Old Apr 22, 2010, 07:32 PM
17b is offline
17b
Find More Posts by 17b
17b
17b's Avatar
Viersen, Germany
Joined Jul 2004
Trikopter with folding Mechanic
Inspired by William Thielickes Thread i managed to build my own trikopter by copying his ideas.
This Trikopter worked very well, William did an amazing Job. Thanks again!
In the meantime i also managed to build a Mikrokopter based on the Hardware from HISystems. I designed a simple frame with carbon tubes from kites.
As William finished his new Mini Trikopter, i decided to make also a new one. This time the footprint should be a little smaller than my first one, and a little bigger than the mini. As a gimmick, i wanted to be able to fold two of the arms to make it better transportable.
The new tubes are carbon tail booms from a 450 TRex.
The main frame is copied from Williams design. I added some holes for connecting the folding mechanism and some clips made from 8,5mm POM to keep the two arms in place.
The clips
The Motor Platforms
This part holds the third arm in place and prevents the two others from damage by folding to hard (sorry, my english is not that good)
The Mainboard. Its designed by William and i could get two of them.
I will use three EMax motors. As soon as i get it, i will exchange the original windings against 15 turns 0,5mm copper wire.
The servo mechanism
The servo driven back motor is not in the middle so it looks like the motors are not in right angle.
All Parts except the clips are made of industrial made fiberglass (FG) that is originally used to make PCBs. Carbon would be also possible, but i dont like it.
The frame is made of 1mm FG. It is unbelievable how stiff the construction is. This could be achieved by using those black spacers between the yellow frame parts
17b is offline Find More Posts by 17b
Old Apr 22, 2010, 11:08 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
beautiful work!
thanhTran is offline Find More Posts by thanhTran
Old Apr 22, 2010, 11:25 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Really nice job!
Williams board is a work of art.
RCvertt is offline Find More Posts by RCvertt
Old Apr 23, 2010, 12:04 AM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Really cool!!
G-unit is offline Find More Posts by G-unit
Old Apr 23, 2010, 03:46 AM
17b is offline
17b
17b
17b's Avatar
Viersen, Germany
Joined Jul 2004
Thanks! Today i will mill a board where i can place all the stuff upon. I started to convert the 3 BEC i got from HK. To save some weight and space it might be possible to stack them and place them in front of the rear arm between the two main frame plates.
Old Apr 23, 2010, 05:47 AM
tori3 is offline
Find More Posts by tori3
Joined Jun 2009
That "William's" board looks like a stock Arduino Pro Mini.
tori3 is offline Find More Posts by tori3
Old Apr 23, 2010, 06:58 AM
17b is offline
17b
17b
17b's Avatar
Viersen, Germany
Joined Jul 2004
Of course it is. If you read Williams Blog about his Electronic Design, you will see that it is based on Arduino.
Old Apr 24, 2010, 11:13 AM
17b is offline
17b
17b
17b's Avatar
Viersen, Germany
Joined Jul 2004
Finished!
I had to modify some of the parameters, but in the End it flew pretty good.
Lift off weight is 614g. Fat bastard...
Some Details can and will be optimized.
Wireless communication between Laptop and Tri is done by a selfmade Bluetooth dongle, based on a BTM-222 chip
Old May 31, 2010, 08:39 PM
17b is offline
17b
17b
17b's Avatar
Viersen, Germany
Joined Jul 2004
Here are some pics in flight:
I modified the original drawings of William for better mounting of the ESC and changed to Roxxy Motors. Meanwhile i also attached some LED strips.
To switch the Trikopter on i added two microswitches who give contact as soon as the right and left arm is put into flight position. In case of a crash the arms fold back and switch main power of to avoid further damage.
Old Jun 19, 2010, 03:49 AM
mcgyver_taner is offline
Find More Posts by mcgyver_taner
Turkey / Antalya
Joined Sep 2009
hi
nice job
how can i find the main frame plans or blueprints ?
mcgyver_taner is offline Find More Posts by mcgyver_taner
Old Jun 20, 2010, 09:54 AM
17b is offline
17b
17b
17b's Avatar
Viersen, Germany
Joined Jul 2004
Hi,
you can get the original Plans on Williams Blog. Check out the Link in the first Thread.
Old Jun 20, 2010, 10:55 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Amazing Ingenuity Engineering right here, there is no doubt about that. Great Job!!!
rimshotcopter is online now Find More Posts by rimshotcopter
Old Dec 06, 2010, 04:47 PM
gunnar-rc is offline
Find More Posts by gunnar-rc
Joined Sep 2010
Yes very nice looking. Something tells me I need to research these parts and build one like this with the folding action. I want to build it Y6.
gunnar-rc is offline Find More Posts by gunnar-rc
Old Dec 06, 2010, 05:17 PM
17b is offline
17b
17b
17b's Avatar
Viersen, Germany
Joined Jul 2004
Ha, then you will get a Draganflyer.
Go for it!
Discussion 14.8gr RC-Glider with folding motor. With plans and Video RetoS. Scratchbuilt Indoor and Micro Models 94 Jul 02, 2015 12:03 AM
Help! Octocopter with folding arms on the cheap... need help danielpetrescu Multirotor Talk 9 Apr 02, 2014 01:30 PM
Sold Phasor 30-3 with cam folding prop soar-iowa Aircraft - Electric - Power Systems (FS/W) 2 Mar 06, 2010 10:09 AM
For Sale Brand new brushed 380 with gear box and folding prop. randall1959 Aircraft - Electric - Power Systems (FS/W) 1 Feb 28, 2010 08:41 AM
Discussion Cybird P1 mechanic in hxbird ! beaulac Ornithopters 1 Oct 02, 2009 09:21 PM
