I've tried a few props on mine, all with the stock 220mah 25c 3 cell, mine tips the scales at 37oz flying weight
The stock 10.5X9 prop makes 42oz of thrust static, 32A draw. It is just barely enough to pull unlimited vertical, the plane accelerates relatively slow, but just seems to keep accelerating as far as the eye can see, the plane picks up speed in a dive very fast, but you need to keep on the throttle to maintain control, dropping below 1/2 with any control movement will bleed off speed pretty quickly. The next prop I tried was the APC 12x6e prop, and MAN did it make a difference, measuring 62oz of static thrust, almost 50% more than the stock prop at an almost identical 33A draw. It will hover just a bit over 1/2 throttle, can take off in a couple feet, and climbs like a rocket. The prop is large, and even with larger 2.5" wheels, it only has about 1" ground clearance, and wil cut grass while taxiing with all 3 wheels planted. It also can be a very good air brake at low throttle, it slows the plane down much faster when throttle is reduced, and makes some moves like pulling vertical from a knife edge, and kind of a rough looking waterfall possible, you have a lot more control of the speed, both slow and fast, and while it may not be quite as fast as the stock prop, especially in a dive, it is pretty close in level flight, but has a huge advantage in acceleration and pullout. My current and favorite setup is the BF-109 10.6X7.8 3 blade prop with a 2" white dubro spinner, it measures 58oz of thrust at 39A WOT(above stock ESC rating), close to the 12X6, but the steeper pitch gives it a faster top speed. It does not quite have the instant response and acceleration of the 12X6, it has a little softer and more forgiving feel, although it still has plenty for very fast pull outs from hovers, it seems to work best across a much wider range of speeds. It seems to have just as much, and maybe a bit more braking at closed throttle than either of the 2 bladed props. Slow flight seems to be more stable, hovers and harriers are a bit more stable than with the 12X6, and FAR easier than with the stock prop, there is more torque to overcome though, but it is consistent. It does seem to require a bit more correction for torque than the 2 bladed props at takeoff, and at slow speeds, but being it is the same length as the stock prop, ground clearance is not an issue, and with the bigger wheels, taxiing, takeoffs and landings from grass is easy. It also looks cooler IMO than the 2 bladers. |
Interesting... I think I have a 109 stock prop laying around somewhere... I'll have to give it a try...
In my testing this morning, I preferred the APC 11x7E to the cut down (to 11") 12x6E APC. Just better overall performance. I have not tried the 12x6, but the 6 pitch felt to slow for this plane (albeit I am flying at 5000ft). |
Latest blog entry: LEDs on my T-28
Servo Twitching
I had a problem that I'd like some opinions about.
I flew yesterday and everything was fine. I left the plane assembled overnight. I hooked up the battery today and every servo twitched. The motor even started and stopped randomly. This happened on multiple tries with several batteries. Sometimes the control surfaces responded to the transmitter, sometimes not during the twitching. ![]() I flew another plane using the same transmitter and saw no signs of interference. I took the EXTRA home and took off the prop, cowling and motor. I checked every connection from the receiver to the ESC and plugged another battery in. This time with the prop on the workbench. I like my fingers. ![]() No twitching. Everything was rock solid. No obvious connection issues found, but who knows? ![]() I use a 72 MHZ FUTABA transmitter and a Berg 4L receiver, which I think I eliminated as the source by flying another plane. Any ideas? I am a little leery of flying the plane until I think I know the answer. Thanks. Eric |
I almost 100% assure you it was a bad bind on the radio...well bind as in 72mhz bind. Did you shut all down incl radio, restart all and see??just sounds like the 2 had some interference. |
Thanks. I'll recheck a few more times before flying. |
| Thread Tools | |
| Discussion Extra 300 32e ARF by E-flite - Horizon Hobby | SalamSyed | Electric Plane Talk | 328 | Jul 21, 2012 05:31 PM |
| Yippee! New parkzone extra 3d flyer bnf or pnp!!!!!!!!!!!!!!!! | lightspeeddud | Parkflyers | 98 | Feb 01, 2012 06:52 PM |
| Discussion Horizon Hobby's 2010 New Release PZ Extra 300 & E-Flite LR-1A Pogo | ChuckTseeker | Electric Plane Talk | 97 | Sep 10, 2010 09:20 PM |
