Old Sep 27, 2001, 09:56 AM
William A is online now
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
10 tooth/48 pitch pinion gear, where at ?
New Creations is out of stock and might be for awhile, any other source ?.
William A is online now Find More Posts by William A
Old Sep 27, 2001, 12:05 PM
Steve H. is offline
Find More Posts by Steve H.
Zebulon, NC
Joined Aug 2000
That the ome for the great planes box? MEC might have some.
Steve H. is offline Find More Posts by Steve H.
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
These 10T pinions are indeed a pain. Maybe Gary W will start selling parts too!
NCP Hobbies sells them for $0.55....not bad!
http://www.ncphobbies.com/newstore/s...armagears.html
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Sep 27, 2001, 05:51 PM
davecee is offline
Find More Posts by davecee
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
I don't think that the gear you referenced is for a 1/8 inch shaft. A 10 tooth 48 pitch pinion is about as small as you can get on a 1/8 inch shaft and your source has pinions down to 7 tooth on the same ad and is for slot cars.
I bought some 10 tooth pinions directly from Leisure Electronics. I forget the price, but it wasn't much. I don't have their address at hand but I remember I found it easily by doing an internet search.
Dave C.
davecee is offline Find More Posts by davecee
Old Sep 27, 2001, 11:08 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Try <a href=http://www.rc-aero.com/biz/mec/ target=blank>Model Electronics Corp.</a> for the 10 tooth gear.
GregG is offline Find More Posts by GregG
Old Sep 28, 2001, 07:16 AM
Rochester, NY, USA
Joined Aug 2000
Dave,
You're probably right about the shaft size. The pinion would likely need to be drilled out to fit a 1/8" shaft.
The real gear is a (LE-Gear10) from Leisure. The 10t Pinion Gear was about $2.50 but they raised it several months ago. Kirk had raised his price to around $4.
If all else fails, Kirk would give you the number for Leisure. I didn't find a link.
Here is the MEC link:
http://www.modelelectronicscorp.com/
They don't list the 10T pinion seperately so you'll have to call.
Old Sep 28, 2001, 10:28 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
I just called New Creations, they said they'd have pinion in sometime next week.
Jim McPherson is offline Find More Posts by Jim McPherson
Old Sep 28, 2001, 12:52 PM
davecee is offline
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
Leisure Electronics: 949-552-5749
For Sale 48 Pitch Pinion&Spur Gears for EP 1/10th. R_JOB Cars - Cars and Parts (FS/W) 0 Feb 14, 2006 03:57 PM
Outlet for a 9 tooth 48 pitch 2.3 mm pinion for a Shogun rickc Mini Helis 6 Jun 10, 2004 09:23 AM
What's the Pitch of the Pinion Gear for Hornet Heli Motor? GoEFlight Micro Helis 2 Dec 06, 2002 01:27 PM
need replacement pinion gear...where to find? research_guy Electric Plane Talk 5 Sep 19, 2002 04:58 PM
GWS Pinion Gear Pullers at Balsa Products peterv Electric Plane Talk 14 Jul 10, 2002 11:23 AM
