 29, 2010, 11:29 AM
Here We Go!
Joined Jun 2005
Anymore info on this now that SEFF is over??
Old Apr 29, 2010, 12:10 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
I bet it's going to be another great offering from EF.
BoneDoc is offline Find More Posts by BoneDoc
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9441 Yesterday 11:15 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 09:07 PM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 09:55 PM
Found Extreme Flight 47" Yak or 48" Extra EXP 3DKid1995 Aircraft - Electric - Airplanes (FS/W) 7 Dec 27, 2009 10:34 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 03:48 PM
